Old Dec 05, 2009, 05:33 PM
RC4x4 is offline
Find More Posts by RC4x4
Fly Low or you'll never know!
RC4x4's Avatar
Thornton, Colorado
Joined Jul 2002
Congrats Doc on your maiden. Looked good. Nice weather!
Let us know what you think about that new Torque motor.
Cory
RC4x4 is offline Find More Posts by RC4x4
Old Dec 05, 2009, 05:35 PM
Doc Austin is online now
Find More Posts by Doc Austin
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Cory
Uhhhh, thanks, but that was the maiden of the first one. The new one hasn't flown yet. We are socked in really good today so it probably won't be until tomorrow afternoon.
Doc Austin is online now Find More Posts by Doc Austin
Old Dec 05, 2009, 09:13 PM
Steve Graham is offline
Find More Posts by Steve Graham
AMA L897187
Steve Graham's Avatar
NE Denver, CO
Joined Sep 2007
Thanks Doc,
Gotta steal Scotts book back from the guy I loaned it to It seems that once your off the wing and on the prop a frame of reference in FS is counter-intuitive. For some reason no book I ever read on aerodynamics gives any tips on post stall maneuvering. Its all great fun to learn though. I have been through your blog before. It is a great reference.
Steve
Steve Graham is offline Find More Posts by Steve Graham
Old Dec 05, 2009, 09:30 PM
routemech is offline
Find More Posts by routemech
shredding Ultracote since 2009
routemech's Avatar
Frederick CO
Joined Jul 2009
Originally Posted by flyinhigh025 View Post
Time to install pushrod connectors onto the servo arms, and thread the ball links onto the pushrods.
This is a set-up I have used on -6- different 3DHS planes, and it has proven to be solid, accurate and reliable. Not a single failure.
Note: You will notice the pushrod connector nuts have two different sides. Make sure the side with the small but pronounced countersink is exposed.
Double Note: Notice the elevator pushrod has a carbon fiber tube for reinforcement. Nice touch!!
-Jeff
Jeff,
What hole did you use in your Dubro servo arms? In your photo you have everything at the bottom, what this your final position?
In the manual the elevator arm is 3rd or 2nd from the bottom on the long arm (Hard to tell from photo)?
routemech is offline Find More Posts by routemech
Old Dec 06, 2009, 12:29 PM
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
That little countersunk area makes a great little pool for the CA to run into and get a bite on the threads.
Old Dec 06, 2009, 12:30 PM
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Originally Posted by routemech View Post
Jeff,
The latest blog article has all my set up photos. The only difference is that since then I have moved the aileron pushrod out one hole at the servo arm.
Old Dec 06, 2009, 12:44 PM
routemech's Avatar
Frederick CO
Joined Jul 2009
I noticed IPS motors was using different size arms from what Jeff used - so I was trying to determine the best setup! Thanks Doc I will go look at your photos...
Old Dec 06, 2009, 02:36 PM
Dennis C is offline
Find More Posts by Dennis C
Dennis C's Avatar
Grass Valley California
Joined Jun 2004
[but that's ok...if you want to be in touch with your feminine side with the yellow, it's okay by me...
SteveT[/QUOTE]
Go ahead mess with my yellow airplane, MAKE MY DAY!!
Out flying my yellow biplane yesterday and had a great time, It is yellow red and blue, does that make me confused?
Dennis
Dennis C is offline Find More Posts by Dennis C
Old Dec 06, 2009, 02:38 PM
Dennis C is offline
Dennis C's Avatar
Joined Jun 2004
Installed the power 32 and did a power run up, right at 900 watts on 4s 4000. I guess that will be adequate
Dennis
Old Dec 06, 2009, 02:45 PM
Dennis C is offline
Dennis C's Avatar
Joined Jun 2004
Mike[/QUOTE]
To get the most effecient servo set up:
Set the end point adjustment in the transmitter to 140%
install the push rod to the contro horn on airplane (the extra 330 only has one hole)
Use the hole on the servo arm closest to the center that will give you the desired throw in high rate.
This will give you the best resolution and servo power
Dennis
Old Dec 06, 2009, 06:09 PM
flyinhigh025 is offline
Find More Posts by flyinhigh025
How can we stop winter?
flyinhigh025's Avatar
Frederick, CO
Joined Sep 2005
Jeff,
Mike,
E-mail sent. I did use the outer holes on the arms for full 3D throws.
-Jeff
flyinhigh025 is offline Find More Posts by flyinhigh025
Old Dec 06, 2009, 11:44 PM
Lonelasso is offline
Find More Posts by Lonelasso
Lonelasso's Avatar
United States, TX, Austin
Joined Dec 2006
FrankenSHP/Sc Vid
Shot this today...nuttin hair raising, still shaking 'er down
FrankenSHP/Sc @ TT ! (3 min 23 sec)
Lonelasso is offline Find More Posts by Lonelasso
Old Dec 06, 2009, 11:46 PM
blucor basher is online now
Find More Posts by blucor basher
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
United States, TX, Tyler
Joined Jun 2003
Exactly.
blucor basher is online now Find More Posts by blucor basher
Old Dec 07, 2009, 12:22 AM
routemech's Avatar
Frederick CO
Joined Jul 2009
Dup
routemech's Avatar
Frederick CO
Joined Jul 2009
mike,
e-mail sent. I did use the outer holes on the arms for full 3d throws.
-jeff
thanks!!!
New Product 3D Hobby Shop 47" Edge 540 #BUILD VIDEOS ADDED# ipsmotors 3D Flying 3960 Nov 23, 2013 08:39 PM
Video 3D Hobby Shop 57" Sukhoi sukhoi26mx Electric Plane Talk 7 Sep 17, 2008 09:33 AM
Sold NIB 3D Hobby Shop SHP Extra 300 *Blue* Version 2 thomer Aircraft - Electric - Airplanes (FS/W) 7 May 04, 2008 02:31 PM
Build Log 3D Hobby Shop 55" Katana LIVE Build Log Jeremy Sebens 3D Flying 54 Oct 12, 2007 04:39 PM
