Old Feb 16, 2010, 07:20 AM
flyinhigh025 is offline
Find More Posts by flyinhigh025
How can we stop winter?
flyinhigh025's Avatar
Frederick, CO
Joined Sep 2005
Originally Posted by bighead93 View Post
What Hyperion motor is that? Is that the ZS3025-10 775kv?
You are correct... ZS3025-10 / 775
-With BACKMOUNT ADAPTER SET - M8 X 28 MM
-Jeff
flyinhigh025 is offline Find More Posts by flyinhigh025
Old Feb 16, 2010, 10:32 AM
prozac is offline
Find More Posts by prozac
prozac's Avatar
USA, TX, Grapevine
Joined Sep 2008
Originally Posted by theKM View Post
weather hasn't been great but I managed to get out for a couple of packs. mainly to keep trimming and sorting out the setup. Running the Scorpion SII-3026-710 and a 14x7 Xoar, and going by today I'm super happy with it. Tons of power, plenty of forward speed, super smooth and quiet. Running it on an ICE-Lite100 and 4S 4000 flightmax packs and 4S2P 1650 Rhino's. An excellent setup to be sure.
Because the motor is so light, the packs need to be all the way forward to balance, and to make that operation easier I crafted a ply tray that locks into the first former to be secured vertically. It only needs to be stopped from sliding back which doesn't take too much effort (I was using masking tape for this purpose today). The cool thing about this is that the packs can change position on the tray for balance just like a regular setup, etc etc. The blenders I was doing today says that it was up for the challenge.
The plane continues to be a rocking beast to fly, so much fun. Last pic is the evidence that I did indeed get her low enough.
Why not make it easier on yourself and just put a heavier motor in there. I could understand all of this work if you just had it laying around and it makes enough power but not as a suggested setup. Your sled is pretty neat though. Anything on the front to protect the packs from the motor bolts that could occur in a hard nose in crash?
prozac is offline Find More Posts by prozac
Old Feb 16, 2010, 10:48 AM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
Yup, the plane can certainly fly a heavier motor for sure, can also use nose weight. I did actually have a heavier motor on there, but it simply doesn't need the power. This Scorpion has an absolute ton of power for this bird as it is. And if this little gadget allows the lighter motor to balance a plane without dead weight... means the plane is lighter and it keeps the operation of things super simple. Seems QED to me.
Puncture protection is on the todo list, but until then I'll just keep in mind to avoid nose-down incidents.
I could understand all of this work...
...you must be a builder
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Feb 16, 2010, 11:53 AM
G.P. is offline
Find More Posts by G.P.
iumop ap!sdn w,I
G.P.'s Avatar
Canada, AB
Joined May 2005
Sounds like this airframe would be a good canidate to get the 70" Slick canopy/cowl treatment in the future. That is one sweet design feature.
G.P. is offline Find More Posts by G.P.
Old Feb 16, 2010, 12:12 PM
Doc Austin is offline
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Incidents are ok as long as they don't include those sudden stops.
Doc Austin is offline Find More Posts by Doc Austin
Old Feb 16, 2010, 12:24 PM
flyracer is offline
Find More Posts by flyracer
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
I'm running a Power 32 and 2500mah 4S pack and find I have to push the battery ALL the way into the nose for proper CG (high risk for punctures!). Even then I think my setup is still alittle tail heavy.
-Flyracer
flyracer is offline Find More Posts by flyracer
Old Feb 16, 2010, 01:16 PM
theKM is offline
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
-Flyracer
wow, a light pack too even. In that case I'd be happily adding more battery to balance, duration is a close second to being lighter
Old Feb 16, 2010, 01:36 PM
prozac is offline
prozac's Avatar
USA, TX, Grapevine
Joined Sep 2008
KM, what are the temps like on that motor after a flight. You think it would work down here in Texas in the summer? Then again, I don't have anything to put this GR60 in.
Old Feb 16, 2010, 01:55 PM
Dennis C is offline
Find More Posts by Dennis C
Dennis C's Avatar
Grass Valley California
Joined Jun 2004
Flew Sat at our club fun fly and had a minor mid air. crunched the leading edg of the wing at the tip to the first rib.. Easy fix but no more flying that day.
Don't all these reqular fliers understand that when you hover or harrior that that is "your air space" and they are supposed to go some where else. I mean really just sitting there should not make you a target!!
