Old Nov 01, 2009, 09:36 PM
blucor basher is offline
Find More Posts by blucor basher
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
United States, TX, Tyler
Joined Jun 2003
I like it fine on the analogs. Opinions differ.
blucor basher is offline Find More Posts by blucor basher
Old Nov 01, 2009, 09:38 PM
twistedgrim is offline
Find More Posts by twistedgrim
twistedgrim's Avatar
San Antonio, TX
Joined Sep 2008
225MG work fine.. Fly them on 55 Katana and 55 Yak.. they work great.. Digital is nice if you want to pony up the cash but ben will tell you they arent needed
edit. as I post the ninja posts before me
twistedgrim is offline Find More Posts by twistedgrim
Old Nov 01, 2009, 09:47 PM
routemech is offline
Find More Posts by routemech
shredding Ultracote since 2009
routemech's Avatar
Frederick CO
Joined Jul 2009
Thanks for the feedback... I will keep the 225MG on the order...
routemech is offline Find More Posts by routemech
Old Nov 01, 2009, 10:06 PM
cayars is offline
Find More Posts by cayars
cayars's Avatar
Bridgeton, NJ
Joined Mar 2009
I actually switched over to the 225MG to try them and didn't see any difference. I just left the 225MG in.
Carlo
cayars is offline Find More Posts by cayars
Old Nov 01, 2009, 10:52 PM
Stagger_Wing is offline
Find More Posts by Stagger_Wing
For the Birds
Stagger_Wing's Avatar
California
Joined Jul 2004
Originally Posted by skippy78 View Post
Your sfg's are on backwards
Letís just call it an experiment. I flew with them both ways and finally decided I like the plane better without the SFGs. You are right however, in the pic they are on backward and I didnít realize it at that time. By the way it flies fine in that configuration.
Stagger_Wing is offline Find More Posts by Stagger_Wing
Old Nov 01, 2009, 11:27 PM
RC4x4 is offline
Find More Posts by RC4x4
Fly Low or you'll never know!
RC4x4's Avatar
Thornton, Colorado
Joined Jul 2002
Originally Posted by routemech View Post
I just ordered the 57" 330SC, I ordered the HS-225MG. anyone: - do you think this is good? or should I have done digital? The HS-225MG are a great price...
Mike,
you'll be fine with the servo's you ordered. I have those in all my planes.
Cory
RC4x4 is offline Find More Posts by RC4x4
Old Nov 01, 2009, 11:59 PM
Doc Austin is online now
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
HS225MG servos rock. I've used the same set over and over in all my different SHPs, and my SR too. That same set will be going into my new SR. There are really reliable, solid, smooth working servos.
Doc Austin is online now Find More Posts by Doc Austin
Old Nov 02, 2009, 12:18 AM
NTM is offline
NTM
Find More Posts by NTM
NTM
NTM's Avatar
Lloydminster, AB, Canada
Joined Nov 2005
Originally Posted by Sillyness View Post
Anyway.. here's what I'm thinking:
Scorpion 4020-16 (415kV)
-Any better 6S motors? Weighs 10.7 ozs, but I heard people were adding 3 ozs ballast w/ the 7ozs motors.
Vox 15x7 Prop
CC Ice-
-Lite? 75 or 100?
Servos: HS-225MG, HS-5245, or JR 3517
-Any inputs here? Is there any difference going digi on this plane or am I better off staying with the cheaper analogs to keep BEC current down? Snaps, etc... good w/ the analogs?
Let me know what you think and anything you'd change!
Thanks!
That's very similar to what's in mine.
Scorpion 4020-16
6s 2500mah
16x8 turnigy wood electric (great props !)
225mg's
Castle ice lite 75
It's pulling 54 amps at full throttle (low timing), lots of thrust and cool running. A 15x8 or 15x10 would work well too.
It's working much better than the hacker a40-14s it replaced.
I'm very impressed with the scorpion.
Balance is no problem, for 125mm with a 6s 2500, the end of the pack is right on top of the wing spar in mine. No spacers needed for the motor, just bolt it to the firewall.
The 225's are great, I can't tell the difference between them and my digitals in flight.
I'm really enjoying this 330sc, it's such a well mannered and responsive plane, it's very easy to fly low and aggressively, confidently.
For those running the ice esc's, do not run the 2.18 beta firmware, it loses timing with higher pole count outrunners and will damage your esc and motor.
2.16 with outrunner mode and low timing is what I'm using with the scorpion.
Regards,
Nathan
NTM is offline Find More Posts by NTM
Old Nov 02, 2009, 12:47 AM
For the Birds
California
Joined Jul 2004
Regards,
Nathan
Thanks for the info. I will change mine back to the older firmware version. I would hate to lose this plane to an esc failure.
Scott
Old Nov 02, 2009, 08:44 AM
BustedBlades is offline
Find More Posts by BustedBlades
Fear is the mind killer
BustedBlades's Avatar
United States, LA, Lafayette
Joined Dec 2008
+1
good way to put it.
BustedBlades is offline Find More Posts by BustedBlades
Old Nov 02, 2009, 08:54 AM
Steve Graham is online now
Find More Posts by Steve Graham
AMA L897187
Steve Graham's Avatar
NE Denver, CO
Joined Sep 2007
NTM wrote:
[PHP]For those running the ice esc's, do not run the 2.18 beta firmware, it loses timing with higher pole count outrunners and will damage your esc and motor.
[/PHP]
Thats exactly what I had to do to get my ICE 75 to work without losing sync on my Thrust 50.
Steve Graham is online now Find More Posts by Steve Graham
Old Nov 02, 2009, 02:57 PM
tho98027 is offline
Find More Posts by tho98027
tho98027's Avatar
Joined Aug 2004
Does anyone know which extra long dubro servo arms to use for the hs 225 are? I think I currently have the 672, not sure, but would like a little more throw on the elevator. I have my radio maxed out on throw right now. Thanks.
tho98027 is offline Find More Posts by tho98027
Old Nov 02, 2009, 03:04 PM
Joined Jun 2003
The longest arm in the DUB672 kit is too long for the elev on this plane. I have my connector on the 4th hole from the outside and I'm past 45 deg on high rates. That's on JR9303X.
Old Nov 02, 2009, 03:15 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
With this arm and my end points maxxed I'm getting 45 degrees, and that's with a Futaba radio.
I never got around to moving it out to the last hole because I was so happy with the plane the way it was. On the next one I'll start off with 50 degrees or so and dial in more if I like it. The SC is so well balanced the way the instructions call for that I don't want to experiment too much.
Old Nov 02, 2009, 03:16 PM
Fliprob17 is offline
Find More Posts by Fliprob17
ADC Vinyl
Fliprob17's Avatar
SoCal-Rancho Santa Marg.
Joined Mar 2007
+1, too much throw. I think I hit 75deg. on the outter hole
Fliprob17 is offline Find More Posts by Fliprob17
New Product 3D Hobby Shop 47" Edge 540 #BUILD VIDEOS ADDED# ipsmotors 3D Flying 3960 Nov 23, 2013 07:39 PM
Video 3D Hobby Shop 57" Sukhoi sukhoi26mx Electric Plane Talk 7 Sep 17, 2008 08:33 AM
Sold NIB 3D Hobby Shop SHP Extra 300 *Blue* Version 2 thomer Aircraft - Electric - Airplanes (FS/W) 7 May 04, 2008 01:31 PM
Build Log 3D Hobby Shop 55" Katana LIVE Build Log Jeremy Sebens 3D Flying 54 Oct 12, 2007 03:39 PM
