Old Oct 29, 2009, 04:20 PM
blucor basher is offline
Find More Posts by blucor basher
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
United States, TX, Tyler
Joined Jun 2003
I think it's pretty apparent what breaks which prop. The scimitar-bladed wood props are only vulnerable right at the tips, where any contact is on a definite grain boundary. Been playing with various Turnigy props, the straight-tip sport props aren't fragile at all.
The APC's tend to break near the hub, I suspect into corn the wood would be at least as good as APC, but rubbing against the runway definitely put the advantage to the APC.
blucor basher is offline Find More Posts by blucor basher
Old Oct 29, 2009, 04:23 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
most important factor to me: "do I have a prop to go fly", "how good it is on the thrust stand and in the air". So, quality woodies whenever possible, APC's 'cause that's all the LHS have and I want to fly today and did something stupid yesterday.
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Oct 29, 2009, 04:35 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Really, my only complaint about APC's is *WHY* do they have to be so sharp? If nothing else, the concensus is that the better wood props are at least as good overall in performance...and you can't cut up a steak with those. Obviously, sharp edges are not necessary.
You are absolutely correct, they don't need to be that sharp. On "slimers" you definitely need to need to dull the rear edge, or you will slice your fingers everytime you try to start your engine, unless you sand the trailing edge.. While I don't sand my "E" props, it does not hurt to do so.
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Oct 29, 2009, 05:49 PM
BoneDoc is offline
Find More Posts by BoneDoc
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
Originally Posted by theKM View Post
... So, quality woodies whenever possible ...
That's got to be the quote of the day .
Let's not turn this into a prop / power system forum . So I will comment on it no further. If you have the dough to swing for a woodie, then by all means .
BoneDoc is offline Find More Posts by BoneDoc
Old Oct 29, 2009, 05:51 PM
theKM is offline
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
...I don't need dough to swing my woodies dude
Old Oct 29, 2009, 05:52 PM
jfv61 is offline
Find More Posts by jfv61
Go guerrilla
jfv61's Avatar
Austin, TX
Joined Jul 2005
And further, I don't need to sand my woody
jfv61 is offline Find More Posts by jfv61
Old Oct 29, 2009, 05:53 PM
Adam G is offline
Find More Posts by Adam G
Joined Dec 2005
I have always used apc-e props. Bought some xoars and tried them out. They are definately nice. I still have some 12x7's on my PA planes. Broke my larger xoars on my 3DHS 55" plus planes and switched back to the apc's because they are available locally and cheap.
I think I like the crazy buzz they produce when stressed.
Adam G is offline Find More Posts by Adam G
Old Oct 29, 2009, 06:00 PM
sukhoi26mx is offline
Find More Posts by sukhoi26mx
Scott Stoops
sukhoi26mx's Avatar
United States, CO, Longmont
Joined Mar 2002
I'd like to shorten that even further - if you can swing the woodie, then by all means...
sukhoi26mx is offline Find More Posts by sukhoi26mx
Old Oct 29, 2009, 06:03 PM
Scott Stoops
sukhoi26mx's Avatar
Joined Mar 2002
Here's my take. the APC-E props work great in all diameters up to 700 or so watts. In the 14-17" range, I get a lot of vibration and cavitation (not technically the correct term, but I don't have a better one) above 700 watts. The jump to 18" and larger diameters seem to handle the higher watts fine due to increased hub mass and thicker blades. I like the 18+" APC-E props just fine. For me, there is a small window in the 14-17" range and higher than 700 or so watts that just doesn't work for my flying style.
Scott
Old Oct 29, 2009, 06:09 PM
jfv61 is offline
Go guerrilla
jfv61's Avatar
Austin, TX
Joined Jul 2005
I have a bunch of APC props also but I like Xoar props - smooth and quiet (but I agree less bite). The Turnigy wood props have turned out amazingly well, just wish more sizes were available. As for durability, I admit that I managed to split the tip of a $$$ 25" Xoar prop once before the plane ever left the ground...
Old Oct 29, 2009, 06:48 PM
GoldCraft is offline
Find More Posts by GoldCraft
GoldCraft's Avatar
United States, GA, Woodstock
Joined Jan 2007
Originally Posted by Jon Craig View Post
It is ordered.
Zomg. This will rock.
Great!...wait till you open that box.
GoldCraft is offline Find More Posts by GoldCraft
Old Oct 29, 2009, 06:56 PM
SonyVegasUser is offline
Find More Posts by SonyVegasUser
currently 3D-Dabbler
SonyVegasUser's Avatar
Richmond, VA
Joined Aug 2009
+1 on nice quiet wood props. Never had an issue with Vox wood props either. They come balanced and just pop it on the plane. The only time I have busted one is doing stupid stuff like flying in the dark the other day. Smacked the asphault on landing. It would have destroyed an APC prop as well.
SonyVegasUser is offline Find More Posts by SonyVegasUser
Old Oct 29, 2009, 07:03 PM
Jon Craig is offline
Find More Posts by Jon Craig
ModemMisuser
Lafayette, IN
Joined Dec 2007
Can...not...wait! UPS needs to move FASTER!
Jon Craig is offline Find More Posts by Jon Craig
Old Oct 29, 2009, 07:04 PM
BoneDoc is offline
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
Speaking of durability, here's my take
47" SHP - VIDEO #2: DURABILITY TESTING .
BTW, this is how the "BoneDoc" maneuver was coined.... Thanks Ben.
Old Oct 29, 2009, 07:12 PM
refugeefromcalif is offline
Find More Posts by refugeefromcalif
May the Farce be with you...
refugeefromcalif's Avatar
Duncanville, Alabama. USA
Joined Dec 2006
That video is a Classic, BoneDoc!
Yours and Ben's comments, just Made it Better.
BTW, Why did you have those frequency pins in your back pocket???
refugeefromcalif is offline Find More Posts by refugeefromcalif
New Product 3D Hobby Shop 47" Edge 540 #BUILD VIDEOS ADDED# ipsmotors 3D Flying 3960 Nov 23, 2013 07:39 PM
Video 3D Hobby Shop 57" Sukhoi sukhoi26mx Electric Plane Talk 7 Sep 17, 2008 08:33 AM
Sold NIB 3D Hobby Shop SHP Extra 300 *Blue* Version 2 thomer Aircraft - Electric - Airplanes (FS/W) 7 May 04, 2008 01:31 PM
Build Log 3D Hobby Shop 55" Katana LIVE Build Log Jeremy Sebens 3D Flying 54 Oct 12, 2007 03:39 PM