Dennis
Dennis C is offline Find More Posts by Dennis C
Old Feb 16, 2010, 01:59 PM
theKM is offline
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
Yup. This motor is working within its published spec (typically we strain them above published spec for punchouts). It has an integrated fan in it and to be honest I could prop down again and still have enough power. It's the scorpion equivalent of the GR45, which is a recommended motor. I had a GR60 in it, so much power, wanted to see what lighter was like.
No motor mentioned in this discussion is a bad choice, really.
I can eagletree the motor temps, but it's below freezing up here, so your results would most certainly vary.
Old Feb 16, 2010, 04:55 PM
tuppertn is offline
Find More Posts by tuppertn
Postcards From The Purple Edge
tuppertn's Avatar
United States, OK, Sand Springs
Joined May 2007
Can you feel a difference in the weight with the lighter motor?
kendall
tuppertn is offline Find More Posts by tuppertn
Old Feb 16, 2010, 05:08 PM
jjr2001 is offline
Find More Posts by jjr2001
Fly Low Fly Fast Fly Often
jjr2001's Avatar
Glendale, Arizona
Joined Jul 2007
Dennis
Target? You bet, at my field if I hover I am the target so I always use all eyes to see if anyone is anywhere near and go somewhere else. If I don't I will loose a plane. I don't mind so much if it is just a foamie but my 3DHS planes are special and I always fly "boggy avoidance" LOL. .
I had one plane come straight down and into me when I was just flying level. Fortunatly my 47" SHP was repairable but the "other plane" was styrofoam dust.
Fly low and Fly the Best.
jjr2001 is offline Find More Posts by jjr2001
Old Feb 16, 2010, 05:20 PM
theKM is offline
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
kendall
3oz is starting to nudge the "can actually feel it" range rather than the "I think I can feel it"... but it's still largely academic for a plane this size. I really like this current setup though
The changes will be subtle, fraction less opposing aileron needed in t-rolls, the smaller prop runs a little smoother, the plane locks in a tad quicker when aborting and punching out... it all sounds awesome but it's still a very subtle difference really.
I do want to try a smaller pack to try for a bigger difference.
Old Feb 16, 2010, 06:55 PM
tuppertn is offline
tuppertn's Avatar
Joined May 2007
I ask because I could conceivably lose about 6oz by dropping down to a 3026-710 and 3700mAh bat. I'm just not sure how noticable that would be.
kendall
Old Feb 17, 2010, 01:08 PM
jjr2001 is offline
jjr2001's Avatar
Glendale, Arizona
Joined Jul 2007
Fly The Best
Wow....Man that is all I can think of....Wow.
I just put my first flight on my 57" SC and I must say that it is the very best 3DHS plane I have ever flown. Of course it seems like every time I get a new 3DHS plane it is the best. This Extra flies so perfect and so true that I don't want to fly anything else.
My setup was heavy but the plane flies "lite".
I have the Reaper GR60
4 HS225MG servos
Turnigy 80 amp ESC
Turnigy 5000 mah 4S Lipo
and yes, it seems lite in the air and on landing. More than enough vertical to fly straight up and out of sight.
Landing was smoooooth, very smoooooooth.
I love this plane.
It is amazing that one of the best 3D 57" planes on the planet is so easy to fly. I think this plane is a perfect plane for anyone that can fly the sim or a foamie and keep their orientation of left and right in order. It is not a trainer in that it will just go exactly where you point it so it will not self correct for pilot errors but it is easy to fly....Very easy to fly.
My battery was set about 4 inches in front of the wing tube but I will be moving it back for some 3D type flying.
I set up the linkages at about 80% of the manual recommendations and my entire flight was at medium rates. I can only imagine how she will react when I crank in full rates.
Fly 3DHS and Fly The Best
New Product 3D Hobby Shop 47" Edge 540 #BUILD VIDEOS ADDED# ipsmotors 3D Flying 3960 Nov 23, 2013 07:39 PM
Video 3D Hobby Shop 57" Sukhoi sukhoi26mx Electric Plane Talk 7 Sep 17, 2008 08:33 AM
Sold NIB 3D Hobby Shop SHP Extra 300 *Blue* Version 2 thomer Aircraft - Electric - Airplanes (FS/W) 7 May 04, 2008 01:31 PM
Build Log 3D Hobby Shop 55" Katana LIVE Build Log Jeremy Sebens 3D Flying 54 Oct 12, 2007 03:39 PM
