Old Jan 10, 2012, 02:53 PM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Originally Posted by lammbn View Post
Yeah. That sounds right. I was just talking about final before the roundout. Ive found that i have the smoothest landings with power off, full flaps, and pitch for airspeed. Give it just a little throttle if i get above 500fpm decent rate. I can land like described but i can make them look so much better power off. Guess im weird.
yeah a proper power off landing can be a thing of beauty. Have you ever flown a tailwheel plane? If not try this in one of the cessnas. on landing keep the nose wheel off the ground throughout the landing AND roll-out until you start to lose elevator authority then lower the nose wheel. Try to make it so that when the mains touch the nose attitude does not change at all. You'll still have the forward CG vs pivot point so rudder control wont be near as important. Actually the only way I can describe the rudder work required for tailwheel is to let a toddler loose on the passenger side floor and tie a couple suckers to the pedals.
kalmon is offline Find More Posts by kalmon
Old Jan 10, 2012, 03:35 PM
rimaarts is offline
Find More Posts by rimaarts
United Kingdom, London
Joined Jul 2011
wooooh.... fnally assembled my extra... now just waiting for batteries... >.< 17 days already from hobbyking... ordered 2 nanos, (i know they are cr$$p but i wanted to save on shipping... next month defo im going gens ace...)
so in order to test if motor is proper, i put on 13x6.5 prop... only battery i have is 3s sky lipo... and very strange thing is, i didnt go over 15% throttle but i could feel my esc getting warmer in the same sec i turn on throttle...?? esc is ice lite 75. should i be vorried? or it is because amp draw is over 3s batterie capabilites?
rimaarts is offline Find More Posts by rimaarts
Old Jan 10, 2012, 06:23 PM
Fliprob17 is offline
Find More Posts by Fliprob17
ADC Vinyl
Fliprob17's Avatar
SoCal-Rancho Santa Marg.
Joined Mar 2007
you're probably fine. Static tests with limited airflow typically produce more heat anyway.
Fliprob17 is offline Find More Posts by Fliprob17
Old Jan 10, 2012, 08:00 PM
BOBBY1017 is offline
Find More Posts by BOBBY1017
BOBBY1017's Avatar
Petaluma, Ca.
Joined Mar 2006
Originally Posted by kalmon View Post
Really? my batteries are shoved way up in the nose. I mean the back of the battery is only 3/4" past the end of the slanted motorbox supporting piece. Then there is about another 1/2 - 3/4 inch then my AR6210 then the wing tube.
Moved them back to the wing tube tonight and flew both the 3700 & 4000, couldn't tell much difference, harriers great as usual, I did get a good torque roll of about 3 rotations. Batteries were 65 deg, plane still feels under powered as its taking almost full throttle to hover, It used to be more like 5/8. If I get a chance I'm going to warm them to about 90 deg f and see if that's the difference, otherwise the batteries must be deteriorating with age. They're about 2 years old, not puffed at all, well balanced.
BOBBY1017 is offline Find More Posts by BOBBY1017
Old Jan 10, 2012, 08:09 PM
aronph is offline
Find More Posts by aronph
TEAM HILLBILLY
aronph's Avatar
Groveport, OH...USA
Joined Nov 2010
you definetly have a power system issue somewhere...i only have a 15x6 on mine and its ballistic out of a hover
aronph is offline Find More Posts by aronph
Old Jan 10, 2012, 08:12 PM
BOBBY1017's Avatar
Petaluma, Ca.
Joined Mar 2006
Here is what I've been using: Hacker a40 750 kv, 14 x 7 apc, 4cell 3700, 6 min flights with at least 20% battery capacity remaining, this produced 74a and 1000 watts. I've got a scorpion 90 esc, the 75 should be fine although i would say its about the min I would use.
Old Jan 10, 2012, 08:17 PM
BOBBY1017's Avatar
Petaluma, Ca.
Joined Mar 2006
The extra prop 1" dia would prob help alot, I'll check tonight with the watt meter and see what is up.
Old Jan 10, 2012, 08:21 PM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
I'm using a hacker x70 esc on an 610kv A40-12s on 4 cells with a 15x8 prop. It has unlimited vertical and hovers right around 2/3 throttle. so something is definitely wrong.
Old Jan 10, 2012, 08:23 PM
aronph is offline
TEAM HILLBILLY
aronph's Avatar
Groveport, OH...USA
Joined Nov 2010
thats not it either...plenty of people flyin 14x7s....i wouldnt fly on those packs...your gonna lose a plane
Old Jan 10, 2012, 08:58 PM
BOBBY1017's Avatar
Petaluma, Ca.
Joined Mar 2006
I'm not sure its the packs, The motor sounded "different" but after a year I may not remember exactly. It's easily flyable now but I wouldn't get to crazy below 50'.
Old Jan 10, 2012, 10:35 PM
BOBBY1017's Avatar
Petaluma, Ca.
Joined Mar 2006
Or maybe it is.... current tests: batt 1, 56a, 879w, 15.5 vm. batt 2, 58a, 889w, 15.3 vm. They were warm, not quite what they were a year ago. I guess even stored at 55% they're still going down hill, roughly a 21% decrease from new. That was in 10-2009.
I have 2 never used that I bought 10-2010 right before I stopped flying. Tomorrow I'll solder the connectors on and see how they do.
Old Jan 10, 2012, 11:57 PM
ADC Vinyl
Fliprob17's Avatar
Joined Mar 2007
prop. up
numbers are a bit low
Old Jan 11, 2012, 12:08 AM
BOBBY1017's Avatar
Petaluma, Ca.
Joined Mar 2006
Originally Posted by Fliprob17 View Post
prop. up
I liked it at the 1000w range, not sure if these batts can handle the larger prop.
Old Jan 11, 2012, 04:42 PM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
it was upper 40s today, clear skies and 3-5 mph vrb winds so I got the plane out today. I double checked my CG and took her for a few spins. I moved the battery forward about 1/4" and that fixed the landing tail drop, however it was a little to nose heavy to fly most 3D stuff. What I found is that if the CG is about 1/4"-1/2" in front of the wing tube the plane lands almost hands off in 3pt attitude. moving the battery back so that it balanced frozen fingertips in the middle of the spar the tail wants to drop like before, it very controllable I'll just have to remember that on landings. I really like the way if flies with the more rearward CG so i'll be keeping it there. I still might add a thro-elev mix on a switch for landings, haven't decided yet. Thanks to everyone with the help on trying to get it sorted out!
-Brian
Old Jan 11, 2012, 06:34 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
prop. up
Agreed . A 15x7 prop will rock it with that motor!
losifanatic is offline Find More Posts by losifanatic
New Product 3D Hobby Shop 47" Edge 540 #BUILD VIDEOS ADDED# ipsmotors 3D Flying 3960 Nov 23, 2013 07:39 PM
Video 3D Hobby Shop 57" Sukhoi sukhoi26mx Electric Plane Talk 7 Sep 17, 2008 08:33 AM
Sold NIB 3D Hobby Shop SHP Extra 300 *Blue* Version 2 thomer Aircraft - Electric - Airplanes (FS/W) 7 May 04, 2008 01:31 PM
Build Log 3D Hobby Shop 55" Katana LIVE Build Log Jeremy Sebens 3D Flying 54 Oct 12, 2007 03:39 PM
