Old Apr 19, 2003, 10:43 AM
mrebman is offline
Find More Posts by mrebman
Cincinnati, Ohio USA
Joined Nov 2000
Here is how Mod'd some nice A10 Wheels-better than the stock ones!
I really hate the stock plastic rattling hoop wheels that come with the GWS A10. Almost every hobby shop carries the common Du-Bro "Mini-Lite" wheels (each wheel weighs 2.14 gr). These wheels are too wide to fit on the stock A10 landing gear wire so I decided to MAKE it fit. First you need to use a 5/64" drill bit to get the axle hole the right diameter. Then, you need to use an 11/64" drill bit to "Countersink" a hole about halfway thru the hub, be careful not to go all the way thru!
The reason for the counter-sunk larger hole is so that you can slide the #A1 keeper in to connect to the end of the axle. Now just use a channel locks or pliers to press the keeper onto the end of the axle & you are Done! One added benefit of using the countersunk hole is that the keeper disappears into the Hole & also fills it. So far the wheel seems quite secure & rolls real easy & no more rattling or sliding on those plastic hoop jobbers & they seem fairly scale & are Light Weight.
-Hope this Helps- (See Pics below)
-Mike-
P.S. - I used 1-1/2" wheels for the mains & I will probably use 1" or 1-1/4" wheels for the nosewheel (Those sizes are already countersunk)!
mrebman is offline Find More Posts by mrebman
Old Apr 19, 2003, 10:45 AM
mrebman is offline
Joined Nov 2000
Here is a view from the side.
-Mike-
Old Apr 20, 2003, 09:25 AM
LESLIEx317537 is offline
Find More Posts by LESLIEx317537
Inbox is almost full
LESLIEx317537's Avatar
Long Island, New York
Joined Nov 2002
I have those also, but I prefer the Hobby-Lobby LYT45's for the rear.
And the smaller wheel up front.
Asorbs more shock than the Dubro's.
LESLIEx317537 is offline Find More Posts by LESLIEx317537
Need some input on how to mod this design Slope Nut Electric Plane Talk 3 Apr 18, 2004 06:21 PM
I need Recommends on some nice Wheels for my GWS Corsair. mrebman Parkflyers 4 Feb 02, 2004 04:15 PM
Here's Some Nice Scale Photos! Paul Naton Scale Sailplanes 1 Sep 29, 2003 12:39 AM
Question Are some channels better than others? BuddyO Radios 13 May 21, 2003 12:11 PM
Kan 950 cells how they are better than the HECELL in REAL SIMPLE Laymens terms. kushal_22 Batteries and Chargers 15 Mar 20, 2003 06:58 PM
