| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#16 |
Registered Plane Abuser
I have to ask again since no one is answering me from Castle. When is this problem going to get fixed?
#17 |
Jeroen van 't Hert
Don't be surprised if it takes at least a few more weeks. I wonder why they keep adding features to a release that's still in beta... If anything happens they'll probably end up blaming you for using their beta stuff.
Furthermore I stumbled upon some pdf's of the ice controllers on google from Castle that state the ice controllers cannot sustain more than half their rated amps in a non airflow situation. Nice one! Edit: I can't find the document only this: castlespecialprojects.com/csp_phoenix_ice.html Last edited by jvthert; Oct 25, 2009 at 03:16 PM. |
#18 |
I updated to 3.19 yesterday and my s2 3008 1220kv scorpion, 3s, 3y.o. CC P35 is having the sink problem until the battery looses its intial peek (about 30 seconds into flight).low advance and med response is best as stated above. low response i think is better but too doggy. My a50 14s hacker on 5s (older motor, 1 y.o. CC P80) is doing fine.
good luck CC |
#19 |
"Do it with batteries"
I have been waiting for the ICE for an inrunner. Hacker B50 11XL 6.7 GB. ANy issues with innrunners.
Flying season is over here except for small stuff on sunny days, so no rush. |
#20 | |
And why the attitude? We don't blame people for using Beta software -- we post up the Beta software with the understanding that it might not be perfect, and users should handle it as such -- it's not Alpha (untested, unproven,) it's Beta (tested and proven.) There may be minor issues with Beta software, but we want to make it public so that people can try it out -- especially if it adds new features or has some fixes. WE DO expect people to test their system after uploading Beta software to be sure that it works correctly BEFORE flying. To be considered Released software, takes a very very long process of testing. (I come from an Avionics background -- and we take Release software testing VERY seriously!) Patrick |
#21 |
Patrick,
Please help me. I can't use my ICE LITE 50 because it doesn't work with my motor because of the "squealing" problem. My motor is a Torque 2818/900 running with a 4S 2350 Lipo and a 12-6 E prop. Does the ICE LITE 50 really not work with this combination or am I just missing something? If it really doesn't work with this combination when do you think it will be fixed? |
#22 | |
Patrick |
#23 |
Joes Pit Crew
Patrick -- you guys feeling better?
Glad to hear we are getting close to a fix for the Squealing issue.
#24 | |
#25 |
Thank you Patrick. Can't wait to try it.
nsg, Unfortunately 2.16 didn't work for me. Even after changing the setup as Castle suggested. It was much better than 2.18 though. 2.16 caused squealing from about 60 to 80% throttle. 2.18 caused squealing from about 20 to 100% throttle. |
#26 |
DonJuan -
The (mostly default) settings that worked for me: -fixed endpoints - normal timing - 8 KHz PWM. |
#27 |
When I have compared CC Phoenix 80 to my similar ESC I get consistently higher (1-2) & amps & RPM. So is it pushing the power edge that causes the problem? Or am I just exposing my ignorance.
#28 | |
The reason you see a couple more amps, and more RPM from the Castle controller is that we hold timing much tighter than many other controllers. Many low cost controllers don't have enough computing horsepower to keep timing accurate at high RPM on high pole count motors (like outrunners). On some low-cost controllers, the timing gets more and more retarded as the RPM goes up. This causes a drop in both power and efficiency as the RPM rises. So, when upgrading to a Castle controller, you should ALWAYS check the power -- you will likely draw more power, and get more RPM from the motor. We have seen several cases where motor damage occurs shortly after an upgrade to a Castle controller -- in one case, a system that drew 60 amps on a low-cost controller drew almost 100 amps using a Castle controller. The customer was thrilled until the magnets on the motor came loose under full power and the motor was destroyed. So -- ALWAYS use caution and make sure your system does not exceed the maximum power that the motor is designed to handle after upgrading to a Castle controller. If necessary, you should go down a bit on prop size (or gearing on a helicopter) to reduce the current draw on the system to a reasonable level. That said -- the new software to be released later this week will allow even higher power to be extracted from outrunners and other high-pole-count motors than was previously possible. So, people will need to be VERY careful with their systems, and make sure they don't over-amp their motors. |
#29 | |
#30 |
Patrick there was a thought behind my post. The possibilty of a fall back lower power safe program to use till the final versions work out. I realize this is impractical at this development stage. But maybe a strategy for a new rollout.
| Thread Tools | |
| Zero, Jeti 110 stops at full throttle.... | SpiritQuest | Power Systems | 3 | Jan 26, 2003 04:27 AM |
| GWS ZERO climbs at full throttle! | Mr.Dickles | Foamies (Kits) | 10 | Oct 24, 2002 10:05 PM |
| Lithium powered Terry 14+ minutes at full throttle. | craig2k | Electric Plane Talk | 9 | Jul 02, 2002 07:33 PM |
| QC830's with Stock TM at full throttle? | coggy | Parkflyers | 2 | Apr 17, 2002 04:28 PM |
| ZAGI 400-X ; power cutting out to motor after flying at full throttle | Joe-z | Foamies (Kits) | 29 | Jul 15, 2001 11:51 PM |
