Old Apr 29, 2010, 02:36 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Originally Posted by bajajrider View Post
you guys might be dissappointed, but i dont know if its gonna happen in sacramento(at least not at the proposed club, mather)..we found out that the county will NOT allow any form of overnight camping on the site...
Well...if it happens, I'll be there to watch....I'm only 90 miles away, so, I hope it does happen as I have never been to any type of 3D fly in... The club I belong to is crazy about racing and stuff like that, and while 3D is tolerated, there are not all that many guys who do it.
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Apr 29, 2010, 02:37 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Originally Posted by kygreen229 View Post
So im going to go with a CC 10A external bec for this plane. my last plane I messed with forever but finally got the bec soldered right at the deans along with the esc. Pain! Is there a better spot or easier way to solder an external bec to your esc?
-Kyle
Yup....
SteveT
Old Apr 29, 2010, 02:38 PM
airportdog is offline
Find More Posts by airportdog
departure from controlled flt
airportdog's Avatar
SF Bay Area
I make up an in-line Deans connector that fits between the ESC and battery. This offers some flexibility - - you can program your radio with the motor disconnected. Also makes it easy to swap out ESCs and BECs.
You do need to use a bit of finess to clamp the assembly in a stable position, mechanically wrap each wire lead around the spades, and get clean solder joints. You can use 3/8" or 1/2" shrinkwrap if you stretch it with a long nose pliers first.
Larry
airportdog is offline Find More Posts by airportdog
Old Apr 29, 2010, 02:40 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Hi Kyle....
A lot of guys, will go an inch or so back on the ESC battery leads, and peel of some of the insulation, and wrap the wire on there and solder it on, and then put heat shrink tube over it..
Another way, is make up and extension with bullet connectors between the battery and the ESC/bec. You then can take a few strands of the wire from the ESC, and wrap them and the BEC wires together, and insert into the bullet connectors, and sweat solder them in. If you do this, I put the female bullet connector on the positive wire of the ESC/BEC, and the male connector on the negative. That way they is no way you would accidently, plug the bullet connects up with the wrong polarity... The extenison then has bullets on one end and the deans on the other...
SteveT
Old Apr 29, 2010, 03:53 PM
fall666 is offline
Find More Posts by fall666
To me, every day is Saturday
fall666's Avatar
DAL/FTW
Joined Jul 2006
Here are two that I have seen.
gb
fall666 is offline Find More Posts by fall666
Old Apr 29, 2010, 04:03 PM
kygreen229 is offline
Find More Posts by kygreen229
kygreen229's Avatar
Boise, Idaho
Joined Jun 2009
alright thanks for the ideas guys. Im thinkin for simplicity I might just do it about an inch back and solder em on and then heat shrink it. Im not quite a solder pro
-Kyle
kygreen229 is offline Find More Posts by kygreen229
Old Apr 29, 2010, 04:24 PM
routemech is offline
Find More Posts by routemech
shredding Ultracote since 2009
routemech's Avatar
Frederick CO
Joined Jul 2009
I had RCAerographiX install graphics on my 57" SC last week. Here are some photos...
They did an amazing job! Here is their web page http://www.rcaerographix.com/
routemech is offline Find More Posts by routemech
Old Apr 29, 2010, 04:31 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Originally Posted by routemech View Post
I had AerographiX install graphics on my 57" SC last week. Here are some photos...
Hi Routemech....
Were these the same two planes that Lesgilmer posted a day or two ago???
SteveT
Old Apr 29, 2010, 04:45 PM
blucor basher is offline
Find More Posts by blucor basher
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
United States, TX, Tyler
Joined Jun 2003
Be sure and try the SFG's on the 57 - you'll like them.
blucor basher is offline Find More Posts by blucor basher
Old Apr 29, 2010, 04:56 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
What maneuvers do they make a big difference in (for?)??
I would assume knife-edge, but mine really knife-edges very well already...
I hadn't put mine on as I hate having to put them on and take then off to put in the wing bags...
Oh....and do you have any extra wing bags for the 70" size planes?? I need another set...
SteveT
Old Apr 29, 2010, 05:03 PM
routemech's Avatar
Frederick CO
Joined Jul 2009
Originally Posted by Draknkep View Post
Hi Routemech....
SteveT
I Don't know (Maybe? I know he put some on his web page), I have not been reading the threads much lately - work is interfering with my life again.
I'm local to RCAerographiX and I dropped them off at their shop last week for the installation. I know he just did a 51 Slick Blue...
Old Apr 29, 2010, 05:08 PM
tjhawker is offline
Find More Posts by tjhawker
Tx
Joined Oct 2008
Just so things are clear....There is a difference between Aerographix, which has been around for a long time, and RC-Aerographix who did Mike's vinyl.
Your 57SC looks great Mike, looking forward to seeing it at the field.
tjhawker is offline Find More Posts by tjhawker
Old Apr 29, 2010, 05:09 PM
routemech's Avatar
Frederick CO
Joined Jul 2009
Thanks Ben, I will give it a try - I have not flown it with them on yet - I was planning on doing that on my next flight.
I was thinking about adding some type of blind nut in the wingtip and using a plastic screw to attache them. Or maybe just leave them on, but then I can't get them in the wing bag... has anyone done any modification from the wood screw attachment?
Old Apr 29, 2010, 05:12 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
I'm local to AerographiX and I dropped them off at their shop last week for the installation. I know he just did a 51 Slick Blue...
I just sent you a PM
The one he posted was a 70", so I would bet it was yours...
SteveT
Old Apr 29, 2010, 05:15 PM
routemech's Avatar
Frederick CO
Joined Jul 2009
Oops Tyler is correct! Yes it's "RC AeroGraphiX"... The owner is Les a member at my local field LAMA. This is my first experience with a graphics kit! I will definitely make it part of my standard build on the bigger airplanes from now on.
New Product 3D Hobby Shop 47" Edge 540 #BUILD VIDEOS ADDED# ipsmotors 3D Flying 3960 Nov 23, 2013 08:39 PM
Video 3D Hobby Shop 57" Sukhoi sukhoi26mx Electric Plane Talk 7 Sep 17, 2008 09:33 AM
Sold NIB 3D Hobby Shop SHP Extra 300 *Blue* Version 2 thomer Aircraft - Electric - Airplanes (FS/W) 7 May 04, 2008 02:31 PM
Build Log 3D Hobby Shop 55" Katana LIVE Build Log Jeremy Sebens 3D Flying 54 Oct 12, 2007 04:39 PM
