Old Dec 28, 2009, 07:21 PM
RedTalon is offline
Find More Posts by RedTalon
The RED filters through
RedTalon's Avatar
Rendon, TX
Joined Feb 2007
Originally Posted by byHISgrace View Post
The only problem I have with the AR500 is the programing that's needed to run the other aileron channel, you have to make your own mix and use the "gear" channel. Matt
The AR500 has a "channel" or "port" for the separate Ailerons....
RedTalon is offline Find More Posts by RedTalon
Old Dec 28, 2009, 08:19 PM
Lonelasso is offline
Find More Posts by Lonelasso
Lonelasso's Avatar
United States, TX, Austin
Joined Dec 2006
Originally Posted by Hypersprint View Post
I have the AR500 in several of my planes without any problem. For $50 I like it a lot
Rob
+ 1 (bought one for $25 and another for $30)
Lonelasso is offline Find More Posts by Lonelasso
Old Dec 28, 2009, 08:22 PM
Hypersprint is offline
Find More Posts by Hypersprint
Lets Make a Deal
Hypersprint's Avatar
Parrish, FL
Joined Apr 2008
Hypersprint is offline Find More Posts by Hypersprint
Old Dec 28, 2009, 08:35 PM
byHISgrace is offline
Find More Posts by byHISgrace
Jesus Freak
byHISgrace's Avatar
USA, TN, Knoxville, Cedar Bluff
Joined Feb 2005
Yes, but it's just a "y" off the other aileron channel. If you want to run flaperons, you must program a mix the "gear" to aileron channel. Matt
byHISgrace is offline Find More Posts by byHISgrace
Old Dec 28, 2009, 08:41 PM
Lets Make a Deal
Parrish, FL
Joined Apr 2008
I don't have my stuff to confirm this but I am pretty sure that all I have done with the AR500's is plug each aileron into each aileron channel and set the wing type to flaperon.
Rob
Edit: The ports labeled AILE are channels 2 & 6
Old Dec 28, 2009, 08:50 PM
wedgewing is offline
Find More Posts by wedgewing
Ready, Post, Aim
wedgewing's Avatar
Cleveland, OH
Joined Nov 2007
Kind of a floaty bird to be messing around with flaperons, but you are right.... built in Y harness....
This is from the AR500 manual
Note: The AR500 features dual aileron channels (channel 2 & 6) making it convenient when using aircraft with two separate aileron servos, no Y-harness or when mixing will be needed.
this post from RCU may contain a contain a work around. I Have not vetted it out to see if the guidance is solid but try it
wpotter6 -> RE: 3 position flaps with AR500 & DX7 (9/29/2009 12:18 AM)
Here are the directions that I put on the Corsair thread about how to make flaperons using DX7 and AR500:
I was able to set this up and bench test it using a DX7 and a spare AR500 with two servos. It is a bit complicated:
1. Use the Gear output to drive the right wing servo (this should be correct but could be the oposiite, i.e left aileron)
2. Turn on Flaperon in order to mix the flaps to the left aileron
3. Set up the desired flap angle
4. Set the Gear travel limts, up and down, to 0%, this is VERY important to prevent the gear switch from driving the right aileron!
5. Mix the AILE to GEAR with 100% rate
6. Mix the Flap to the Gear with 100% rate for the down flap positions, 0% for the Up Flap position
For some unknown reason, I was unable to mix the flap to both the aileron and the gear using 2 differnt mixes, with the flaperon off. I thought this would work, but it did not.
Make sure to use either Mix 5 or Mix 6 for the AILE to Gear mixing, because these channels on the DX7 trim both master and slave. Mises 1-4 do not trim the slave and can be used for the flap to gear mix. The DX6i programming may be slightly different.
These directions can be modifed if you are adding two flap servos with a Y-harness and making two flap surfaces separate from the ailerons:
1. Use the Gear output to drive the flap servos
2. Set up the desired flap angle
3. Set the Gear travel limts, up and down, to 0%, this is VERY important to prevent the gear switch from also driving the flaps!
4. Mix the Flap to the Gear with 100% rate for the down flap positions (both of them), 0% for the Up Flap position
If you use the flaperon technique, you will then avoid having to add two new servos and making a mod to the wing. This also helps to eliminate tip stall, because now the outer portion of the wing has more lift than the inner wing. You just need to eliminate the Y-harness to the aileron and use the Gear output for the other Aileron. There are two AILE outputs on the AR500, but these are simply connected together internal to the receiver and will not work for flaperon.
wedgewing is offline Find More Posts by wedgewing
Old Dec 28, 2009, 10:01 PM
cayars is offline
Find More Posts by cayars
cayars's Avatar
Bridgeton, NJ
Joined Mar 2009
Not so much for landing or takeoff but "spoiler/flaperons" can be used in harmony with the elevator to get extreme pitch. Like doing square loops, etc...
