Vertical upline Tumble - right stick upper right corner, left stick lower left corner Catch the plane in the proper orientation. Wait for it to get parallel with nose pointing right. Then full left rudder and high throttle (at first... You can back off later but you need some throttle to "catch the plane") and right stick at 12 o'clock. From here you will need to hold full down elevator and then find the sweet spot for ailerons. Some planes like a little right aileron, some need left and some like neutral ailerons. Timing is key while catching the plane. Let me know how this works for you. My explanation probably isn't great so if you have questions just ask. |
I went with the standard mount on my latest build and really like it. It allows me to put the batteries a little further back in the tray which makes it a heck of a lot easier to strap them in. And I haven't noticed any weight penalty at all with this setup.
The only issue I ran into was I had to use two washers on each mount hole to pull the motor off the firewall just a hair so that the retaining collar wouldn't rub. |
| Thread Tools | |
| New Product 3D Hobby Shop 47" Edge 540 #BUILD VIDEOS ADDED# | ipsmotors | 3D Flying | 3959 | Dec 05, 2012 09:57 PM |
| Video 3D Hobby Shop 57" Sukhoi | sukhoi26mx | Electric Plane Talk | 7 | Sep 17, 2008 08:33 AM |
| Sold NIB 3D Hobby Shop SHP Extra 300 *Blue* Version 2 | thomer | Aircraft - Electric - Airplanes (FS/W) | 7 | May 04, 2008 01:31 PM |
| Build Log 3D Hobby Shop 55" Katana LIVE Build Log | Jeremy Sebens | 3D Flying | 54 | Oct 12, 2007 03:39 PM |
