Old Sep 17, 2009, 05:56 AM
A Monell is offline
Find More Posts by A Monell
Gloucester Ma
Joined Dec 2002
Quick note to others:
Cut out only one rear servo covering if building stock
A Monell is offline Find More Posts by A Monell
Old Sep 17, 2009, 08:49 AM
flyinhigh025 is offline
Find More Posts by flyinhigh025
How can we stop winter?
flyinhigh025's Avatar
Frederick, CO
Joined Sep 2005
Originally Posted by jadamian75
Jeff,
The build is looking great. Hope to see it fly Saturday at LAMA.
Hypersprint,
Good idea on zip tying the extensions for the ailerons to the side they are supposed to go to.
I have used the heat shrink method of holding extentions together but have melted a couple of plastic cases myself. The aeroworks servo locks are very nice especially for places that need to be removed. I have used for semipermanent locks the smallest zip ties I can find. They work great by looping through one of the inside sets of 3 wires on the extension to the servo wire..
Joe
Good call Joe.
I will be at LAMA Sat. morning with the SC. Hope the weather is good!-Jeff
flyinhigh025 is offline Find More Posts by flyinhigh025
Old Sep 17, 2009, 04:41 PM
Frederick, CO
Joined Sep 2005
Elevator Set-Up
Time to get the elevator connected and ready to go...
NOTE!!! I am going to take a moment to remind everyone just how important it is to REMOVE THE PROPELLER during ANY power on set-up. I have lucked out time and time again, but have now heard enough horror stories about folks getting all sliced up by an inadvertent throttle application while setting up the controls. Or also bad, models have been severely damaged when they fly off a work bench...
Sorry to go there, but I had to say something.
-Jeff
Old Sep 17, 2009, 07:27 PM
MLT67 is offline
Find More Posts by MLT67
Joined Nov 2005
Jeff great build.. I'm right behind you - should start my wings tomorrow. I'll be intersted to see where you mount your RX...
MLT
MLT67 is offline Find More Posts by MLT67
Old Sep 17, 2009, 08:07 PM
Frederick, CO
Joined Sep 2005
MLT
MLT,
Thanks! Sounds like we will finish about the same time.
I have a feeling I will mount the RX on the farthest aft area on the battery tray. I'm hoping with the lighter Reaper GR45 my lipo will be a little forward of that position.
Jeff
Old Sep 17, 2009, 08:19 PM
GoldCraft is offline
Find More Posts by GoldCraft
GoldCraft's Avatar
United States, GA, Woodstock
Joined Jan 2007
Originally Posted by flyinhigh025
MLT,
Jeff
With the GR45 on 1/4" standoffs youll still have plenty of room on the back of the tray...thats where Zero3803 put his. Mine is velcroed to the side near the servo wing servo wire holes.
GoldCraft is offline Find More Posts by GoldCraft
Old Sep 17, 2009, 08:24 PM
Frederick, CO
Joined Sep 2005
Rudder Set-Up
3DHS was nice enough to run the rudder cables for us at the factory... I say thanks! And we have plenty of cable length to work with.
Hints:
1) Be sure rudder cables are taught, not tight. Banjo string tight won't do you any good. In fact it will put undue stress on the rudder servo causing a loss of torque and pre-mature wear on the servo.
2) Too loose is also bad. If you can move the rudder a visible amount of travel without the servo arm moving, the cables are too loose.
Take your time on this step. It's not as scary or as hard as I probably just made it sound. Just go easy and work find that "sweet-spot" between too tight, and too loose.
Anyone feel free to jump in and offer more suggestions on the topic!
-Jeff
Old Sep 17, 2009, 08:29 PM
Doc Austin is online now
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Nice, clean build, dude. I hope mine comes out as tight.
Doc Austin is online now Find More Posts by Doc Austin
Old Sep 17, 2009, 08:53 PM
pvtzemerak is offline
Find More Posts by pvtzemerak
JR > Futaba
pvtzemerak's Avatar
Green Lane, PA
Joined Mar 2008
Looks pretty good, cant wait to to hear about the maiden.
--PvT
pvtzemerak is offline Find More Posts by pvtzemerak
Old Sep 17, 2009, 09:27 PM
Frederick, CO
Joined Sep 2005
Thanks GC. I am going to put the AR6200 there for now. I appreciate the input. I have a new AR7600 on the way, so it will take the place of the 6200 when it gets here next week. That way the 6200 can go back to the Slick.
-Jeff
Old Sep 17, 2009, 09:30 PM
Frederick, CO
Joined Sep 2005
Doc and PVT,
Thanks for the compliments. No doubt your SC's will rock, another awesome kit for sure. I have had a great time assembling this one. If the weather is decent enough it will be ready to maiden Sat. morning. I will then report back and hopefully have some pics and maybe video.
-Jeff
Old Sep 17, 2009, 09:44 PM
SonyVegasUser is offline
Find More Posts by SonyVegasUser
currently 3D-Dabbler
SonyVegasUser's Avatar
Richmond, VA
Joined Aug 2009
Jeff,
Thanks for the build pictures and descriptions. I just got the last of my parts and supplies today. So, I should be right behind you this weekend. If only my 4S batteries on back order from Hobby City would arrive then I could get into the air.
SonyVegasUser is offline Find More Posts by SonyVegasUser
Old Sep 17, 2009, 10:04 PM
Frederick, CO
Joined Sep 2005
Originally Posted by SonyVegasUser
Jeff,
Mike,
Very good! Be sure to report back to us when you finish the build and get the SC in the air.
What Lipos are you planning to run in the SC?
-Jeff
Old Sep 17, 2009, 10:51 PM
fall666 is offline
Find More Posts by fall666
To me, every day is Saturday
fall666's Avatar
DAL/FTW
Joined Jul 2006
Jeff, if I may, I have started adding a nut to my pull pull's. See the attachments. The nut's main purpose is to let the builder make fine adjustments to the wire's tension. Too, they act as a backup if the adjustor's set screw were to become loose.
Hope we can soon look forward to a video of your plane's maiden.
gb
fall666 is offline Find More Posts by fall666
New Product 3D Hobby Shop 47" Edge 540 #BUILD VIDEOS ADDED# ipsmotors 3D Flying 3960 Nov 23, 2013 07:39 PM
Video 3D Hobby Shop 57" Sukhoi sukhoi26mx Electric Plane Talk 7 Sep 17, 2008 08:33 AM
Sold NIB 3D Hobby Shop SHP Extra 300 *Blue* Version 2 thomer Aircraft - Electric - Airplanes (FS/W) 7 May 04, 2008 01:31 PM
Build Log 3D Hobby Shop 55" Katana LIVE Build Log Jeremy Sebens 3D Flying 54 Oct 12, 2007 03:39 PM
