Old Oct 26, 2009, 09:40 AM
BustedBlades is offline
Find More Posts by BustedBlades
Fear is the mind killer
BustedBlades's Avatar
United States, LA, Lafayette
Joined Dec 2008
Im using these packs with the GR-60. No problems, 5~6 min flights. About 2500~2800 mAh used.
http://www.hobbycity.com/hobbycity/s...idProduct=9506
BustedBlades is offline Find More Posts by BustedBlades
Old Oct 26, 2009, 09:42 AM
Lonelasso is offline
Find More Posts by Lonelasso
Lonelasso's Avatar
United States, TX, Austin
Joined Dec 2006
Originally Posted by sun.flyer
Let's see how would Manta1 type this...........
hehe.....hehe....hehe
muahahahahaaa
Lonelasso is offline Find More Posts by Lonelasso
Old Oct 26, 2009, 09:47 AM
sun.flyer is offline
Find More Posts by sun.flyer
Test your skills....fly IMAC!!
sun.flyer's Avatar
Swanton, Ohio
Joined Feb 2005
Originally Posted by lonelasso
muahahahahaaa
Yeap there's Matt.
Tim
sun.flyer is offline Find More Posts by sun.flyer
Old Oct 26, 2009, 09:55 AM
jfv61 is offline
Find More Posts by jfv61
Go guerrilla
jfv61's Avatar
Austin, TX
Joined Jul 2005
Originally Posted by Jon Craig
Well yeah - I was more wanting specific pack recommendations as far as size/weight and such. HC has a LOT of packs in that range. The model specs an 85A speed control, so 15C and I would think a lot of lower-cap 20C packs are not suited.
20C has been plenty for me, your mileage may vary. The 3600 Zippy packs I have are no longer available but I've used a variety of Flightmax and Turnigy packs in other sizes that have been great for me. Personally, I'd go for something like this:
http://www.hobbycity.com/hobbycity/s...idProduct=9467
I think the 30C Turnigy and the Rhino 25C 3700 would also be a good choice. Hope that helps-
jfv61 is offline Find More Posts by jfv61
Old Oct 26, 2009, 09:58 AM
sun.flyer's Avatar
Swanton, Ohio
Joined Feb 2005
Originally Posted by Sillyness
Hi all...
I'm contemplating getting this plane. I have 8 x 6S 2600-3000mAh packs that I fly in a 12S heli... looking for plank I can use the same packs in.
What would be a power and efficient setup for this thing on these packs? Would I be better with the 51" Slick or is this the ticket?
FWIW... I am an adept airplane 3D pilot too... I have a 100cc 3D machine, but getting sick of carrying it.
FWIW I did search the thread, but found scattered 6S info and no testamonials from anyone who had been flying it much.
Those packs would definately fly this airplane quite well.......probably better so than the 51" Slick which really is a better 4s flyer.
As to motor setups you would need a motor in the about the 500 KV area and a solid 14" to 15" prop with a solid 60A-80A ESC.
Tim
Jon Craig is offline
Find More Posts by Jon Craig
ModemMisuser
Lafayette, IN
Joined Dec 2007
I think the Rhino 25C 3700 would also be a good choice. Hope that helps-
Those packs look good, but 20 x 3.6 = 72, which is under what the ESC is capable of dealing with. I usually like to match that.
Hrmm. Price is darn good though...
Jon Craig is offline Find More Posts by Jon Craig
Old Oct 26, 2009, 10:11 AM
Joined Dec 2008
which is exactly why I went with 30C. I bench tested the GR-60 on a 15X7 and got 97 amps. Those 20C's would be hurtin.
Old Oct 26, 2009, 10:41 AM
jfv61 is offline
Go guerrilla
jfv61's Avatar
Austin, TX
Joined Jul 2005
20C has been plenty for me, your mileage may vary...
Much depends on your left thumb, a 20C battery can handle bursts well above the continuous rating. The vast majority of my 4S batteries from 2100 up to 3600 are 20C and they work well for me. With 3S I find that I want at least 25C. With 6S even 15C is working well for me. Again, YMMV
Old Oct 26, 2009, 10:43 AM
Joined Dec 2008
I have a heavy thumb.
Old Oct 26, 2009, 10:46 AM
ModemMisuser
Lafayette, IN
Joined Dec 2007
Well, I'd be mainly sport-flying the bird, so fast is the name of the game. So yeah probably gonna want higher C rating.
Old Oct 26, 2009, 10:53 AM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Something like that I think.
Tim
HEY!It always turns to me dont it....
Manta1 is offline Find More Posts by Manta1
Old Oct 26, 2009, 11:03 AM
sun.flyer's Avatar
Swanton, Ohio
Joined Feb 2005
Yes..........always.
Tim
Old Oct 26, 2009, 11:32 AM
birdie_in_texas is offline
Find More Posts by birdie_in_texas
Pro Bro #1008
birdie_in_texas's Avatar
USA, TX, Weatherford
Joined Sep 2003
Should be made illegal..!! hahhahaha just kidding..
birdie_in_texas is offline Find More Posts by birdie_in_texas
Old Oct 26, 2009, 11:48 AM
jfv61 is offline
Go guerrilla
jfv61's Avatar
Austin, TX
Joined Jul 2005
In that case I might go with a little more capacity for longer flight time:
http://www.hobbycity.com/hobbycity/s...idProduct=9511
http://www.hobbycity.com/hobbycity/s...idProduct=9463
http://www.hobbycity.com/hobbycity/s...idProduct=7656
The Turnigy packs have been good for me in other sizes.
Old Oct 26, 2009, 11:57 AM
Doc Austin is offline
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
I think if you put 5s in the SC it would be stupid fast. The 55" SHP was heavier, but on 5s the thing was just downright scarey overpowered as faster than most of the nitro planes at my club field.
If you want your SC to streak, put 5s in it.
I think for 3D, the SC is a much better plane than the SHP, simply because the power to weight ratio is much better suited for alpha flight. Dropping down to 4s on an SHP would get you closer, but the SC still has a lighter airframe, lighter power system, one less servo with linkage, and more wing.
I haven't weighed mine, but it is much, much lighter than my 5s SHP. Anyone know the difference in weight? I've seen a few people claim their SC is right at 4lbs.
The SC might be very similar in shape, size and construction to the SHP, but in execution it is a completely different airplane. For those who may have missed it, please check out my EXTRA SC Blog Report.
Doc Austin is offline Find More Posts by Doc Austin
New Product 3D Hobby Shop 47" Edge 540 #BUILD VIDEOS ADDED# ipsmotors 3D Flying 3960 Nov 23, 2013 07:39 PM
Video 3D Hobby Shop 57" Sukhoi sukhoi26mx Electric Plane Talk 7 Sep 17, 2008 08:33 AM
Sold NIB 3D Hobby Shop SHP Extra 300 *Blue* Version 2 thomer Aircraft - Electric - Airplanes (FS/W) 7 May 04, 2008 01:31 PM
Build Log 3D Hobby Shop 55" Katana LIVE Build Log Jeremy Sebens 3D Flying 54 Oct 12, 2007 03:39 PM
