Old Jan 09, 2012, 10:59 PM
Luv3d is online now
Find More Posts by Luv3d
Honeybadger don't care...
Luv3d's Avatar
United States, FL, Winter Park
Joined May 2010
Trimming question
Anyone own a JR 9503, and use Differential to make rolls more axial? I have a friend who is helping me retrim my 330SC, and as we are stepping through a Peter Goldsmith trimming guide, and it talks about differential based on the airplane 'walking' (45 deg upline with a full aileron deflection either direction)- the guide talks about decreasing the up aileron if it walks one way, but decreasing down aileron if walking the other way. A friend suggested we just adjust the TRAVEL ADJ menu to reduce the deflection in the needed direction.
My question is this- Diff. Aileron or TRAVEL ADJ- which do you prefer, and why?
Thanks for your thoughts!
Luv3d is online now Find More Posts by Luv3d
Old Jan 09, 2012, 11:14 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Don't need it. 3DHS planes are designed not to need differential.
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jan 10, 2012, 01:10 AM
BOBBY1017 is offline
Find More Posts by BOBBY1017
BOBBY1017's Avatar
Petaluma, Ca.
Joined Mar 2006
Originally Posted by BOBBY1017 View Post
This is close to my exact setup, hacker, batt's Rhino 3700 25c, I keep the end of the battery even with the front of the wing tube.
Originally Posted by kalmon View Post
Really? my batteries are shoved way up in the nose. I mean the back of the battery is only 3/4" past the end of the slanted motorbox supporting piece. Then there is about another 1/2 - 3/4 inch then my AR6210 then the wing tube.
I would think that would be nose heavy.
BOBBY1017 is offline Find More Posts by BOBBY1017
Old Jan 10, 2012, 07:10 AM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
I thought that is would be too, but the CG machine balanced it at 108, or so it said.... its not my CG machine and i never fingertip tested it as I trusted the machine. Maybe it was sticky or off, very nose heavy wouldn't do like I was describing, would it?
kalmon is offline Find More Posts by kalmon
Old Jan 10, 2012, 07:28 AM
aronph is offline
Find More Posts by aronph
TEAM HILLBILLY
aronph's Avatar
Groveport, OH...USA
Joined Nov 2010
i was extremely supprised to find how far back I had to move my battery to find neutral after i thought it was just "slightly" nose heavy...i had to slide it back almost 1 1/4 inches...and everybody that flies with the battery against the wingtube, I have no idea how you guys are doing that...you must have some spacers or something in the motor or a heavier motor...mine is a little heavier in the tail than most because i used 2x56 threaded rod and ball links on both ends of the servo linkages all the way around the plane but man....
aronph is offline Find More Posts by aronph
Old Jan 10, 2012, 08:13 AM
Luv3d is online now
Luv3d's Avatar
Joined May 2010
SteveT
I agree that is how they are designed, but mine clearly walks left when I deflect full aileron to the right- so I'm trying to fix that. I have used a meter to measure the angles- and they are spot-on, so I'm perplexed. May just have to play with each a little.
Old Jan 10, 2012, 08:18 AM
Luv3d is online now
Luv3d's Avatar
Joined May 2010
My 4000 mah 4S balances about 1/2" in front of the wing tube (batt weighs about 480g all in). I just picked up some 3300 mah 4S packs, and they balance much closer to the vertical supports on the batt tray- easily 2.5-3" in front of the wing tube. And my balance is almost perfectly neutral; I don't fly it slightly nose heavy. I run a Hyperion motor, 80A airboss ESC and no standoffs. I also have 2-56 threaded rod and ball links on both ends for all my servo linkages all around.
Old Jan 10, 2012, 08:30 AM
Wingin' Wayne is online now
Find More Posts by Wingin' Wayne
I like the violent stuff!
Costa Mesa, CA
All my planes have a nose up attitude for landing. I put a few degrees of up "spoileron" to push the nose down for landing, put it on a switch to make it easy. I fly with a couple 3DHS Team pilots and they said forget the switch and learn to fly it out. It was intense at first but I'm getting the hang of it.
