Go Back   RC Groups > Vendors > Castle Creations
Old Nov 05, 2009, 10:56 AM   #31
Patrick del Castillo's Avatar
Originally Posted by DavidN View Post
Patrick there was a thought behind my post. The possibilty of a fall back lower power safe program to use till the final versions work out. I realize this is impractical at this development stage. But maybe a strategy for a new rollout.
David,
Well, that's kind of what the ICE is all about -- there is built-in current protection if people wish to use it.
Patrick del Castillo is offline Find More Posts by Patrick del Castillo   Reply With Quote
Old Nov 05, 2009, 11:07 AM   #32
"Do it with batteries"
DavidN's Avatar
would that stop the Squealing?
DavidN is offline Find More Posts by DavidN   Reply With Quote
Old Nov 05, 2009, 11:10 AM   #33
Which sort of prompts the response 'why would anyone not wish to use it..?'
IIRC, 'insensitive' current protection is recommended for helis. Is this still the case ? Does this still provide adequate protection ?
scallybert is offline Find More Posts by scallybert   Reply With Quote
Old Nov 05, 2009, 11:48 AM   #34
With the ICE, you can setup a maximum current, in amps. This is different than the "standard" current limiting.
Old Nov 05, 2009, 12:06 PM   #35
Cool. So it can be set to protect the packs & motor - not just the ESC.
Old Nov 05, 2009, 01:20 PM   #36
Exactly. You shouldn't try to use it to run a "bad" setup -- full throttle current should be below the rating of the motor, esc AND batteries, but it can protect things quite well when something bad happens.
So, always set up your system within the specifications of the components, and don't try to use the current limiting to protect sub-par components.
Old Nov 05, 2009, 02:31 PM   #37
MrE
I would highly recommend that Patrick's comments in posts 28, 34, 36 about how the new software allows more power to be made a sticky AND post it on the web site as an up-grade note/warning.
Lots of guys wont believe or understand whats happening but they need to be warned anyway.
MrE is offline Find More Posts by MrE   Reply With Quote
Old Nov 07, 2009, 08:14 AM   #38
coy
Hi,
i've experienced the same "squealing" while checking my new motor (HS2220-3500) with a phoenix 45 on my Mini Titan heli.
For testing, on the remote i manually raised the throttle in governor mode starting from 0. At some rpm rates this squeling appeared very loud, but when going to higher (desired) rpm it disappears.
Software version is the latest (2.18). Timing is already low, PWM rate is 12KHz.
Should i change any settings? Is it safe to fly with this firmware version at all?
(sorry if my english is not 100% accurate - i am from Germany :-)
Regards
Markus
coy is offline Find More Posts by coy   Reply With Quote
Old Nov 07, 2009, 08:50 AM   #39
nsg
Markus - I'd go back to 2.16
nsg is offline Find More Posts by nsg   Reply With Quote
Old Nov 08, 2009, 11:35 AM   #40
Manta1's Avatar
Send a message via Yahoo to Manta1
hmmm i wasnt aware of this.this is neat.we may need to chat
Manta1 is offline Find More Posts by Manta1   Reply With Quote
Old Nov 08, 2009, 04:35 PM   #41
Staggerflyer's Avatar
Not having flown in over two months, and just updating my software/firmware to 2.16 from 1.56, not knowing about this squealing problem, and using lower C rating batteries, I didn't experience any squealing, instead my motor kept cutting out (current limiting?) at half throttle. It did NOT do this until the update to 2.16.
My system: Great Planes P-6E Hawk ARF, 15 lbs AUW. EFlite Power110, Phoenix 85HV, Common Sense 6000mah 8C 18.5v x 2,(as 10S), 18x10 MenZ wood prop. First couple flights flown using Master Airscrew 16x10x3blade prop. Max amps pulled on ground 47amps.
New aircraft this past spring, only flown maybe 1/2 dozen flights. Full throttle hit maybe 5-6 times on original set-up. Then only for 2-3 seconds at a time. No problems encountered. Then updated firmware to 2.16 (Link software was 3.16) and then, for first time, motor would cut out at about 55% throttle, ground or air. Cut-off is set as hard, so returned throttle to idle and had power again. Since plane needs only 45-50% throttle for full flight regime, was able to fly it for show put on for Veterans Home by our local club.
I've since purchased new Impulse 18.5v 20C 4800mah batteries, and now I have the squeal at just over half throttle that is being dicussed on multiple threads here and elsewhere. Going to full throttle does NOT reduce/change it. It will do this with or without prop installed, so it is NOT over propped.
I also have a Top Flight Staggerwing with EFlite Power 160, Phoenix 110HV with 1.56 firmware, using same batteries, and no problem. I switched ESCs to see what would happen, and the squeal followed the ESC from plane to plane, so it is definitely the software!
Still waiting for the new software to come out, so I can fix these problems, I hope.
Staggerflyer is offline Find More Posts by Staggerflyer   Reply With Quote
Old Nov 08, 2009, 07:45 PM   #42
if anyone wants to sell there ice 50 send me a pm
cmulder is offline Find More Posts by cmulder   Reply With Quote
Old Nov 13, 2009, 01:10 PM   #43
I see a new firmware update for the ICE. Anybody know if that is the squeal fix?
dgfinch is offline Find More Posts by dgfinch   Reply With Quote
Old Nov 13, 2009, 01:22 PM   #44
Yes, this is the squeal fix.
Old Nov 13, 2009, 01:23 PM   #45
DavidN's Avatar
Please how it is working out there in the trenches
Zero, Jeti 110 stops at full throttle.... SpiritQuest Power Systems 3 Jan 26, 2003 04:27 AM
GWS ZERO climbs at full throttle! Mr.Dickles Foamies (Kits) 10 Oct 24, 2002 10:05 PM
Lithium powered Terry 14+ minutes at full throttle. craig2k Electric Plane Talk 9 Jul 02, 2002 07:33 PM
QC830's with Stock TM at full throttle? coggy Parkflyers 2 Apr 17, 2002 04:28 PM
ZAGI 400-X ; power cutting out to motor after flying at full throttle Joe-z Foamies (Kits) 29 Jul 15, 2001 11:51 PM
Bored? Want to fight?
Join the RCGroups clan!
