Old Jul 08, 2012, 07:27 AM
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Originally Posted by joesmith285 View Post
That was the whole point of using thin ca, get everything all lined up, glue the ca hingeds, and then wick in thin around the joiner.
Glue wars
I think I'll go this route once my replacement elevator gets here. The original one is in the trash... I got pissed and snapped it into several pieces!
turnerm is offline Find More Posts by turnerm
Old Jul 08, 2012, 07:47 AM
Team Hillbilly
tominator06's Avatar
Baltimore, Md
Joined Feb 2009
Now I find that hard to believe.
tominator06 is offline Find More Posts by tominator06
Old Jul 08, 2012, 08:06 AM
I like the violent stuff!
Costa Mesa, CA
I'm with Joe Smith on this one. I've put together a half dozen planes using this method with NO problems. The covering to covering bond holds WELL on the horizontal stab with thin CA, so that's how I join the elevator.
Wingin' Wayne is offline Find More Posts by Wingin' Wayne
Old Jul 08, 2012, 11:42 AM
Irg
ol' yellow eyes is back
Irg's Avatar
Brooklyn, NY
Joined Apr 2009
ok skar face.
Irg is offline Find More Posts by Irg
Latest blog entry: laser repair
Old Jul 08, 2012, 12:30 PM
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Originally Posted by Irg View Post
ok skar face.
Oooooh man!! Them is FIGHTIN' WORDS!!!
Old Jul 08, 2012, 12:34 PM
chq28's Avatar
USA, MI, Portage
Joined Feb 2009
ok skar face.
Is that the second Skar face comment in as many days. What's up with that
chq28 is offline Find More Posts by chq28
Old Jul 08, 2012, 01:57 PM
TEAM K.G.B.
FIXXIN2FLY's Avatar
Roscoe, IL
Joined Jul 2008
OK, the 57 is almost finished. Waitin on the 100 ice and its go time. I will have to say that was one of the easiest builds yet from 3DHS. It just kinda fell together. I did have a little modifying to do to the motor mount to make the Motrol 3620 fit properly with the cowling (mainly the color and striping match. The motor box is very deep and I had to push the motor out 1/2" to get everything to line up. Still not perfect but good enough. Looking forward to 3DHS ship #4 of the 5 Ive purchased this year alone
FIXXIN2FLY is offline Find More Posts by FIXXIN2FLY
Latest blog entry: The family continues to grow
Old Jul 08, 2012, 02:02 PM
Irg
Irg's Avatar
Brooklyn, NY
Joined Apr 2009
I definitely took inspiration from the first one . I feel for both of you guys...I've been in the same mood of frustration and anger many a time. the nice thing is that if you continue in the hobby you start to accrue tools and skills that make everything easier and those moments start to become fewer and farther between.
Old Jul 08, 2012, 02:40 PM
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
I do agree with that. I starting getting frustrated with this build before getting to that point... that was just the proverbial straw that broke the camel's back for me.
Old Jul 08, 2012, 02:53 PM
United Kingdom, London
Joined Jul 2011
when i built mine, the one and only fustration (like on every 3dhs build for me) i screwed pull-pull setup lol... i didnt check and had a wire wrapped around ballink.. and i noticed it only after i had caed rudder servo side...
rimaarts is offline Find More Posts by rimaarts
Old Jul 08, 2012, 03:16 PM
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Yea - seems like I screw one thing up on just about every build too so I know your pain!
On this one I had issues with the horizontal stab but it wasn't really my issue. This was a garage sale Extra and there was a slight issue with the fuse where the cutout for the horizontal stab goes so it would fit in very well. Plus I was missing a tail wheel but I just snagged one from my crashed 51" Slick.
Old Jul 09, 2012, 01:53 PM
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
I just got my new Castle ICE 100 ESC for the plane and Aero-model tested and returned my A40-12s. I've never setup a castle esc before. I have the castle-link but there are so many settings there. Anyone have any idea what timing, pwm, etc I should use for the A40-12S?
*edit: I just hooked everything up soldered the EC3s on that Castle 100. What a pain that was!! I had to cut the wires trim about 10% off the diameter of the 10awg wire so that I could fit it into the EC3's bullet.
Am I an idiot for trimming a small amount of the wires? It is still 12awg in size.
Castle logging on a fresh 4S 3900mAh TP pack shows 68 amps and 885watts. Does that sound right?
The good news is I no longer have any acceleration problems. All the motor studdering/clunking and stalling is gone YAY!
I used 16khz PWM, normal timing(5), and medium throttle response. I set the cutoff to 3.3V soft, figuring it'd be better to lose a battery than the whole plane. Is that a good idea?
I also used the auto throttle sensing? is that good for a plane or should I use the fixed end points?
-Brian
kalmon is offline Find More Posts by kalmon
Old Jul 09, 2012, 05:20 PM
Trill's Avatar
United States, TN, Murfreesboro
Joined Oct 2008
Originally Posted by kalmon View Post
I also used the auto throttle sensing? is that good for a plane or should I use the fixed end points? -Brian
Fixed end points has at least one benefit. "Auto throttle" requires you to run the throttle up to full throttle before each flight to enable the Castle ESC to calibrate the range of your throttle for smooth operation.
When you click on the "?" next to the functions within your Castle Link program when your Castle Link is connected to your computer you'll get helpful and sometimes useful information.
Hope this helps!
Trill is offline Find More Posts by Trill
Old Jul 11, 2012, 12:31 AM
iumop ap!sdn w,I
G.P.'s Avatar
Joined May 2005
It's part of my preflight routine, and I've caught power system issues before getting in the air by doing it.
G.P. is offline Find More Posts by G.P.
Old Jul 11, 2012, 01:29 AM
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
And do you also hold the plane nose up in the air to see if it is going to lean out??
Actually, while I don't always do it (and I should), I totally agree with you Greg....
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
New Product 3D Hobby Shop 47" Edge 540 #BUILD VIDEOS ADDED# ipsmotors 3D Flying 3959 Dec 05, 2012 09:57 PM
Video 3D Hobby Shop 57" Sukhoi sukhoi26mx Electric Plane Talk 7 Sep 17, 2008 08:33 AM
Sold NIB 3D Hobby Shop SHP Extra 300 *Blue* Version 2 thomer Aircraft - Electric - Airplanes (FS/W) 7 May 04, 2008 01:31 PM
Build Log 3D Hobby Shop 55" Katana LIVE Build Log Jeremy Sebens 3D Flying 54 Oct 12, 2007 03:39 PM
