Latest blog entry: More FPV flying! Checking out a couple...
SteveT |
Latest blog entry: My hangar...
That is what I thought too...I have built over a dozen of the 3DH planes and this is the first time I have had an issue with a servo. I took every ball-link off and made sure that everything is moving free (nothing is binding). I have the horn right over the hinge gap...the aileron moves easy by hand...all the way to 50+'.
So I did finally get out and fly mine today (one flight before yet another servo failuer) and what a nice plane!! Flies great and was down on the deck hovering on the maiden! Second flight was scary...took off and went into a knife edge...snapped to the right and then the right aileron locked at about 30' straight up...thank goodness I was able to get her down and didn't even drag a wing tip...take a look at the pics and let me know if I am missing something...I have a hard time thinking I had 3 bad servos
Bighead,
I notice you installed the ball link on the outboard side of the aileron horn. The manual and the build thread http://www.rcgroups.com/forums/showp...4&postcount=64 show it on the inboard side (mine is that way). The ball link may be binding against the horn at the +- servo endpoints. You should be able to verify this by inspection. Or hook up a wattmeter and look for current spikes. One other thing to check....make sure you have enough gap aileron-to-wing-root and aileron-to-SFG. These might be binding the aileron at flight loads. -- Larry |
Las Vegas, NV
Joined Nov 2009
Hi BigHead, question... Does that servo smell burned? An analog servo like the 225 would take a while to burn up, even if stalled. It's hard to say whether the motor or the op-amp would go first, but the magic smoke stinks(!) How are you powering the receiver/servos? The bec output from the ESC or a separate UBEC? Do you have a voltmeter to verify what voltage is going into (and thus out of) the receiver? It would be odd for an extreme overvoltage to pop just one servo, but in electronics I've seen stranger... G. P. may be on to something regarding the extension, or there might be a solder bridge in the receiver on that channel. Solid DC (of high enough voltage) on the signal wire might kill the servo. Do you have a spare receiver you can try? Have all three servos "gone bad" while you were flying the bird? Vibration from the prop/motor might be bringing on an intermittent problem... Hope something here helps. :-)
Rodger |
bighead93,
I have my aileron servo on the 2nd hole on the servo arm and the ball link connected to the side of the control horn thats closer to the servo not the opposite side like in your picture. (I use the radio endpoints to get the recommended throws) Maybe that would make a difference. Joe |
My 2 cents. I think your better off with the ball link as the pictures show. If you put it on the other side it would cause more of an angle.
I agree 100% on the servo extension theory. Don't use really light wire extensions either. That could certainly cause it to burn up. There may be wires broken in your current extension giving your connection but now allowing proper amperage to get to the servo. I'm using the Dubro heavy duty arms and from the center of the servo to the hole I'm using is 1". I also have my ball link on the outside so the linkage is more linear as yours is. |
Put the ball link on the inside of the aileron controll horn
Make sure the EZ connector is not too tight on the servo arm. But I see the biggest problem is you have to put the push rod through the little hole in the EZ connector Though the way you have it you should have less binding.Pending weather we will have our club fun fly Sat May 1st at Dr Hook's Come on up Dennis |
Thanks for all the replies! The first servo failed from the first time I sent current to it...took it to my LHS and we found that one of the gears was stripped (no burnt smell). 2nd servo was installed...watt tested again no spikes...moving the ailerons the right side froze at about 20' down. Pushed it gently and it recentered. Tried again and the servo was making some strange sounds and froze both up and down. Swapped for #3. Worked great and ground testing and then for a 6 minute flight. Second flight about 2 mins in it locked up. Scary landing like that but I did it...I am going to swap out the servo extention...I took all the ball links apart a couple of times so the ball moves around easy. We will see what the LHS says about the servo...funny the other 3 have been fine (knock on wood)!!
I will try and get up there again Dennis! |
| Thread Tools | |
| New Product 3D Hobby Shop 47" Edge 540 #BUILD VIDEOS ADDED# | ipsmotors | 3D Flying | 3959 | Dec 05, 2012 09:57 PM |
| Video 3D Hobby Shop 57" Sukhoi | sukhoi26mx | Electric Plane Talk | 7 | Sep 17, 2008 08:33 AM |
| Sold NIB 3D Hobby Shop SHP Extra 300 *Blue* Version 2 | thomer | Aircraft - Electric - Airplanes (FS/W) | 7 | May 04, 2008 01:31 PM |
| Build Log 3D Hobby Shop 55" Katana LIVE Build Log | Jeremy Sebens | 3D Flying | 54 | Oct 12, 2007 03:39 PM |
