Old Sep 13, 2009, 12:34 AM
GunnyGlow is offline
Find More Posts by GunnyGlow
piro-maniac........
GunnyGlow's Avatar
United States, CO, Aurora
Joined Dec 2007
Question
Rhino battery balance tap question.
I use a triton2/equinox charging setup.....and I have adapters to fit Thunder Power packs. I don't have an adapter to go from the new Rhino's to the eqionox. Not sure what the "name" of the balance tap I NEED is....or what you call the rhino job. BUT....I don't wanna charge w/o balancing these new batts.
Can't all the battery connectors out there just get along!?!
Battery in question...
GunnyGlow is offline Find More Posts by GunnyGlow
Old Sep 13, 2009, 01:02 AM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Nearly all China sourced lipolys use JST-XH taps. Assuming you already have a 4S Female Polyquest adapter that fits your Equinox, you need a 4S Female JST-XH to Male Polyquest.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Sep 13, 2009, 09:37 AM
piro-maniac........
GunnyGlow's Avatar
Joined Dec 2007
Mark
Of course I need something else from there. :
Thanks a ton for the linky!!
Old Sep 13, 2009, 09:38 AM
piro-maniac........
GunnyGlow's Avatar
Joined Dec 2007
I found this....
http://www.rcaccessory.com/pdf/Batte...on%20Guide.pdf
from what I can tell on that spreadsheet.....the Align/JST is the same as the Rhino?? Thats not the case here in Gunnison. Or am I just not "getting it"?
Is it possible to buy the actual balance tap plug from somewhere and switching over the tap on the battery? Rather than using an adapter?
EDIT: I started a wanted thread. Hopefully I'll get some help.
Old Sep 13, 2009, 10:55 AM
joey1117 is offline
Find More Posts by joey1117
joey1117
Dayton Intl, Ohio, United States
Joined Sep 2004
wrong post
joey1117 is offline Find More Posts by joey1117
Old Sep 13, 2009, 10:57 AM
KC is offline
KC
Find More Posts by KC
KC
Registered Loiterer.
KC's Avatar
United States, FL, Orlando
Joined Sep 2006
If Polyquest male balance lead is what you need, have a look at this one.
http://www.rcaccessory.com/index.asp...ROD&ProdID=185
All balance lead that are available.
http://www.rcaccessory.com/index.asp...gory=57&Page=1
KC
KC is offline Find More Posts by KC
Old Sep 13, 2009, 11:07 AM
joey1117 is offline
joey1117
Joined Sep 2004
http://www.electrifly.com/chargers/g...0-inseta-2.jpg
Old Sep 13, 2009, 02:04 PM
So. Cal.
Yes. Align / JST-XH are synonymous. JST is a connector manufacturer. Their XH connector is the most widely used balance tap and is ubiquitous in nearly all packs sourced from China, including Rhino.
RCAccessory's battery tap configuration guide is an excellent resource and is very accurate. Only update that I'm aware of that isn't included in this guide is that Impulse switched from Polyquest to Thunder Power taps a few years ago.
Mark
Old Sep 13, 2009, 02:05 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
The equinox balancer should come with JST-XH connectors, unless I missed something
Xpress.. is offline Find More Posts by Xpress..
Old Sep 13, 2009, 02:06 PM
piro-maniac........
GunnyGlow's Avatar
Joined Dec 2007
Mark
Forgive me if I"m being thickheaded....but wouldn't that mean that my Rhino SHOULD attach to my equinox with no trouble?? Cuz...thats not the case.
Old Sep 13, 2009, 02:36 PM
So. Cal.
I don't own an Equinox but assumed (perhaps incorrectly) that it came with the same connectors as the Hyperion LBA6 which is identical to the Equinox. The LBA6 came standard with Hyperion/Polyquest adapters which is why made the recommendation found in post #2 above. It would seem odd to me if the Equinox were equipped with different connectors than its Hyperion brother.
Perhaps others who own an Equinox can comment? Alternately, if you can post a photo of the 4S adapter that came with your Equinox this puzzle can be solved with certainty.
Mark
Old Sep 13, 2009, 02:41 PM
piro-maniac........
GunnyGlow's Avatar
Joined Dec 2007
appreciate the help. I'd like to be able to grasp what is going on with this stuff....but it is all different.
link to post...not sure that pic worked.
http://www.rcgroups.com/forums/showp...7&postcount=13
Old Sep 13, 2009, 02:58 PM
KC is offline
KC
KC
KC's Avatar
Joined Sep 2006
KC
Old Sep 13, 2009, 03:01 PM
piro-maniac........
GunnyGlow's Avatar
Joined Dec 2007
nice....
Thanks!
Old Sep 13, 2009, 03:03 PM
piro-maniac........
GunnyGlow's Avatar
Joined Dec 2007
Somebody is missing something....I think its me.
I've only ever ran into align/jst and Thunder Power balance tap connectors. I got some adapters from horizon a long time ago to deal with the difference in Align and Thunder power.
Nothing I have works. Hopefully I have something coming that will help me out. If not...I"m gonna hack up some connectors as explained to me by another member. But I'd much prefer to either solder on new ones or use a nice little adapter.
Data Battery Balance Tap Configuration Guide by Battery Brand RC Accessory Batteries and Chargers 5 Aug 01, 2009 06:16 AM
Question Elite 4800 Lipo...balance tap Question Bookstar75 Batteries and Chargers 1 Mar 27, 2009 12:52 PM
Help! lipo balance tap question Hal_The_Hacker Batteries and Chargers 14 Oct 14, 2008 06:02 PM
Discussion Balance tap question hellbentrodder Batteries and Chargers 2 Jan 25, 2007 11:16 PM
Discussion stryker c lipo and balance tap question Fatts Batteries and Chargers 1 Dec 14, 2006 12:19 AM
