Old Sep 13, 2009, 10:19 PM
sbmon is offline
Find More Posts by sbmon
Joined Aug 2004
Help!
what balance adapter (hyperion 6s battery needs to balance on tp210)
I need to figure out which balance adapter will work for me. I am getting some hyperion 6s vx 2600mah batteries and I need to be able to balance these on my TP 1010/210 charger/balancer.
Thank you for any help
shawn
sbmon is offline Find More Posts by sbmon
Old Sep 13, 2009, 10:43 PM
everydayflyer is online now
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Max. number of cells per connector if 5 for the 210 so you will have to use two maleTP balancing pigtails to a single Hyp. 6S (7 pin) female.
Will be same as this 7S example wiring wise minus one lead.
http://www.rcgroups.com/forums/showp...2&postcount=35
210 wiring for many cell combos
http://www.rcgroups.com/forums/showa...hmentid=567086
Charles
everydayflyer is online now Find More Posts by everydayflyer
Old Sep 13, 2009, 10:59 PM
sbmon is offline
Joined Aug 2004
Thank you for the help.
I am familiar with the way the 210 deals with 6s packs (by using both ports on bank 1). Unfortunately I am having trouble sourcing a premade adapter plug or board. That would take the hyperion style plug and adapt that into the two TP style plugs that I need to fit both of the open banks on the 210 charger. I do have another adapter that did just this but it was for an align 6s lipo that had 1 balance plug that was then adapted to the two plugs needed for the 210. Is there any chance that the align balance plug is the same as the hyperion?
Thank you
shawn
I have tried the search function for this information and could not seem to find a simple solution so any help is very greatly appreciated.
Old Sep 14, 2009, 06:14 AM
Southern Pride
Cheapbatterypacks.com has both the TP Male pitails ,ones that plug into balancer and the Female Hyp./PG pigtails,one that match Hyp.male pigtails on the Hyp. LiPolys.
This is a very,very old post of mine that answers most every question on balancing and adapters including many sources. GFuess the Search missed it.
http://www.rcgroups.com/forums/showp...0&postcount=29
Charles
Old Sep 14, 2009, 07:54 AM
Ron101 is offline
Find More Posts by Ron101
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
I'm looking for the same info.... 6s hyperion to TP
were getting close here charles.. you have all the parts we need at cheapbatterypacks.com
but need a diagram for what color goes to what on those connectors
I'm slow charles..lol.. I have to be spoon fed this stuff
maybe if I buy the leads and post pictures you could help with what color to what?
that would really help me out
Ron
Ron101 is offline Find More Posts by Ron101
Old Sep 14, 2009, 09:25 AM
Hughes500Bob is offline
Find More Posts by Hughes500Bob
Retired CFI Helicopter
Hughes500Bob's Avatar
Southeast PA
Joined Jun 2007
Finding an HP-EOSLBA-MC-A6 is like finding hen's teeth.
Australia = http://www.airstrike.com.au/Hyperion%20Chargers.htm
Is the only place I know of. I'd think it a lot easier to re-wire the tap with TP connectors which can be bought at rclipos.com or rcaccessories.com with free shipping.
Hughes500Bob is offline Find More Posts by Hughes500Bob
Old Sep 14, 2009, 08:09 PM
Southern Pride
Ron
same link as posted befor and same comments. this is fro a 7S ,6S will be same with just one less lead used.
Old Sep 15, 2009, 12:49 PM
Southeast PA
Joined Jun 2007
Finally found it while placing an order.
rclipos.com has a PQ-TP-6S for $5.99 that converts Polyquest/Hyperion 6S to Thunder Power 6S.
Discussion NEU 6S battery adapter for V-balancer? hereagain Batteries and Chargers 5 Jun 17, 2009 09:18 AM
Discussion TP 210 balancer adapter for 6s Zippy Battery crocket Batteries and Chargers 4 Jan 08, 2009 09:24 PM
Help! Thunder Power Balance Plugs to Astro Blinky Adapter for 6s Lipo graupman Power Systems 0 Mar 09, 2007 10:05 AM
Discussion Help with balance adapter Hyperion LBA6 to Common Sense 4s Tommy D Batteries and Chargers 5 Jul 24, 2006 10:32 AM
Progress...Battery Needs Flying Low Foamies (Kits) 3 Jun 27, 2001 12:58 AM
