Old Sep 12, 2009, 08:57 PM
yogiraw is offline
Find More Posts by yogiraw
It's the best day ever!
yogiraw's Avatar
Corte Madera (in Marin County, CA)
Build Log
Finch (20 inch my own design)
Hey I'm building a quick tiny build for aerobatic fun,
Airfoil: approximate, semi-symmetrical
Wing: 2 sheets of 1/16th balsa epoxy/CA wrapped over tapered balsa rod (1/4 inch in middle).
Fuse: sandwich of blue foam and balsa
Tail: Solid balsa v-tail
Nose: pointy
The idea here is doing everything precise except for airfoil, and to have a tiny plane that can go any where and fly in medium wind and have the quality to be very fun in big air too (just no going too far away as its tiny)
yogiraw is offline Find More Posts by yogiraw
Old Sep 12, 2009, 10:41 PM
b36roxs is offline
Find More Posts by b36roxs
Joined Sep 2006
Sounds cool, go 4 it
b36roxs is offline Find More Posts by b36roxs
Old Sep 13, 2009, 12:45 AM
Neil Walker is offline
Find More Posts by Neil Walker
Texas Ranger
Neil Walker's Avatar
USA, CA, San Francisco
Joined Aug 2004
Why not just make the airfoil approximately symmetrical?
Neil Walker is offline Find More Posts by Neil Walker
Old Sep 13, 2009, 02:48 AM
yogiraw is offline
yogiraw's Avatar
Well, effectively I did, but of course one sheet of balsa will tend to be slightly stiffer than the other. The stiffer on will be the one that is flatter (underside of the wing). But what I did was CA the spar to the underside wing first and then mocked it all up with epoxy and the top bent a little more. See pic.
Old Sep 15, 2009, 08:15 AM
Marcos Quito is offline
Find More Posts by Marcos Quito
Plank addicted
Marcos Quito's Avatar
Sao Paulo - Brazil
Joined Jan 2007
Sorry to say, but this will be for very strong winds, and not "medium winds", unless you´re taking very very special care on the weight.
- Do you have a weight target ?
Marcos Quito is offline Find More Posts by Marcos Quito
Old Sep 15, 2009, 12:08 PM
theBOZman is offline
Find More Posts by theBOZman
__Jackass Savant__
theBOZman's Avatar
United States, CA, Oxnard
Joined Feb 2005
How close are you to your CG with the servo in the tail like that???
fyi:
Since the tail servos distance is farther from the CG than the nose, you'll need ALOT more lead in the nose then the weight of the servo to counter for it.
theBOZman is offline Find More Posts by theBOZman
Old Sep 17, 2009, 05:11 AM
yogiraw is offline
yogiraw's Avatar
fyi:
Or would more metal rod be worse having the servo closer to front?
Taking special care. Yes, it wing loading will be high afterall. I will do the calculations soon and post AUW, how much lead is in the nose, and wing loading. Just must finish the tail feathers fist.
btw, I'm thinking of calling this little one the finch. Name taken by a glider yet?
Old Sep 17, 2009, 07:14 AM
TweakRacer is offline
Find More Posts by TweakRacer
TweakRacer's Avatar
United States, CA, Orange County
Joined Jan 2006
Looks good! How'd you finish the plane? WBPU? Laminating film?
TweakRacer is offline Find More Posts by TweakRacer
Old Sep 17, 2009, 04:13 PM
yogiraw is offline
yogiraw's Avatar
No, no, much higher class than those: zagi tape.
Probably a year later I will take off all the tape, give it a good sand and redo it in a kote or paint.
Old Sep 17, 2009, 05:04 PM
__Jackass Savant__
theBOZman's Avatar
Joined Feb 2005
A flexible push rod and sleeve would add way less weight than the servo would. EVEN IF the rod weighed as much as the servo, the weight of the rod is distributed along the moment arm of the tail. With the servo, ALL it's weight is focused in one spot WAY far out from the CG.
Old Sep 18, 2009, 12:58 AM
yogiraw is offline
yogiraw's Avatar
My next tiny plane will be designed to have room for that, using maybe a carbon thin rod. Thanks!
Old Sep 18, 2009, 05:17 AM
yogiraw is offline
yogiraw's Avatar
AUW: 7 oz
0.7 oz of lead added to nose
Wing area: 63 square inches (.4375 sq ft)
Wing loading: 16oz/sq ft!!!
Will wait for very windy day then?
Old Sep 18, 2009, 07:31 AM
Antonsoarer is offline
Find More Posts by Antonsoarer
Long to be flyin'
Antonsoarer's Avatar
Wirral, (UK)
Joined Dec 2003
The lightest elevator system is closed-loop, I have done it on v-tails and it worked fine, makes a great sound if the wires are out in the breeze!
Antonsoarer is offline Find More Posts by Antonsoarer
Old Sep 18, 2009, 04:13 PM
yogiraw is offline
yogiraw's Avatar
Yes, the plane could have been ever more stealthier, but hey, its going to rip the skies anyways and scream!
Contest Fun Build II Guillow's Cherokee, 20 inch plan build Konrad Scale Kit/Scratch Built 96 Jun 20, 2011 10:04 PM
Build Log Opus … 100g (3.5 oz) 20-inch quick build delta ... Video & Plans post 2 chaosMurphy Foamies (Scratchbuilt) 113 Jun 25, 2008 02:30 AM
New Product 20~25C lipoly battery will coming soon epower model Batteries and Chargers 67 Jan 18, 2006 09:26 AM
New 24 inch wing with GWS 300 Motor (scratch build) Qrome Flying Wings 15 Sep 24, 2005 04:23 PM
ANT-20 scratch build - what mods should be done? Martin Hunter Scale Kit/Scratch Built 14 Jan 31, 2005 07:24 PM
