Old Feb 13, 2013, 12:11 PM
DenverJayhawk is online now
Find More Posts by DenverJayhawk
Epoxy & CA Investor
DenverJayhawk's Avatar
United States, CO, Denver
Joined May 2010
Originally Posted by Bigster View Post
I finally got my 4315-714 bolted up with a 15x6 Xoar and the ICE was claiming ~80A peak (with a storage charged battery). I didn't have the connectors for my wattmeter yet, but holy cow, it nearly dragged me across the room!
Yeah. You'll love this. It's like a sling shot on takeoff. Kind of stupid vertical power, really.
DenverJayhawk is online now Find More Posts by DenverJayhawk
Old Feb 13, 2013, 12:12 PM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Originally Posted by DenverJayhawk View Post
sounds low on the amp draw with that setup. I'm closer to 90amps with the same setup but a 15x10 prop.
Your 15x10 prop numbers make sense. I think with a 15x8 you'd get around 80-85.
turnerm is offline Find More Posts by turnerm
turnerm is offline
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Stupid indeed but MAN I love it.
Old Feb 13, 2013, 12:13 PM
timlake is offline
Find More Posts by timlake
Joined Apr 2012
i wouldn't trust a 75 amp esc with that motor on 4S. You'll definitely peak over 75amps given my experience with similar equipment.
A few people have been telling me that, but the data I'm getting isn't confirming it. I have a buddy I fly with who has the same setup, and his results are very similar to mine. I'll probably swap to a 100 just to be safe though.
timlake is offline Find More Posts by timlake
Epoxy & CA Investor
Joined May 2010
that makes sense. I should try a 15x8 sometime. I propped up for the elevation where i fly, which is generally about 5300-6000 ft.
Old Feb 13, 2013, 12:15 PM
Epoxy & CA Investor
Joined May 2010
well, if your watt meter is telling you that, then give it a go. You should be safe in theory.
Old Feb 13, 2013, 12:16 PM
timlake is offline
Joined Apr 2012
maybe your throttle end points in the radio are limiting the range?
I've never messed with that... Are the default settings not good?
Old Feb 13, 2013, 12:21 PM
Letzrock is offline
Find More Posts by Letzrock
Yard Dart
Letzrock's Avatar
United States, TN, Woodbury
Joined Aug 2012
At WOT you should see a red light flicker on your ESC. The red light indicates full throttle has been reached by the ESC. I dont believe you can change much on your throttle with a DX6.
Letzrock is offline Find More Posts by Letzrock
Old Feb 13, 2013, 12:22 PM
turnerm is offline
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
If you're not pulling too many amps with the 15x10 then I'd just stick with that. I'm guessing you might be disappointed with the 15x8 at your altitude.
Old Feb 13, 2013, 12:31 PM
timlake is offline
Joined Apr 2012
I think the logged data also shows a "100" in the "power out" column when the ESC registers full throttle. Am I reading that right?
I'm also noticing a temporary 3v dip in voltage when I go from 0 to 100 on the throttle. Is this normal, or is my battery about to become a paperweight?
Old Feb 13, 2013, 12:39 PM
Epoxy & CA Investor
Joined May 2010
my radio had them defaulted at 100 and 100. I generally change the end points using Castle's instructions.
Old Feb 13, 2013, 12:51 PM
turnerm is offline
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
+1. Setup fixed end points per their instructions.
Old Feb 13, 2013, 01:51 PM
Letzrock is offline
Yard Dart
Letzrock's Avatar
Joined Aug 2012
A higher c rated battery helps this
Old Feb 13, 2013, 03:47 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Wow... I wonder why I'm getting such different results? What kind of battery are you using?
A larger ESC will usually give you more power due to it having a lower internal resistance, and also, they usually have larger wires, so again lower resistance...
SteveT.
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Feb 13, 2013, 03:50 PM
SteveT.'s Avatar
San Jose, CA
He has end point adjustment, and that is what is needed to set up fixed end points. And yes, Fixed end points usually works best...
SteveT.
New Product 3D Hobby Shop 47" Edge 540 #BUILD VIDEOS ADDED# ipsmotors 3D Flying 3960 Nov 23, 2013 08:39 PM
Video 3D Hobby Shop 57" Sukhoi sukhoi26mx Electric Plane Talk 7 Sep 17, 2008 09:33 AM
Sold NIB 3D Hobby Shop SHP Extra 300 *Blue* Version 2 thomer Aircraft - Electric - Airplanes (FS/W) 7 May 04, 2008 02:31 PM
Build Log 3D Hobby Shop 55" Katana LIVE Build Log Jeremy Sebens 3D Flying 54 Oct 12, 2007 04:39 PM
