Old Sep 08, 2012, 09:12 PM
edf_rookie is offline
Find More Posts by edf_rookie
edf_rookie's Avatar
Australia, QLD, Brisbane
Joined Mar 2011
Sorry, another question. Where do you all get your standoffs from.
Just tried test mounting the motor and getting the placement for the cowl before I tightened it all down.
Appears I now need approx 10mm long standoffs with a 4mm inside diameter to get the proper spacing so the cowl fits in the corect place.
If nothing else, this plane is teaching me all the little extras I needed and hopefully where to get them from
edf_rookie is offline Find More Posts by edf_rookie
Old Sep 08, 2012, 09:18 PM
quadracer is offline
Find More Posts by quadracer
No, I won't ship it. Don't ask
quadracer's Avatar
United States, IN, Derby
Joined Feb 2012
I've got a bunch of nylon/plastic standoffs from my 60" Extra that I have no use for. I think they are 4mm shaft size, and a couple different lengths. If you want them, PM me your address and I'll mail them to you.
EEK! Just noticed you're in Oz.... That might be more expensive to post than it would be worth..
quadracer is offline Find More Posts by quadracer
Old Sep 08, 2012, 09:23 PM
edf_rookie's Avatar
Joined Mar 2011
Thanks for the offer but that's the problem being down here in Oz, it's virtually impossible to find standoffs and prop inserts down here. My building has come to standstill until I can source some.
That's why if I can find somewhere that sells them then I can order a large quantity of different sizes that I know I will need sometime in the future anyway.
Old Sep 08, 2012, 09:29 PM
quadracer's Avatar
Joined Feb 2012
Yeah, you definitely want to buy in bulk down there. Have you tried a hardware store? Never know what you can find to "engineer" stuff together..
Old Sep 10, 2012, 07:57 AM
Wingin' Wayne is offline
Find More Posts by Wingin' Wayne
I like the violent stuff!
Costa Mesa, CA
I agree with the hardware store. Suprising what you can find in the little slide out drawers. I too am a machinist, even a small shop in garage and I still check the hardware store first. I have been making things for the buds at the field for a while, popular item for the SC is way oversized aluminum washers for the SFG's. An 8x10 bushing may be a standard item in a big catalog like McMaster Carr. Bushings and standoffs should be easy to find. Good luck!
Wingin' Wayne is offline Find More Posts by Wingin' Wayne
Old Sep 10, 2012, 08:15 AM
heritageflyer is offline
Find More Posts by heritageflyer
Time to Fly AJ's Best!
heritageflyer's Avatar
Hills of Eastern Ohio
Joined Nov 2008
Anyone have any (Good) used CF LG for the 57 SC?
I caught a hole yesterday on a grass field and it twisted out my right leg at the pant. Split the layers.
PM if you do, I need it by this Friday, got another big Fly event in WV.
Otherwise I am ordering new LG today...
heritageflyer is offline Find More Posts by heritageflyer
Old Sep 10, 2012, 02:38 PM
dentalpain is offline
Find More Posts by dentalpain
dentalpain's Avatar
United States, FL, Marianna
Joined Apr 2011
Here is some data for your consumption:
3DHS 57 Extra
Motrolfly 4315-714
Ice 100 Lite
Protek 15x7
Hitec HS225MG x4
Spektrum AR600
Gens Ace 4s4000 25C
Castlelink Settings:
Fixed End Points
Throttle Response: Medium (5)
Motor Start Power: Medium (59)
Motor Timing: Normal (5)
PWM Rate 12 Khz
Bec 6v
Logging Disabled.
Watts Up Power Readings: (End Points 73/74)
88 Amps
1370 Watts
Alt Settings
Throttle Respons: High (8)
Motor Start Power: Custom (75)
Motor Timing Low (0)
PWM Rate 8Khz
1240 Watts
82 Amps
dentalpain is offline Find More Posts by dentalpain
Old Sep 10, 2012, 05:36 PM
bigroger is offline
Find More Posts by bigroger
Just flitting about!!
bigroger's Avatar
Joined Aug 2011
Mate,
I just used some 12mm square pine strip and cut some 15mm pieces. Drilled holes through them and mounted so the pre-machined 12mm thickness was on the mount side so as not to screw with the thrust angles etc.
