Old Oct 07, 2011, 10:08 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Originally Posted by aronph View Post
how bout we ALL call castle?
with all of the fires they have produced lately I think we all already have
losifanatic is offline Find More Posts by losifanatic
Old Oct 07, 2011, 10:11 PM
aronph is offline
Find More Posts by aronph
TEAM HILLBILLY
aronph's Avatar
Groveport, OH...USA
Joined Nov 2010
I gotta toast Ice 100 here I have been wanting to send back but I want to wait till all the recall crap is over..im askeert i might not see it again
aronph is offline Find More Posts by aronph
Old Oct 07, 2011, 10:16 PM
lammbn is offline
Find More Posts by lammbn
Hooked on 3DHS
lammbn's Avatar
United States, ID, Boise
Joined Nov 2009
That was my gut feeling too... that means between my wrecked 71 slick and this esc the only 3dhs plane i have to fly is my epp extra. That is so saddening with so little good weather left in the season. Sunday was supposed to be good too
lammbn is offline Find More Posts by lammbn
Old Oct 07, 2011, 10:17 PM
aronph is offline
TEAM HILLBILLY
aronph's Avatar
Groveport, OH...USA
Joined Nov 2010
snatch one out of the classifieds
Old Oct 07, 2011, 10:48 PM
vienquach is offline
Find More Posts by vienquach
vienquach's Avatar
Chicago, IL
Joined Nov 2009
So i got my new props and tried some run ups with them. Before when i was trying a 16x8 that my buddy has my ice 75 shut down on me due to over current. About 78 amp peak on my watt meter. No problems with a 14x7 pulling 33 amps, but now with a 15x7 my esc is cutting out again at 51 amps. I set the over amp sensitivity to insensitive but its still cutting out when i hit full throttle. Obviously something isnt right. Any ideas from the addicts or should i call castle?
My ICE 75 cuts out at 82A or so.
100+ flights, no problem.
Vien
vienquach is offline Find More Posts by vienquach
Old Oct 07, 2011, 11:05 PM
aronph is offline
TEAM HILLBILLY
aronph's Avatar
Groveport, OH...USA
Joined Nov 2010
Vien
that limit is raisable though isnt it?
Old Oct 08, 2011, 01:34 AM
chriscap is offline
Find More Posts by chriscap
USA, CA, Los Angeles
Joined Jun 2010
There's some small thin collars in the hardware. They look like they go in the threaded pieces that connect to the ball links for the pull pull setup. Is that what they're for? What is their purpose? Don't see any mention in the manual or build video.
chriscap is offline Find More Posts by chriscap
Old Oct 08, 2011, 06:59 AM
vienquach's Avatar
Chicago, IL
Joined Nov 2009
Should be.
I set at 105A, but as often it cuts out at 82A-85A (continuous), probably due to the current spikes that hit 105A.
Vien
Old Oct 08, 2011, 07:16 AM
kwiktsi is offline
Find More Posts by kwiktsi
United States, FL, Port Charlotte
You need more planes . I have a 72" SC, two 57" SC's, 55" SHP, three 47" SHP's, 55" Edge, 47" Edge and 40" Edge in my 3DHS fleet. It's actually kind of sickening lol.
kwiktsi is offline Find More Posts by kwiktsi
Old Oct 08, 2011, 03:47 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
If you mean the thin washers on the "EZ" connectors then yes, one goes on the "EZ" connector, then stick the threaded portion through the servo arm, and then the other washer, then the nut. I have found for some reason, that I usually am not able to use both due to the thickness of the servo control arms. Sometimes, I will use one, or none depending on the thickness of the servo arm. Be VERY careful when putting the CA glue on the nut after you have it adjusted for the proper movement, as it is very easy to glue the "EZ" connector to the servo arm.
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Oct 08, 2011, 06:39 PM
chriscap is offline
Joined Jun 2010
Naw. These are long skinny sleeves. They look like they go in the threaded connectors that attach to the pull pull setup. Will take a picture and post
Old Oct 08, 2011, 06:45 PM
Luv3d is offline
Find More Posts by Luv3d
Honeybadger don't care...
Luv3d's Avatar
United States, FL, Winter Park
Joined May 2010
I suspect they are the crimping sleeves for the pull-pull setup. It is designed for the pull-pull cable to be routed through it, then looped a second time before crimping. Finish with a bead of CA (let it sit for awhile to dry).
Luv3d is offline Find More Posts by Luv3d
Old Oct 08, 2011, 07:04 PM
vienquach's Avatar
Chicago, IL
Joined Nov 2009
My 57" expired today. Low pass at high speed, 1 second of distraction from a warbird landing.
Been hating my yellow 57" (red looks wayy better) but probably now I will miss it. It served about 150 flights with 5 different power systems (from 800w - 1500w, 4s, 5s, and 6s)
Had 6 great flights today though. Did several KE spins with the new Motrolfly 4315-500 on 6s with Xoar 16x8. The thing was screaming pretty good. Crazy power at 1500+ W but I never flew at WOT today.
Vien
Old Oct 08, 2011, 07:10 PM
Luv3d is offline
Luv3d's Avatar
Joined May 2010
bummer. Sorry to hear that- B/Y, wasn't it? Is it repairable?
Old Oct 08, 2011, 07:14 PM
vienquach's Avatar
Chicago, IL
Joined Nov 2009
Probably not ... Looking at the RED 57" SC or Orange 59" Slick.
Vien
New Product 3D Hobby Shop 47" Edge 540 #BUILD VIDEOS ADDED# ipsmotors 3D Flying 3960 Nov 23, 2013 07:39 PM
Video 3D Hobby Shop 57" Sukhoi sukhoi26mx Electric Plane Talk 7 Sep 17, 2008 08:33 AM
Sold NIB 3D Hobby Shop SHP Extra 300 *Blue* Version 2 thomer Aircraft - Electric - Airplanes (FS/W) 7 May 04, 2008 01:31 PM
Build Log 3D Hobby Shop 55" Katana LIVE Build Log Jeremy Sebens 3D Flying 54 Oct 12, 2007 03:39 PM
