Old Jul 22, 2012, 10:04 AM
What?!? I didn't do that!
gremlin's Avatar
Orchard Park, NY
Joined Dec 2002
I use a single Gens Ace 25C 4S 4000 in my 57" and double them up for my 71" Slick. Those batteries work great in both planes. A pair should work fine in the 72" Extra. The weight of the 3800 and 4000 are about the same so go for for the larger ones.
gremlin is offline Find More Posts by gremlin
Old Jul 22, 2012, 10:06 AM
Dad, why isn't yours that big?
CrashesALot's Avatar
Western CT
Joined Aug 2009
Originally Posted by delta2001 View Post
Need some help guys. I am about to purchase batteries for this plane and need advice on which ones. Looking at gens ace 4s 25c 3800 and 4000. I like a floatier plane but I am also looking at a 72 inch next spring that these batteries need to work in also. Any ideas?
I run relatively lighter setups and I am using zippy 4S 4000 packs on mine and I like them a lot. With that size, my packs still need to be pretty far forward to get a slightly nose heavy cg. So, if you like slightly nose heavy cg's, then I would skip the 3800's and go right to the 4000's.
Plus, you are then perfectly setup to go 8S 4000 later for the 72".
CrashesALot is offline Find More Posts by CrashesALot
Old Jul 22, 2012, 10:24 AM
United States, AL, Montgomery
Joined Mar 2005
Thanks guys. 4000mah it is then. Using them for both set ups sounds real good.
One more question. Are deans connectors ok to use or do I need something more heavy duty?
delta2001 is offline Find More Posts by delta2001
Old Jul 22, 2012, 10:40 AM
gremlin's Avatar
Orchard Park, NY
Joined Dec 2002
You will get a lot of different opions on that. Deans will work, especially on the 57", but I prefer EC5s, especialy to solder up. Others prefer PowerPoles. One reason I use the EC5s is then I only need one paraboard to charge all my larger packs, 4s, 5s and 6s.
Old Jul 22, 2012, 11:53 AM
Western CT
Joined Aug 2009
On this size ship, Deans will definitely work. IIRC Joe uses Deans on his electric 104.
Old Jul 22, 2012, 12:39 PM
Dennis C's Avatar
Grass Valley California
Joined Jun 2004
If you have good solder skills then the Deans are an excelent choice.
If you have problems soldering heavier wire then the deans could be a problem. don't over rate your skills.
Dennis
Dennis C is offline Find More Posts by Dennis C
Old Jul 22, 2012, 02:18 PM
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
better put on a fire resistant suit!!
Any of the popular connectors will work fine at this size. EC3or5 Deans, Power Poles.
As to the batteries I use ThunderPower 3900 25C packs and the plane flies nice and light. I also plan on getting a 71" plane next year and running 2 in series for 8S.
-Brian
kalmon is offline Find More Posts by kalmon
Old Jul 22, 2012, 04:41 PM
Hooked on 3DHS
lammbn's Avatar
United States, ID, Boise
Joined Nov 2009
If your just starting in this size so looking for a connector keep this in mind. Powerpoles are easy to use and hard to mess up. But for when you go bigger and start running your batts in series you really dont need a harness and less wire= less resistance. Just separate your pos and neg plugs from eachother and then plug one pos into the other batteries neg and then connect the remaining pos and neg together for your 8s output. Ive seen it done and work nicely. Also seen the connection point between the batteries used as a spot for an arming switch. Powerpoles also save you money on shrink wrap and solder. Not saying the other connectors arent great too but ive tried them all and just sharing my experience.
PS: get the crimpers. They are worth their weight in gold. I tried using regular crimpers for a while and had no clue what i was missing out on.
lammbn is offline Find More Posts by lammbn
Old Jul 22, 2012, 05:21 PM
Trill's Avatar
United States, TN, Murfreesboro
Joined Oct 2008
+1 on the Power Poles and yes, get the crimpers!
But if you like or prefer soldering, the Power Poles are easy to solder. The crimping is just so easy, clean, and convenient!
And yes, I have used Deans, EC3, EC5, XT60, and Power Pole connectors. For my money the flexibility of the Power Poles can't be beat.
Trill is offline Find More Posts by Trill
Old Jul 22, 2012, 06:40 PM
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
I'm using Anderson Power Poles on my 57" SC and love them. Prior to this I had only used deans.
turnerm is offline Find More Posts by turnerm
Old Jul 22, 2012, 07:42 PM
djmoose's Avatar
USA, OH, Macedonia
Joined Jul 2009
I'm excited to have ordered my 2nd 57" I had one a few years ago and sold it to go bigger. I have now realized that I LOVED this plane and want another one.
djmoose is offline Find More Posts by djmoose
Old Jul 22, 2012, 11:31 PM
Epoxy & CA Investor
DenverJayhawk's Avatar
United States, CO, Denver
Joined May 2010
i've used APP's for about a year now. Best thing since sliced bread.
DenverJayhawk is offline Find More Posts by DenverJayhawk
Old Jul 23, 2012, 01:18 AM
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Personally, I prefer home baked bread....
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jul 24, 2012, 10:40 AM
ADC=Worldwide 3DHS Stuff :)
Fliprob17's Avatar
SoCal-Rancho Santa Marg.
Joined Mar 2007
go with the 25c 4000mah - this is exactly what I am running, great setup.
Fliprob17 is offline Find More Posts by Fliprob17
Old Jul 24, 2012, 08:07 PM
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Kitty Hawk
Joined Oct 2007
Originally Posted by fliprob17 View Post
go with the 25c 4000mah - this is exactly what i am running, great setup.
+1!
losifanatic is offline Find More Posts by losifanatic
New Product 3D Hobby Shop 47" Edge 540 #BUILD VIDEOS ADDED# ipsmotors 3D Flying 3959 Dec 05, 2012 09:57 PM
Video 3D Hobby Shop 57" Sukhoi sukhoi26mx Electric Plane Talk 7 Sep 17, 2008 08:33 AM
Sold NIB 3D Hobby Shop SHP Extra 300 *Blue* Version 2 thomer Aircraft - Electric - Airplanes (FS/W) 7 May 04, 2008 01:31 PM
Build Log 3D Hobby Shop 55" Katana LIVE Build Log Jeremy Sebens 3D Flying 54 Oct 12, 2007 03:39 PM
