Old Oct 09, 2011, 11:34 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Originally Posted by chriscap View Post
Do the hs225's buzz a bit when at full deflection. I got my elevator all setup tonight and I was surprised to hear them buzz a bit. The surfaces all move freely with no binding that I can tell. I guess my experience has been that all servos buzz to some degree. The hs-45's were really bad, 65's not so bad. I was just expecting these metal gear servos to be totally silent. Don't know why I expected that.
Is your elevator going full to the bevel, if so, back off just a few degrees, so that it is not. This usually the reason for buzzing at full deflection....
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Oct 10, 2011, 06:08 AM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
SteveT
+1 also with the 225s thats a good way to ruin that servo. Just make sure you are not getting any binding. Though also servos have noise to some degree
losifanatic is offline Find More Posts by losifanatic
Old Oct 10, 2011, 01:06 PM
YamaDan is offline
Find More Posts by YamaDan
Crashing Gooder and Gooder!
YamaDan's Avatar
United States, CA, Mission Viejo
Joined Feb 2009
Originally Posted by Wingin' Wayne View Post
I maidened my 57" Extra yesterday. Rob at ADC took great care of me with all the hot rod parts and Yamadan did a smokin' job on the build!!! All I had to do is show up and fly. Life is good! Ground check is good, wattmeter check just over 1100W, let's go! Took off, NO TRIM needed, thanks DAN. A couple minutes of getting a feel for it and RCDrum says okay enough circles. Blender time! Throw in a couple tumbles, check the knife edge, harrier and inverted flight. Only had one borrowed battery so the FUN was short lived. My biggest plane yet and bigger DOES fly better!!! Really looking foreward to cutting my teeth on this one and then moving up. A couple weeks and I'll be ready to pull out the 65" Viper. My hat's off to Ben and the crew for consistantly coming up with planes that are WINNERS right out of the box! I may have to get a bigger car so I can make the jump to 70" size!
You're welcome! Glad you enjoyed it!
YamaDan is offline Find More Posts by YamaDan
Old Oct 10, 2011, 04:06 PM
lammbn is online now
Find More Posts by lammbn
Hooked on 3DHS
lammbn's Avatar
United States, ID, Boise
Joined Nov 2009
Originally Posted by gabrielisrael View Post
What Castle ESC are you using?
Did you see I am having problems with my Castle Lite 75amp in my 59" Slick running the recommended components? It cut out on me about 5 seconds after pulling out of a hover. Fortunately I was able to dead stick it in, but still having problems with it.
Please keep me informed how things go.... thanks
i am using an Ice 75. not the lite version. it flew fine at the field with the 15x7. still didn't feel like it had as much punch as i would like. i'm going to do a little trouble shooting on my esc to see if it was the lvc or the current limiting causing it to cut out. if it was the current then i'm going to turn logging back on and see what the esc is reporting. if its bad i will put my Ice 100 in to hold me over while the 75 is in for repairs. I will update with the results of the testing and possible watt numbers with the ice 100 to see if they are any different with my prop selection.
lammbn is online now Find More Posts by lammbn
Old Oct 10, 2011, 07:44 PM
Fliprob17 is offline
Find More Posts by Fliprob17
ADC Vinyl
Fliprob17's Avatar
SoCal-Rancho Santa Marg.
Joined Mar 2007
told you
Fliprob17 is offline Find More Posts by Fliprob17
Old Oct 10, 2011, 08:19 PM
chriscap is offline
Find More Posts by chriscap
USA, CA, Los Angeles
Joined Jun 2010
Does it matter which side of the control horn the machine screw/ball link is on vs the nut. I feel like these minor things don't really matter. For example, on the ailerons, I've seen most pictures with the ball link on the inside and the nut on the outside (facing the wing tip). But when I lay mine out, seems to be a straighter line on the opposite. Does these things matter or contribute to binding. I'll probably just follow what I see, but is it worth worrying about something this small?
chriscap is offline Find More Posts by chriscap
Old Oct 10, 2011, 09:20 PM
Luv3d is online now
Find More Posts by Luv3d
Honeybadger don't care...