I have mine setup like this on my 3D birds so I can activate it with a switch.
Carlo
cayars is offline Find More Posts by cayars
Old Dec 28, 2009, 10:13 PM
Safety Hawk is offline
Find More Posts by Safety Hawk
Here We Go!
Safety Hawk's Avatar
United States, VA, White Stone
Joined Jun 2005
Carlo
I do the opposite of that. I have mine set to match my elevator.....well not an exact match, but more like 50% flaperon to elevator, and have it set to my trainer switch. So when I want to do fast elevators, I just grab the trainer switch and it make my plane fall like a rock.
Safety Hawk is offline Find More Posts by Safety Hawk
Old Dec 28, 2009, 11:13 PM
G.P. is online now
Find More Posts by G.P.
iumop ap!sdn w,I
G.P.'s Avatar
Canada, AB
Joined May 2005
Carlo
I thought the Slick already had "extreme pitch"!!!
I'd love to see that!
G.P. is online now Find More Posts by G.P.
Old Dec 28, 2009, 11:23 PM
cayars is offline
cayars's Avatar
Bridgeton, NJ
Joined Mar 2009
I use my "flap" switch to control "flaps". In the up possition the flaps deflect in the opposite direction of the elevator. In the switch down position the flaps deflect in the same direction as the elevator.
With this setup I can do all kinds of crazy stuff.
Carlo
PS G.P. yea on the slick I don't use as much as on the Extra cause I have to watch or it can snap out a bit or get squirley fast if the plane isn't flying at the correct speed. I wouldn't suggest it on the Slick unless you are very comfortable with it already.
Old Dec 29, 2009, 09:40 AM
Jeff_edge540 is offline
Find More Posts by Jeff_edge540
Mis-guided heli guy
Jeff_edge540's Avatar
Austin, TX USA
Joined Mar 2007
Aside from flaps...
The AR500 does not allow for sub-trim or travel limit adjustments on the other channel.
So unless your servo is setup *exactly the same as the other wing and is perfectly centered, you will not be able to adjust out aileron differential (axial rolls).
Jeff_edge540 is offline Find More Posts by Jeff_edge540
Old Dec 29, 2009, 01:17 PM
starzen is offline
Find More Posts by starzen
starzen's Avatar
USA, FL, Stuart
Joined Jul 2009
two words
LOVE IT
had my maiden on sunday and two more flights today. It is absolutely amazing
Now i need some more packs ...
starzen is offline Find More Posts by starzen
Old Dec 29, 2009, 01:40 PM
sukhoi26mx is offline
Find More Posts by sukhoi26mx
Scott Stoops
sukhoi26mx's Avatar
United States, CO, Longmont
Joined Mar 2002
Glad you like it!
sukhoi26mx is offline Find More Posts by sukhoi26mx
Old Dec 29, 2009, 01:54 PM
i love nachos is offline
Find More Posts by i love nachos
Some Sharp Looking Cheddar
i love nachos's Avatar
Cleveland, OH
Joined Aug 2008
Originally Posted by starzen View Post
two words
LOVE IT
Can't wait to build mine!
i love nachos is offline Find More Posts by i love nachos
Old Dec 29, 2009, 11:59 PM
cayars is offline
cayars's Avatar
Bridgeton, NJ
Joined Mar 2009
Originally Posted by sukhoi26mx View Post
Glad you like it!
How can we not? It's a superb airplane!
Carlo
PS BTW, Scott of all the planes offered by 3DHS (by U or AJ) what is your favorite plane in the 5X-7X" size?
New Product 3D Hobby Shop 47" Edge 540 #BUILD VIDEOS ADDED# ipsmotors 3D Flying 3960 Nov 23, 2013 07:39 PM
Video 3D Hobby Shop 57" Sukhoi sukhoi26mx Electric Plane Talk 7 Sep 17, 2008 08:33 AM
Sold NIB 3D Hobby Shop SHP Extra 300 *Blue* Version 2 thomer Aircraft - Electric - Airplanes (FS/W) 7 May 04, 2008 01:31 PM
Build Log 3D Hobby Shop 55" Katana LIVE Build Log Jeremy Sebens 3D Flying 54 Oct 12, 2007 03:39 PM