Wingin' Wayne is online now Find More Posts by Wingin' Wayne
Old Jan 10, 2012, 08:35 AM
Luv3d is online now
Luv3d's Avatar
Joined May 2010
I used a Throttle-ELEV mix, so when the throttle was very low or off, it mixed in 2% down elevator. Helped me keep the right attitude for landing. I'm a full scale pilot as well, and frankly am embarrassed at how bad my normal landings are with and R/C airplane. I can harrier land the snot out of anything- in almost any weather condition, but don't ask for a normal landing...it may be in another state, or hit LVC trying!
The only 2 planes I think I land well normally are a 46" Vyper and my 48" EF Extra EXP. All others have had CF landing gear replaced at least once if not twice...
Old Jan 10, 2012, 08:39 AM
Fliprob17 is offline
Find More Posts by Fliprob17
ADC Vinyl
Fliprob17's Avatar
SoCal-Rancho Santa Marg.
Joined Mar 2007
CG at the leading edge of the wing tube
finger test is the simplest way to do it. for what it's worth I've never cared for the machines and have seen instances with guys where they were way off for some reason.
Fliprob17 is offline Find More Posts by Fliprob17
Old Jan 10, 2012, 08:46 AM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
It's sad that a simple machine seems to mess up so many people. I know a lot of guys that couldn't get the cg machine to work for them??????
I don't use mine for setting up my initial cg. I only use mine to fine out where it ended up after I flew the plane and put it where I thought the plane flew the best. That way if I make repairs I will know exactly where to put my battery at to have the same cg as before.
losifanatic is offline Find More Posts by losifanatic
Old Jan 10, 2012, 08:47 AM
ADC Vinyl
Fliprob17's Avatar
Joined Mar 2007
As it slows the tail continues to drop well below 3 point attitude and I'm having to use a little forward stick(not just released back, actual forward stick) to bring the nose down. All its gonna take is one light wind change or more likely me forgetting to put on low rates and it's gonna hit HARD nose first. My CG is at 108 which should be VERY conservative as I've heard of people maidening at 120. Any thoughts?
are you chopping the throttle at first, and/or controlling the decent/landing with the elevator? Land with the throttle, not the elevator. As soon as you chop the throttle on a neutrally balanced 3D plane, the tendency is for it to balloon up, making you force it back down. Keep the throttle at about 1/4 and gently force the nose down with the elevator. Then control the rate of decent with the throttle. It's perfectly normal to have to force the nose down just a little bit in a conventional landing.
Old Jan 10, 2012, 08:56 AM
kwiktsi is offline
Find More Posts by kwiktsi
United States, FL, Port Charlotte
I used to use the same mix on all my 3DHS planes, but have since gotten the hang of just flying them in since I just didn't bother programming it in on a couple of the newer ones. It's not bad once you get the hang of it, however, it is a real handful when I go from one that has the mix to one that doesn't. It takes at least 2 tries to get the feel for it again. To make it even worse- we fly off a narrow street with my car and friends full sized truck parked on the side and us standing alongside them. Doesn't leave a bunch of room for landing and the curb gets awfully close if you are struggling with the landing at all. Yesterday, I had to come in with a bum aileron servo- would just stick in various positions, that was REAL fun to get down.
kwiktsi is offline Find More Posts by kwiktsi
Old Jan 10, 2012, 09:09 AM
aronph is offline
TEAM HILLBILLY
aronph's Avatar
Groveport, OH...USA
Joined Nov 2010
ben told me just BEHIND the wingtube..thats where mine is...and its just a touch ahead of neutral
Old Jan 10, 2012, 09:14 AM
ADC Vinyl
Fliprob17's Avatar
Joined Mar 2007
leading edge of wingtube produces a very, very slight downward drop hands off inverted, that's how I like to set mine up. It's a good starting point, adjust from there to your liking.
New Product 3D Hobby Shop 47" Edge 540 #BUILD VIDEOS ADDED# ipsmotors 3D Flying 3960 Nov 23, 2013 08:39 PM
Video 3D Hobby Shop 57" Sukhoi sukhoi26mx Electric Plane Talk 7 Sep 17, 2008 09:33 AM
Sold NIB 3D Hobby Shop SHP Extra 300 *Blue* Version 2 thomer Aircraft - Electric - Airplanes (FS/W) 7 May 04, 2008 02:31 PM
Build Log 3D Hobby Shop 55" Katana LIVE Build Log Jeremy Sebens 3D Flying 54 Oct 12, 2007 04:39 PM
