Old Jan 23, 2013, 10:03 AM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Originally Posted by kalmon View Post
Same for me as DenverJayhawk mentioned, it feels very tough to get locked in. especially in yaw. I think Turnerm mentioned that it felt like he had to have it tipped past vertical a bit to get it to hover right. I have analog HS225mgs all around in mine and that might contribute to the difficulty. I also have that 15x8 turning at a lower than optimal rpm so there is another strike. I can hover the plane I just don't feel comfortable with it, and I never try it down low.
-Brian
Yea... for me, it does seem like I have to pull it past vertical a little to get it locked in. It also helps to enter with a little right rudder as it always wants to pull left on me. And unlike many of my other planes, it doesn't stay locked into a hover very well. You have to babysit it the whole time.
But outside of that it's a fantastic plane.
turnerm is offline Find More Posts by turnerm
Old Jan 23, 2013, 12:46 PM
jimmyg79 is offline
Find More Posts by jimmyg79
United States, MI, Macomb
Joined Jan 2010
I guess I found this thread a little late. I just got this plane last week and going off of 3DHS recommendations I ordered the Hacker A40-12S. I just got the motor today and it does look a little small for this plane. I didn't realize it's physical size is actually smaller than the 32 Rimfire I have in a 50" GP Extra. I'm not quite sure I made the right choice here...
jimmyg79 is offline Find More Posts by jimmyg79
Old Jan 23, 2013, 12:50 PM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
the a40-12s will work great. its not an over powered motor, but for 3D flight it is light weight and more than enough. 3DHS doesnt recommend equipment for no reason. its not a sport setup, i.e. its not going to give you rediculous ballistic performance, but it is reliable, adequate power, light weight, and will swing the correct prop (depending on your battery selection)
rcbirk21 is offline Find More Posts by rcbirk21
Old Jan 23, 2013, 01:02 PM
jimmyg79 is offline
Joined Jan 2010
I'm going to be running this setup with 30c 4000mah 4s sky lipos. I was thinking a 15x6 for the prop.
Old Jan 23, 2013, 01:47 PM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
It will be pretty slow with a 6" pitch prop on a 610kv motor on 4S. I use ThunderPower 3900mAh 4S packs on mine with the A40-12s with a 15x8 prop. It is only drawing 60ish amps and 850watts, and that is with the 15x8! on the 15x6 it'll only be around 50amps and 600watts. That is really low!!! If you get a 15x8 the plane will fly really well, decent power, decent speed. FYI people using 4S and the 15x7 on the 4315-714 have been reporting 1100-1200watts and 80+ amps.
-Brian
kalmon is offline Find More Posts by kalmon
Old Jan 23, 2013, 02:11 PM
3Daddict is offline
Find More Posts by 3Daddict
Addicted to 3DHS and EF
3Daddict's Avatar
United States, FL, Bonita Springs
Joined Oct 2010
-Brian
How would you measure your wattage? is there a device to do this with?
3Daddict is offline Find More Posts by 3Daddict
Old Jan 23, 2013, 02:13 PM
jimmyg79 is offline
Joined Jan 2010
Thanks for the input. I'll slap a 15x8 on it and go from there. I'm looking forward to getting this one airborne!
Old Jan 23, 2013, 03:04 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Watts Up meter... Or logging if using a Castle ESC (just keep the sampling rate low), or an Eagle Tree system... many ways...
SteveT.
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jan 23, 2013, 05:51 PM
DenverJayhawk is offline
Find More Posts by DenverJayhawk
United States, CO, Denver
Joined May 2010
-Brian
1274watts static with gens ace 4s 4000 with about 50% left in the batt
DenverJayhawk is offline Find More Posts by DenverJayhawk
Old Jan 27, 2013, 09:40 AM
Mr Big Head is offline
Find More Posts by Mr Big Head
Mr Big Head's Avatar
United States, CA, Redding
Joined Feb 2011
A40-12S is a.n awesome motor with a 15x7......on 5 cells
Mr Big Head is offline Find More Posts by Mr Big Head
Old Jan 27, 2013, 04:20 PM
Alex Schauer is offline
Find More Posts by Alex Schauer
Alex Schauer's Avatar
United States, MN, North Mankato
Joined Feb 2011
Would a Talon 90, APC 15x8 (or a Xoar 15x7) and Motrlfly 4315 714kv on 4s be alright?
Alex Schauer is offline Find More Posts by Alex Schauer
Old Jan 27, 2013, 04:24 PM
Joined Feb 2011
I mean a Xoar 15x8 PJN
Old Jan 27, 2013, 06:05 PM
3Daddict is offline
3Daddict's Avatar
Joined Oct 2010
should be, that is what I ordered for mine. And I based that off of what everyone else was using.
Old Jan 28, 2013, 03:17 PM
GetSome! is offline
Find More Posts by GetSome!
GetSome!'s Avatar
United States, CA, Roseville
Joined Jan 2011
Does anyone have a spare yellow and blue right wing they are willing to part with? My aileron exploded on a blender...it would be most appreciated cause 3dhs is out of stock....
Feel free to PM me what you want for it, Thanks in advance!
GetSome! is offline Find More Posts by GetSome!
Old Jan 30, 2013, 01:52 PM
ThreeDwannabe is offline
Find More Posts by ThreeDwannabe
United States, CA, San Jose
Joined Jan 2010
I was so happy to land my extra nicely after the successful maiden flight the weekend before last....so happy that I got excited and hit the fence while taxiing and broke the Falcon 15x7. Anyway, I bought 15x8 APC that's not fitting (too small) to go over the prop adaptor of my motrofly!! I thought the adapters are standard or at least small enough to go through the props...use washers for smaller holes on the props...anyway, What do you suggest? I dont want to enlarge the hole in the prop. I think that will mess up its balance. I think I should go with wood props again.
thanks.
ThreeDwannabe is offline Find More Posts by ThreeDwannabe
New Product 3D Hobby Shop 47" Edge 540 #BUILD VIDEOS ADDED# ipsmotors 3D Flying 3960 Nov 23, 2013 07:39 PM
Video 3D Hobby Shop 57" Sukhoi sukhoi26mx Electric Plane Talk 7 Sep 17, 2008 08:33 AM
Sold NIB 3D Hobby Shop SHP Extra 300 *Blue* Version 2 thomer Aircraft - Electric - Airplanes (FS/W) 7 May 04, 2008 01:31 PM
Build Log 3D Hobby Shop 55" Katana LIVE Build Log Jeremy Sebens 3D Flying 54 Oct 12, 2007 03:39 PM
