Old Apr 19, 2003, 04:22 AM
mefly2 is offline
Find More Posts by mefly2
mefly2's Avatar
New York Mills, MN
Joined Jan 2002
Finally finished my Dandy-...uhh...Poly/Ail/Sport...maybe...
Finally got 'er done. I modeled it after an old sailplane I have...not sure how it's going to work, but I'm confident. I call it my Dandy-Poly/Ail/Sport... . Sport because I put an EPS300c up front.
Weighs in at 13.5 ounces, 1.5 more than specified. Not too bad considering the ailerons, 1/32" sheeting-LE to top spar, and the motor w/8x720 AAA's.
Thanks for looking...
Bob
mefly2 is offline Find More Posts by mefly2
Old Apr 19, 2003, 04:29 AM
mefly2 is offline
mefly2's Avatar
New York Mills, MN
Joined Jan 2002
Kind of hard to see, but this shows the ail flex cable exiting the fuse (yellow thingies ). I also need to put the LG in all the way, maybe it wouldn't sit crooked then... .
Now, if the 3" of snow will melt, the wind drop a few hundred miles an hour, and the temp rise above freezing...maybe I could maiden it.
Bob
Old Apr 19, 2003, 05:48 AM
j8m8l is offline
Find More Posts by j8m8l
Thats NOT indestructible
j8m8l's Avatar
London UK
Joined Apr 2002
Hi Bob
That looks amazing man.
I am beguinning to think that i should get one of these before my SB !
Could you explain how you covered it, i really like the icicle look.
Josh
j8m8l is offline Find More Posts by j8m8l
Old Apr 19, 2003, 07:11 AM
mefly2 is offline
mefly2's Avatar
New York Mills, MN
Joined Jan 2002
Hey Josh, before you make your decision, I just wanted to mention that the regular Dandy doesn't have ailerons, if that matters... .
Covering was fun...let me just say I'm glad it is done...WHEW!
First I LIGHTLY spray painted the frame white. I then covered the stab and rudder completely w/white Solite, and the wing from the top spar back (pic). Then I took blue Solite and cut pieces out that covered one half of the stab top, one full side of the rudder, and half of the wing top. I then cut the chunks of covering in half, using the zig-zag pattern on the plane. That way I had two separate pieces with the pattern.
Too keep air bubbles out, I lightly sprayed the covering that was going to be underneath the blue w/water and dishsoap, layed the pieces of blue where I wanted them, took a paper towel and "squeegeed" the water/soap out from underneath the blue, and let it sit overnight. After it dried I went over it with my iron on low heat...this tacked it down better w/o shrinking the blue. Use Windex and a paper towel to clean off any dried soap, this will also find any loose edges tho, so be careful.
And there you have it...easy... !
Hope that all is understandable, if not let me know.
Bob
Old Apr 19, 2003, 07:16 AM
mefly2 is offline
mefly2's Avatar
New York Mills, MN
Joined Jan 2002
BTW...if you do this, remember to seal the covering down tight to the bare wood on the wing... .
Bob
Old Apr 19, 2003, 08:19 AM
j8m8l is offline
j8m8l's Avatar
London UK
Joined Apr 2002
Hi
I know that the normal one dont have ail's, but i am sure that i can handle a mod
I would also get the sport wing for some more fun !
Cheers
Josh
Old Apr 19, 2003, 10:05 AM
FLYWINGFAN is offline
Find More Posts by FLYWINGFAN
FLYWINGFAN's Avatar
Minneapolis MN
Joined Sep 2002
Hey Bob,
great plane you got there! nice to see another MNer, (I can sympathise with the weather )
-Sam
FLYWINGFAN is offline Find More Posts by FLYWINGFAN
Old Apr 19, 2003, 02:02 PM
mefly2 is offline
mefly2's Avatar
New York Mills, MN
Joined Jan 2002
I'm sure you have pretty much the same weather there....
Well, even tho it's raining, I'm still watching for the wind to die. Where 'bout is Harris, MN. (too lazy to find a map... )
Bob
Old Apr 19, 2003, 09:13 PM
FLYWINGFAN's Avatar
Minneapolis MN
Joined Sep 2002
About 8 miles North of North Branch
-Sam
Old Apr 20, 2003, 04:01 PM
mode1 is offline
Find More Posts by mode1
mode1's Avatar
Southwest Missouri
Joined Oct 2002
Nice Dandy. Lots of fresh ideas. Talented list, this is. LeRoy
mode1 is offline Find More Posts by mode1
Old Apr 20, 2003, 10:36 PM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
Woah Bob! That looks awesome!!! Fantastic covering job, and excellent work on the ailo conversion. Can't wait to hear how she flies!
==Now, if the 3" of snow will melt==
What, don't you know that Dubro makes skis now?
Tres Wright is offline Find More Posts by Tres Wright
Old Apr 21, 2003, 03:05 PM
mefly2 is offline
mefly2's Avatar
New York Mills, MN
Joined Jan 2002
Thanks for the good words, Tres...
Yeah me too! Beautiful day, but windy. I ended up pulling an all-nighter on my Taco, just so I wouldn't miss daybreak. The wind was already blowing then... .
...heh,heh...skies... .
Bob
Finally finished my RV-4!!! Cass Parkflyers 12 Feb 07, 2004 08:20 AM
Finally- Maidened my Dandy Sport(after retiring estarter) wolfance Parkflyers 14 Jun 17, 2003 11:59 PM
Rave Finally finished my Bluto!! tenover Slope 35 Nov 21, 2002 09:47 PM