Has worked really well, just don't over tighten onto the pine spacers or you will crush the pine standoffs.
Alternative is just to cut some 15mm dowl hardwood to size and drill through the centre. Problem with that is you need to pretty sure of the lengths or you alter the thrust angle.
bigroger is offline Find More Posts by bigroger
Old Sep 10, 2012, 06:51 PM
DenverJayhawk is offline
Find More Posts by DenverJayhawk
Epoxy & CA Investor
DenverJayhawk's Avatar
United States, CO, Denver
Joined May 2010
that is crazy. Those are exactly the same numbers I'm getting, static test. APC 15x10
3DHS 57 Extra
Motrolfly 4315-714
Ice 100 Lite
Protek 15x7
Hitec HS225MG x4
Spektrum AR600
Gens Ace 4s4000 25C
Fixed End Points
PWM Rate 12 Khz
Bec 6v
Logging Disabled.
88 Amps
1370 Watts
Alt Settings
PWM Rate 8Khz
1240 Watts
82 Amps
DenverJayhawk is offline Find More Posts by DenverJayhawk
Old Sep 10, 2012, 08:24 PM
FIXXIN2FLY is offline
Find More Posts by FIXXIN2FLY
FLY ANGRY
FIXXIN2FLY's Avatar
United States, IL, Roscoe
Joined Jul 2008
Hey Bro,
I landed mine hard the other day (frickin ccreations hard cut off in hover) and broke the bottom out of the plane but Im pretty sure the gear was intact. I understand the timelyness of the parts for shows and I have nothing going on for two weeks. If it would help I can send you mine to get you on the solid for the show. LMK
FIXXIN2FLY is offline Find More Posts by FIXXIN2FLY
Old Sep 10, 2012, 08:29 PM
Joined Nov 2008
Originally Posted by FIXXIN2FLY View Post
Hey Bro,
Thanks! But Aronph came through for me! He's almost local, so shipping out Gear tomorrow USPS Priority (1 day).
Old Sep 10, 2012, 08:33 PM
Joined Nov 2008
Doylestown Fall FunFly vid
Had a good day at D'Town yesterday. Shot vid of last flight of the 57.
Damaged that gear on the second landing, catching the right wheel and flipping over. Then on this one, tried to slow up and Harrier Plop so I would have short roll and not flip over again, but caught a little wind puff on the left side and more like Dropped it.
Other than that the flight was decent.
57 SC @ Doylestown Fall FunFly 2012 (4 min 29 sec)
Old Sep 10, 2012, 08:37 PM
FLY ANGRY
FIXXIN2FLY's Avatar
Joined Jul 2008
RIGHT ON BRO!!! GO GETTEM!!! Friends dont let friends fly broke
Old Sep 10, 2012, 09:55 PM
Joined Nov 2008
I still Feel Broke!
Old Sep 10, 2012, 10:07 PM
FLY ANGRY
FIXXIN2FLY's Avatar
Joined Jul 2008
I still Feel Broke!
LOL I was just saying that to a fellow addict at the field tonite. Even when shiz is going my way and taking things home in one piece, "I" still feel broke!!! >LOL< too funny
New Product 3D Hobby Shop 47" Edge 540 #BUILD VIDEOS ADDED# ipsmotors 3D Flying 3960 Nov 23, 2013 07:39 PM
Video 3D Hobby Shop 57" Sukhoi sukhoi26mx Electric Plane Talk 7 Sep 17, 2008 08:33 AM
Sold NIB 3D Hobby Shop SHP Extra 300 *Blue* Version 2 thomer Aircraft - Electric - Airplanes (FS/W) 7 May 04, 2008 01:31 PM
Build Log 3D Hobby Shop 55" Katana LIVE Build Log Jeremy Sebens 3D Flying 54 Oct 12, 2007 03:39 PM
