no no no.....boondock saints......
warning...explicit lyrics
United States, FL, Port Charlotte
. As for the parenting comment, it was not directed at you specifically, just stating that if people on a "family forum" are worried about their kids seeing something inappropriate, try parenting instead of sitting back letting the internet raise your child then complaining that you don't like the result. An all too common occurrence these days .As for the spinners- I have seen pretty much every type spin true and I seen pretty much every type wobble, regardless of fit on the shaft. I have seen some wobble just because the knurling on the back plate does not jive well with the knurling on the face of the prop adapter and not let it sit flush. Heck, I have seen some prop adapters (cheap collet style) not let the collar sit straight when tightened down that are barely noticeable with just a prop on it but once you add a spinner, it is extremely noticeable. Spinners are just a matter of personal preference IMHO. I run them for looks on a majority of my planes and leave them off others when weight and or cooling is a concern. |
To space a spinner that you don't have a spacer for (proper spacers are sweet, but this method will work)... get some tape (my favorite is Scotch green automotive masking tape), and tear off about 10 inches and then tear it in half length ways. wrap around the prop shaft with the clean factory cut edge snug against the hub in a tight fashion. wrap so there's more than enough as a spacer. Then remove small pieces at a time checking to see if the spinner back plate is able to slide on in a snug fashion. When you can push the spinner plate to the hub, get a sharp knife and cut the tape close as you can to the spinner plate. The spacer is now made, mount prop and spinner as usual. When you tighten the prop nut, the force of the prop onto the back plate onto the hub of the motor will keep it all secure... it's just that the tape allows you to get something just about perfectly centered. If the spinner doesn't turn true, than it's probably a bad spinner or something is maybe bent...
That was actually my plan exactly. except i usually use electrical tape. i'm not sure i can get even one layer without drilling out the back plate with how close the hole already is. might have to drill it out a small step if i cant get it .the weird thing is though that it seems more like the back plate is warped with the wobble i'm seeing. it can only be seen by looking down onto the top of the plane. looking head on it seems perfect. i'm going to try to get a snug fit before i worry about it too much. i also have another great planes spinner in black waiting for my 58 edge to get here. i will try that as well. this plane has never had a blade strike or anything to hit the motor so i'm sure its still true. i couldnt see or feel any wobble running it without a prop or spinner.
SteveT |
Latest blog entry: My hangar...
Latest blog entry: This season's 3D line up...
| Thread Tools | |
| New Product 3D Hobby Shop 47" Edge 540 #BUILD VIDEOS ADDED# | ipsmotors | 3D Flying | 3959 | Dec 05, 2012 09:57 PM |
| Video 3D Hobby Shop 57" Sukhoi | sukhoi26mx | Electric Plane Talk | 7 | Sep 17, 2008 08:33 AM |
| Sold NIB 3D Hobby Shop SHP Extra 300 *Blue* Version 2 | thomer | Aircraft - Electric - Airplanes (FS/W) | 7 | May 04, 2008 01:31 PM |
| Build Log 3D Hobby Shop 55" Katana LIVE Build Log | Jeremy Sebens | 3D Flying | 54 | Oct 12, 2007 03:39 PM |
