Old Oct 17, 2012, 09:30 AM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Originally Posted by dth7 View Post
Hey, just curious where you all get para boards? I've been getting mine from Progressive RC. Thanks
I get mine from EPBuddy but Progressive RC is another good company for sure.
turnerm is offline Find More Posts by turnerm
Old Oct 17, 2012, 11:24 AM
3Daddict is offline
Find More Posts by 3Daddict
Addicted to 3DHS and EF
3Daddict's Avatar
United States, FL, Bonita Springs
Joined Oct 2010
Originally Posted by turnerm View Post
Ridiculously good combo there. I have it and couldn't be more thrilled.
Your the reason I got the motor. I just got my castle ice lite 100. All that leaves is the plane and servos and I will be in business. I will order them together from 3dhs. I am going with the HS-5245mg digital. I will order that sometime within the next two months and have the plane ready to fly for next year.
3Daddict is offline Find More Posts by 3Daddict
Old Oct 17, 2012, 11:26 AM
DenverJayhawk is offline
Find More Posts by DenverJayhawk
Epoxy & CA Investor
DenverJayhawk's Avatar
United States, CO, Denver
Joined May 2010
Yep. Exact setup i'm using except for a 15x10 prop. Can you say Bottlerocket?
DenverJayhawk is offline Find More Posts by DenverJayhawk
Old Oct 17, 2012, 11:31 AM
turnerm is offline
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
That thing must leave a vapor trail when you let it rip!!
Old Oct 17, 2012, 11:32 AM
turnerm is offline
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Well there you have it! You'll love it. Trust me on this. Be sure to set fixed end points instead of using auto calibration. I also needed to modify my throttle curve a little bit but once I got those two things dialed in it's been pure bliss ever since!!
Old Oct 17, 2012, 07:01 PM
heritageflyer is offline
Find More Posts by heritageflyer
Time to Fly AJ's Best!
heritageflyer's Avatar
Hills of Eastern Ohio
Joined Nov 2008
Motrolfly Rocket Motors are Fun......
heritageflyer is offline Find More Posts by heritageflyer
Old Oct 17, 2012, 07:13 PM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
? What is the diff between the -10s and -12s? Is it a lower kv? Not sure on all the motor codes yet. Thanks. I will go with the H a40-10s and swing a 14x7 or 15x7 I guess.
A40-10S is 750kv A40-12S is 610kv.
With the -10s you'll probably want to start with a 14x7. A 15x7 will put you over 1200watts
A -12s and a 15x8 put you just above 800 watts on 4S.
-Brian
kalmon is offline Find More Posts by kalmon
Old Oct 17, 2012, 10:13 PM
dth7 is offline
Find More Posts by dth7
Back in the hobby- ALL in!
dth7's Avatar
United States, NH, Greenland
Joined Feb 2012
-Brian
So, I'm a little confused. What is better for 80/20 3D/ Sport? I see recommendations for the 10s w 15x7? I will put it on a watt meter. I assume running too many watts will blow the motor. I have 14x7and a wooden 15x7 on the way. We'll see what my combo pulls. Thanks.
dth7 is offline Find More Posts by dth7
Old Oct 18, 2012, 03:58 AM
rimaarts is offline
Find More Posts by rimaarts
United Kingdom, London
Joined Jul 2011
technically, pulling too many amps will cook(not blow) the motor... i dont know how much watts you have to pull to blow motor...
my input against 10 vs 12... in summer, 12s gets freakishly hot for me, 4s 4000, and i pull around 60A at 800-900w... is you are used to 3:1 power ratio, dont buy that motor, you will not be happy, but other than that, power is adequate...
well if im cooking 6xxkv motor on 15x7, i have no wish to even try 7xxkv motor on the same size...
rimaarts is offline Find More Posts by rimaarts
Old Oct 19, 2012, 07:54 AM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
My A40-12S + APC-E 15x8 on 4S gets fairly warm bordering on hot in summer. Not to hot that I cant hold a finger on it for 10sec though. If you run the recommended A40-10S make sure you check those watts!! 14x7 will be 1000+. Give it time to cool between flights. If I had to do it over again I'd use the Motrolfly 4315-714. That motor is wider and shorter leading to less heat soak. The other option is to get some very light balsa or depron and make the cooling holes in the cowl on each side of the ducted to channel air over the motor.
-Brian
Old Oct 19, 2012, 03:37 PM
dth7 is offline
dth7's Avatar
Joined Feb 2012
Where are you guys flying in summer? I'm in New England so it's not crazy hot (90s max)! 3D doesn't have the Hacker -10s in stock right now. Is anyone running the motrolfly 4315-714 with an 80A esc? I have apc 14x7, master airscrew 14x8 and a pro tek 15x7. Curious what kind of Amps it will pull with a good 4s 2200-4000? Guessing 65+
Old Oct 19, 2012, 04:01 PM
Epoxy & CA Investor
Joined May 2010
80amp will be a little low for 4S. At least that is my experience with a 15" prop.
Old Oct 19, 2012, 04:02 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Aero-Model is the distributor for the Hacker Motors, and may have them in stock, That said, the Motrolfly is a much better motor power-wise, but at this time, Ken is out of stock on them also...
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Oct 19, 2012, 04:05 PM
Joined Nov 2008
I'm pulling 80-82A on a 15x7 Xoar on just a Zippy 4S 4000 20C.
ICE 100 Lite is a good choice for ESC for this one.
dth7 is offline
dth7's Avatar
Joined Feb 2012
You guys have bought all "my" motors! Snow is coming!
Ok. Don't really want another esc. Just bought the 80amp. Guess I'll wait on the hacker 10s to come in. 3 D said it should have the same thrust to weight that I have on my 48" edge and that's fine for me.
New Product 3D Hobby Shop 47" Edge 540 #BUILD VIDEOS ADDED# ipsmotors 3D Flying 3960 Nov 23, 2013 07:39 PM
Video 3D Hobby Shop 57" Sukhoi sukhoi26mx Electric Plane Talk 7 Sep 17, 2008 08:33 AM
Sold NIB 3D Hobby Shop SHP Extra 300 *Blue* Version 2 thomer Aircraft - Electric - Airplanes (FS/W) 7 May 04, 2008 01:31 PM
Build Log 3D Hobby Shop 55" Katana LIVE Build Log Jeremy Sebens 3D Flying 54 Oct 12, 2007 03:39 PM
