Old Aug 03, 2012, 03:29 PM
Trill is offline
Find More Posts by Trill
Trill's Avatar
United States, TN, Murfreesboro
Joined Oct 2008
Originally Posted by Fliprob17 View Post
if you can up the voltage output on your esc pump 6volts through the servos. past that, the digital 5245 version has a bit more torque
I need to upgrade from the HS 225s also. But some have identified some problems with the HS 5245s and I tried the HS 5245s on another plane.
What are the JR, Airtronics, and Savox equivalents of the HS 5245 servos?
Trill is offline Find More Posts by Trill
Old Aug 03, 2012, 03:37 PM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
you can reset all the set screws and use blue locktite, past that it wiggles around a bit and gets a little loose from time to time.
I've been really impressed with the 5245's on 6v!
turnerm is offline Find More Posts by turnerm
Old Aug 03, 2012, 04:06 PM
chq28 is offline
Find More Posts by chq28
chq28's Avatar
USA, MI, Portage
Joined Feb 2009
That's been my concern, because I have heard issues with them.
And then I hear this
chq28 is offline Find More Posts by chq28
Old Aug 03, 2012, 04:18 PM
chq28 is offline
chq28's Avatar
USA, MI, Portage
Joined Feb 2009
I've got 6V set right now. I just don't feel I get that much throw out of them. I'm going to check it tonight.
Old Aug 03, 2012, 04:31 PM
Trill is offline
Trill's Avatar
Joined Oct 2008
Best servos for the 57" Extra 330 SC
In addition to not enough throw I'm getting blow back on the elevator with the HS 225 servo and I have my CC 75 Amp ESC set to 6v output to the servos.
Anyone have suggestions for a digital equivalent to the HS 5245 MG that works on the 57" Extra 330 SC?
Old Aug 04, 2012, 05:27 AM
quadracer is offline
Find More Posts by quadracer
No, I won't ship it. Don't ask
quadracer's Avatar
United States, IN, Derby
Joined Feb 2012
That seems odd, I've got an HS225HB in the elevator on mine, and I'm getting 60-65 of throw, and I haven't noticed any blowback. I've got a Hitec long arm on the servo though.
quadracer is offline Find More Posts by quadracer
Old Aug 04, 2012, 12:04 PM
Trill is offline
Trill's Avatar
Joined Oct 2008
Solution for the HS 5245 servo
See http://www.rcgroups.com/forums/showthread.php?t=589365 for a modification on the HS 5245. But wouldn't it be better/best if the servo worked well right out of the box with no need for modification?
Old Aug 04, 2012, 03:09 PM
DenverJayhawk is online now
Find More Posts by DenverJayhawk
Epoxy & CA Investor
DenverJayhawk's Avatar
United States, CO, Denver
Joined May 2010
plenty of people use the 5245 right out of the box just fine. Extreme Flight and 3dhs both recommend it in their 57-60" models. Now that doesn't mean you should use it simply because they do. But to say the 5245 doesn't work well out of the box is inaccurate. I know several people using them just fine without modification. Based on what I've read on this forum, only a few folks here have had case problems with the 225mg and hitec took care of it. Note that these folks are exceptional pilots who possess more capability and put more demands on the 225mg than 95% of us here.
DenverJayhawk is online now Find More Posts by DenverJayhawk
Old Aug 06, 2012, 08:21 PM
lammbn is offline
Find More Posts by lammbn
Hooked on 3DHS
lammbn's Avatar
United States, ID, Boise
Joined Nov 2009
Ive actually been wanting to try the solar mini servos, have heard good things about them. other than that all your other options are $60+ i wish we could fit full sized servos in these. i would just say screw it and throw ds610/savox 1258tg servos in and call it a day. the extra weight wouldn't be that bad and they would fit in my 70" planes after i crash
lammbn is offline Find More Posts by lammbn
Old Aug 06, 2012, 08:52 PM
Trill is offline
Trill's Avatar
Joined Oct 2008
Thanks for the recommendation. Where can I get these solar mini servos?
Yes, titanium gear servos would bring out the best in the plane.
Old Aug 06, 2012, 09:00 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Guys if you fly hard you will need to do the case mod for the 5245s. Well all of hitecs servos that size need it as they all have the same case. I have killed more of these servos b/c of the case failing and locking up my servos than I care to think about. The mod is a good one and works great..
With all that said if you don't fly really hard you most likely will not have an issue. Though it does give you piece of mind.
losifanatic is offline Find More Posts by losifanatic
Old Aug 06, 2012, 09:10 PM
quadracer's Avatar
Joined Feb 2012
Anyone got a link or info on this "case mod?" I'm on my iPhone, and don't want to search for it...
Old Aug 06, 2012, 09:11 PM
Sippin the Koolaid!
Joined Oct 2007
Trill posted a link a few posts up from ours
Old Aug 06, 2012, 09:15 PM
quadracer's Avatar
Joined Feb 2012
Thanks! I guess if I weren't an idiot, I would have noticed that... Lol
Old Aug 06, 2012, 10:46 PM
Trill is offline
Trill's Avatar
Joined Oct 2008
Thanks for weighing in on the HS 5245 issue. What servo(s) do you recommend to replace rather than modify the HS 5245?
You're in great company. Joe Smith weighed in on another issue over in the 87" Extra SHP thread.
New Product 3D Hobby Shop 47" Edge 540 #BUILD VIDEOS ADDED# ipsmotors 3D Flying 3960 Nov 23, 2013 07:39 PM
Video 3D Hobby Shop 57" Sukhoi sukhoi26mx Electric Plane Talk 7 Sep 17, 2008 08:33 AM
Sold NIB 3D Hobby Shop SHP Extra 300 *Blue* Version 2 thomer Aircraft - Electric - Airplanes (FS/W) 7 May 04, 2008 01:31 PM
Build Log 3D Hobby Shop 55" Katana LIVE Build Log Jeremy Sebens 3D Flying 54 Oct 12, 2007 03:39 PM
