Old Dec 07, 2011, 03:10 PM
aerosheldon is offline
Find More Posts by aerosheldon
No one has more fun than me
aerosheldon's Avatar
United States, CO, Denver
Joined Sep 2003
Originally Posted by vienquach View Post
Would be nice if the wing tip had some blind nuts installed for the SFG, like the EF planes.
Vien
they don't? I just got mine and haven't built it yet.
aerosheldon is offline Find More Posts by aerosheldon
Old Dec 07, 2011, 03:14 PM
vienquach is offline
Find More Posts by vienquach
vienquach's Avatar
Chicago, IL
Joined Nov 2009
No, they don't. EF planes do.
Maybe something that could be improved.
Vien
vienquach is offline Find More Posts by vienquach
Old Dec 07, 2011, 03:18 PM
Joined Sep 2003
so you just screw into the wood in the wingtip?
Old Dec 07, 2011, 03:21 PM
rimaarts is offline
Find More Posts by rimaarts
United Kingdom, London
Joined Jul 2011
yes, and 'in theory' drip thin ca into hole to harden the wood... i remember someone did blindnutting for sfg but that involved recovering so no no for me... p.s. that motrofly... does it bolt right on? or do i need spacers? and was spacers supposed to come with kit? cause with 1.5 buck huck there is spacers, but here there was no spacers... just asking.... so far just cut holes, hinged rudder, finished tail section, assembled landing gear... now all i have to do is wait for servos and next month for motor and esc....
rimaarts is offline Find More Posts by rimaarts
Old Dec 07, 2011, 03:23 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
there's holes in the balsa tip that guide the screw into the backed plywood. you screw it in, remove it, add some thin CA, let it cure, and there you have a pretty tough and secure mount without requiring more hardware than needed and screws that you don't need to loctite or anything else in fear of them backing out during flight. the 70" planes and up have blind nuts and bolts, not necessary for this size airframe.
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Dec 07, 2011, 03:27 PM
vienquach's Avatar
Chicago, IL
Joined Nov 2009
Yeah, I guess. A friend installed blind nuts but required re-covering.
Thin CA into wood will work, but blind nuts will help last longer, after many cycles of installing and removing.
Vien
Old Dec 07, 2011, 03:29 PM
Joined Sep 2003
well if there is plywood in there I would think it would work fine then... thanks!
Old Dec 07, 2011, 03:47 PM
aronph is offline
Find More Posts by aronph
TEAM HILLBILLY
aronph's Avatar
Groveport, OH...USA
Joined Nov 2010
only bad thing about the blind nuts on the inside of wind is when they come off and rattle around inside the wing.....seen it several times
aronph is offline Find More Posts by aronph
Old Dec 07, 2011, 04:40 PM
chriscap is offline
Find More Posts by chriscap
USA, CA, Los Angeles
Joined Jun 2010
Spacers didn't come with mine. The a40 requires 10-12mm of spacing (7/16" roughly). I don't know about spacing on a motorfly.
chriscap is offline Find More Posts by chriscap
Old Dec 07, 2011, 06:53 PM
Luv3d is offline
Find More Posts by Luv3d
Honeybadger don't care...
Luv3d's Avatar
United States, FL, Winter Park
Joined May 2010
Weird, I know, but I have to remove my SFG's every time I pack my SC into my car. A couple of times a week...the screws probably hold fine over time, but I prefer thumb screws, so I made a cap for each wingtip, and put a 6/32" blind nuts in each wing. Very easy to remove or put on with no tools. Wasn't that hard, either.
Got the idea from Stickybeatz. His turned out awesome.
Luv3d is offline Find More Posts by Luv3d
Old Dec 07, 2011, 08:18 PM
Joined Sep 2003
Pics?
Old Dec 08, 2011, 04:54 AM
Luv3d is offline
Luv3d's Avatar
Joined May 2010
Pics?
I'll post them tonight- I think they turned out great. However, there was covering involved....
Old Dec 08, 2011, 01:45 PM
Joined Sep 2003
thanks, I can file them in my memory and after my build if I have issues with the standard I will know what to do...
Old Dec 08, 2011, 05:24 PM
Luv3d is offline
Luv3d's Avatar
Joined May 2010
Here are a couple of pics to help see what I did and how it came out. I used 1/8" balsa for the end cap, then I cut out the original section of the wingtip which held the plywood ring. I bored out the ring to fit a 6/32" blind nut, then pressed it into place and used thick CA to hold it on. I glued that to the back of the wing end cap after carefully placing the hold in the wing caps.
Then I used med CA to glue the entire wing cap to the existing wingtip. I use 6/32"x3/4" nylon thumb screws to hold the SFG's in place- works like a champ!
Old Dec 08, 2011, 05:26 PM
Joined Sep 2003
thanks!
New Product 3D Hobby Shop 47" Edge 540 #BUILD VIDEOS ADDED# ipsmotors 3D Flying 3960 Nov 23, 2013 07:39 PM
Video 3D Hobby Shop 57" Sukhoi sukhoi26mx Electric Plane Talk 7 Sep 17, 2008 08:33 AM
Sold NIB 3D Hobby Shop SHP Extra 300 *Blue* Version 2 thomer Aircraft - Electric - Airplanes (FS/W) 7 May 04, 2008 01:31 PM
Build Log 3D Hobby Shop 55" Katana LIVE Build Log Jeremy Sebens 3D Flying 54 Oct 12, 2007 03:39 PM