Luv3d's Avatar
United States, FL, Winter Park
Joined May 2010
I don't think so. Do what makes your setup better.
Luv3d is online now Find More Posts by Luv3d
Old Oct 11, 2011, 07:10 AM
ADC Vinyl
Fliprob17's Avatar
Joined Mar 2007
whatever gives the most direct, straight shot to the control horn. Doesn't really matter. You want to avoid angles in the servo horn to control horn connection.
Old Oct 13, 2011, 11:45 AM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Setup suggestion
I'm pretty sure I'm going to be ordering one of these. I'm relative new to RC, I started with a RTF 3 channel Cub, then a UM t-28, moved up to a DX6i and a PZ P-47 42" and now I have a e-flite UMX sbach342. I can fly the Sbach well and can hover it, KE, high alpha, couple of harrier rolls(still working on them). The guys at my local club think that I'm ready for a good balsa plane and said 3dhs is the way to go. Enough about me the question is I've never setup a plane before as all the other planes I have were BNF or RTF. I was thinking about getting a Scorpion SII-3026 710or890 and probably a 90amp ESC powered by a 4cell lipo. 4x HS-5245MG and a AR7010 or AR6210.
Will this setup work? Do I need a separate BEC? is there a better suited motor ESC combo? Would I be better off going with the 3dhs hacker A40-10S and X70A ESC? would that need a separate BEC?
I'm sorry for what is probably a simple question I've searched and been reading for weeks now but theory and actually building are different things usually.
kalmon is offline Find More Posts by kalmon
Old Oct 13, 2011, 11:58 AM
6L6Amp is offline
Find More Posts by 6L6Amp
6L6Amp's Avatar
Northern Indiana
Joined Jan 2009
The Hacker setup is great. You can probably save some money with a combo from 3dhs, too. Get it all in one spot and save on shipping.
And you can start collecting points towards other 3dhs stuff, too. Trust me, there will be more.
Running your servos at 6 volts really increases the performance. If your chosen ESC doesn't have an adjustable voltage BEC, you can run an external BEC like the Castle 10 amp. The stock BEC in the X-70 will work fine though if you don't want to mess with an external.
HS-5245 will work great on all surfaces.
6L6Amp is offline Find More Posts by 6L6Amp
Old Oct 13, 2011, 12:53 PM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
thanks for the quick response. I think for easy of setup i'll use the 3dhs combo.
Old Oct 13, 2011, 12:57 PM
chriscap is offline
Joined Jun 2010
Running 6v to the Rx and servos won't overload them or shorten their life?
Old Oct 13, 2011, 01:38 PM
stickybeatz is offline
Find More Posts by stickybeatz
stickybeatz's Avatar
USA, AZ, Phoenix
Joined Apr 2010
The resurrected 57 is enjoying her second chance at life out in the Arizona sun. Photos courtesy of Buzzed
p.s. leaning totally helps you avoid mid airs
stickybeatz is offline Find More Posts by stickybeatz
Old Oct 13, 2011, 01:45 PM
heritageflyer is offline
Find More Posts by heritageflyer
Time to Fly AJ's Best!
heritageflyer's Avatar
Hills of Eastern Ohio
Joined Nov 2008
No, they can take it. Running 225MG's on 6v.
heritageflyer is offline Find More Posts by heritageflyer
Old Oct 13, 2011, 01:46 PM
Joined Nov 2008
Feels good doesn't it!
New Product 3D Hobby Shop 47" Edge 540 #BUILD VIDEOS ADDED# ipsmotors 3D Flying 3960 Nov 23, 2013 07:39 PM
Video 3D Hobby Shop 57" Sukhoi sukhoi26mx Electric Plane Talk 7 Sep 17, 2008 08:33 AM
Sold NIB 3D Hobby Shop SHP Extra 300 *Blue* Version 2 thomer Aircraft - Electric - Airplanes (FS/W) 7 May 04, 2008 01:31 PM
Build Log 3D Hobby Shop 55" Katana LIVE Build Log Jeremy Sebens 3D Flying 54 Oct 12, 2007 03:39 PM
