Old Sep 13, 2009, 05:47 PM
kdill2160 is offline
Find More Posts by kdill2160
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
Mini-HowTo
Rebuilding the E-Flite Blade mSR Rotor Head...
So, I took my E-Flite Blade mSR out to my girlfriends house to fly it in the back yard, had a minor accident and broke one of the blade grips, when it came apart the small shims were lost...
I picked up the necessary parts for a complete head rebuild and thought I'd photograph the rebuild and share with everyone here...
Ken
kdill2160 is offline Find More Posts by kdill2160
Old Sep 13, 2009, 05:54 PM
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
Prep the chassis...
After removing the complete rotor head, main gear and main shaft I cleaned the heli and main board with some dust off, I also cleaned the main shaft bearings and swash bearing, I then applied a small bit of Tri-flow to the bearings...
The main shaft comes packaged with the shaft collar and screws, the collar is already installed...
Old Sep 13, 2009, 06:10 PM
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
Install the swashplate on the mainshaft...
Install the swashplate on the main shaft, then slide the Anti-rotation collar onto the mainshaft and secure in place with the correct screw...
Old Sep 13, 2009, 06:20 PM
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
Install the Flybar...
Next step is to install the flybar, I am running my linkages on the longer arms, the links go from the swash through the anti-rotation collar then the two link balls in the center of the flybar...
Old Sep 13, 2009, 06:39 PM
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
Install the Main Rotor Hub...
Install the main rotor hub as shown in the photos, secure in place with the proper screw...
Old Sep 13, 2009, 07:02 PM
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
Install the feathering shaft...
Next step is to install the dampeners, feathering shaft and shims...
Place one dampener in each side of the Main Rotor Hub... Next, insert the feathering shaft through the dampeners... Finally place one shim on either side of the feathering shaft...
Old Sep 13, 2009, 07:14 PM
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
Install the blade grips...
If you don't have a clamp like this all I can say is; Get one...
Place one blade grip on the Feathering Shaft on either side of the Main Rotor Hub, be certain the small shims stay in place...
Old Sep 13, 2009, 07:18 PM
vanman2004b is offline
Find More Posts by vanman2004b
Tennesee
Joined Feb 2007
As always your "build" threads are great.
vanman2004b is offline Find More Posts by vanman2004b
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
For beefier jobs...
Here's another clamp I use in building helis...
Solid steel, a heavy lil bugger...
Edit: Thanks Vanman... LTNS Big guy...
Old Sep 13, 2009, 07:20 PM
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
The screws used to secure the blade grips to each other are different than others on the mSR, they are a bit shorter than those used on the main shaft...
Old Sep 13, 2009, 07:43 PM
EQMOD is offline
Find More Posts by EQMOD
EQMOD's Avatar
Joined Mar 2008
nice build details here
Not related to the build procedure. I see a minor potential issue on the flybar ring design. Its not secured to the shaft ? And only the shaft phasing arms (above and below) are the keeping the flybar in phase ? My take is that the flybar will temporarily bind with the ball links (temporarily losing gyroscopic function) at sudden throttle speed changes.
EQMOD is offline Find More Posts by EQMOD
Old Sep 13, 2009, 07:52 PM
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
Blade grips installed...
Next, install the flybar to blade grip links...
Old Sep 13, 2009, 07:55 PM
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
I've noticed a couple strange things(the bevel in the flybar center seems to be on the wrong side), but the way it flys I am not going to question or complain...
We had a perfect day here today, almost no wind at all, my GF has a great backyard to fly in, no trees and perfect rectangle, I finally got to see how fast this lil heli is, I am impressed with its performance...
Ken
Old Sep 13, 2009, 08:02 PM
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
The complete rotor head...
Here's a photo of the completed Rotor Head/Main Shaft assembly...
Next, I need to install it in the chassis and install the main gear...
Old Sep 13, 2009, 08:18 PM
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
Into the Main Frame...
Pretty straight forward, slip the main shaft through the two main bearings, make sure the anti-rotation pin on the swash is in between the guide pins, connect the servo links...
Sold E-Flite Blade MSR BNF PatternFlyer Aircraft - Electric - Helis (FS/W) 4 Sep 01, 2009 01:39 PM
Discussion Question regarding E-Flite Aluminum lower rotor head drh Coaxial Helicopters 3 Mar 27, 2008 03:01 AM
Sold E-Flite Blade CP w/All Metal Head & extras Jinxx Aircraft - Electric - Helis (FS/W) 2 Nov 29, 2006 06:55 PM
Question E-Flite Blade CP rotor blade questions ... baratta930 Micro Helis 3 Jun 27, 2005 09:33 AM
