Old Sep 17, 2009, 11:06 PM
tjhawker is offline
Find More Posts by tjhawker
Tx
Joined Oct 2008
There will definitely be video of the maiden...from multiple angles...so it better be a good maiden....no pressure or nuthin Jeff.
Good tip on the nut, btw. Looks like that'd work pretty well.
tjhawker is offline Find More Posts by tjhawker
Old Sep 17, 2009, 11:26 PM
jadamian75 is offline
Find More Posts by jadamian75
jadamian75's Avatar
Fort Collins Colorado USA
Joined Oct 2007
Originally Posted by fall666
Jeff, if I may, I have started adding a nut to my pull pull's. See the attachments. The nut's main purpose is to let the builder make fine adjustments to the wire's tension. Too, they act as a backup if the adjustor's set screw were to become loose.
gb
That sounds like a really good idea.
Joe
jadamian75 is offline Find More Posts by jadamian75
Old Sep 17, 2009, 11:29 PM
jadamian75's Avatar
Joined Oct 2007
Sounds like you'll have a whole camera crew. Hopefully there should be at least 3 new 57" 330s thereon Saturday.
Old Sep 17, 2009, 11:37 PM
RC4x4 is offline
Find More Posts by RC4x4
Fly Low or you'll never know!
RC4x4's Avatar
Thornton, Colorado
Joined Jul 2002
Awesome Jeff. It's gonna be cool with 3 of these out at the field forsure.
Cory
RC4x4 is offline Find More Posts by RC4x4
Old Sep 17, 2009, 11:40 PM
fall666 is offline
Find More Posts by fall666
To me, every day is Saturday
fall666's Avatar
DAL/FTW
Joined Jul 2006
Nut for pull pull adjusting works great. If a wire's tension needs tweaking, you loosen the set screw, pull a little on the wire to give the nut some travel space, run the nut in or out, let off on the wire, tighten the set screw, and you are good to go.
gb
fall666 is offline Find More Posts by fall666
Old Sep 18, 2009, 12:02 AM
Doc Austin is offline
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Doc Austin is offline Find More Posts by Doc Austin
Old Sep 18, 2009, 07:40 AM
SonyVegasUser is offline
Find More Posts by SonyVegasUser
currently 3D-Dabbler
SonyVegasUser's Avatar
Richmond, VA
Joined Aug 2009
Originally Posted by flyinhigh025
Mike,
Very good! Be sure to report back to us when you finish the build and get the SC in the air.
What Lipos are you planning to run in the SC?
-Jeff
I am using the Reaper GR-45 and ordered the Rhino 3700mAh 4S 14.8v 25C. I have both 14x7 and 14x8 wooden and APC Electric props to play with as well to see if there is any difference in the way the plane flies.
http://hobbycity.com/hobbycity/store...idProduct=9338
They said the back order should be in at the end of September / beginning of October. I may have to break down and order a $150 pack (in stock) from another store that can get delivered more quickly. I would like to see it in the air much sooner than that.
SonyVegasUser is offline Find More Posts by SonyVegasUser
Old Sep 18, 2009, 07:41 AM
Richmond, VA
Joined Aug 2009
Hope we can soon look forward to a video of your plane's maiden.
gb
Interesting idea. I may try that.
Old Sep 18, 2009, 07:47 AM
flyinhigh025 is offline
Find More Posts by flyinhigh025
How can we stop winter?
flyinhigh025's Avatar
Frederick, CO
Joined Sep 2005
I second that, using a nut on the pull-pull is a GREAT idea.
And...
GREAT. My maiden flights are usually not so exciting. Take off, roll inverted, adjust CG, check knife edge...
hehe...
Jeff
flyinhigh025 is offline Find More Posts by flyinhigh025
Old Sep 18, 2009, 07:48 AM
Frederick, CO
Joined Sep 2005
How's your SC coming along Joe? Will you have it ready for a maiden Sat? We could fly a double maiden!
(that would take a little pressure off me... )
Jeff
Old Sep 18, 2009, 07:56 AM
Frederick, CO
Joined Sep 2005
Cory
Cory,
Your going to bring your ballistic 57" SC sat.?? Right?
-Jeff
Old Sep 18, 2009, 09:21 AM
RC4x4 is offline
RC4x4's Avatar
Thornton, Colorado
Joined Jul 2002
Cory,
-Jeff
You and Joe might a little more ballistic with the Reaper 45.
I may have to bolt on the Reaper 60 and hit it!
Cory
Old Sep 18, 2009, 01:40 PM
DalAv8r is offline
Find More Posts by DalAv8r
DalAv8r's Avatar
Peachtree City, GA
Joined Jun 2008
Is there any disadvantage to installing the aileron servos the other way. (output shaft closer to the aileron). It seems I get just a little bit more reach with the extension if I try it this way.
Scott
DalAv8r is offline Find More Posts by DalAv8r
Old Sep 18, 2009, 02:46 PM
RC4x4 is offline
RC4x4's Avatar
Thornton, Colorado
Joined Jul 2002
Receiver mounting
Originally Posted by MLT67
Jeff great build.. I'm right behind you - should start my wings tomorrow. I'll be intersted to see where you mount your RX...
MLT
Mike. If your using the lighter motor and 4s, you can mount it on the battery tray right at the wing tube.
Here's a picture.
Cory
Old Sep 18, 2009, 03:03 PM
GoldCraft is offline
Find More Posts by GoldCraft
GoldCraft's Avatar
United States, GA, Woodstock
Joined Jan 2007
Here's a picture.
Cory
Probably not a big deal, but I like to turn the RX the other way to get the antenna further from the carbon fiber wing tube on the light setup.
GoldCraft is offline Find More Posts by GoldCraft
New Product 3D Hobby Shop 47" Edge 540 #BUILD VIDEOS ADDED# ipsmotors 3D Flying 3960 Nov 23, 2013 07:39 PM
Video 3D Hobby Shop 57" Sukhoi sukhoi26mx Electric Plane Talk 7 Sep 17, 2008 08:33 AM
Sold NIB 3D Hobby Shop SHP Extra 300 *Blue* Version 2 thomer Aircraft - Electric - Airplanes (FS/W) 7 May 04, 2008 01:31 PM
Build Log 3D Hobby Shop 55" Katana LIVE Build Log Jeremy Sebens 3D Flying 54 Oct 12, 2007 03:39 PM
