Old Dec 16, 2009, 11:45 PM
routemech is offline
Find More Posts by routemech
shredding Ultracote since 2009
routemech's Avatar
Frederick CO
Joined Jul 2009
Originally Posted by tjhawker View Post
IMO - Start at 2-3% right rudder to full throttle and increase as needed. If you need help making the mix or getting the mix setup right, let me know. I'll probably be down around that area at some point throughout the weekend. I know there's other guys at LAMA who use that mix and would probably be glad to help as well.
Thanks for the help I really appreciate it, I will try the 2% to start...
I hope to make it to LAMA tomorrow around 11-12 to test it out (Some lunch time flying), I need to take advantage of the nicer weather. I will probably be out this weekend also.
routemech is offline Find More Posts by routemech
Old Dec 17, 2009, 01:25 AM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Hi Guys...
Finished mine completely today...I have my receiver mounted on the battery tray, and onto the wing tube, and with a Thunderpower 4S 3850mAH 30C pack, it balanced right at 110mm with the pack about a 1/2" in front of the receiver. So...I little room for moving the CG back if I want, but figured I'd start where the instructions said.
Now I just have to get some decent weather to maiden her... The rain is letting up, but the weatherman is saying thick fog in the morning...maybe once it burns off, the weather will co-operate and I'll get to fly. I'm really having withdrawal symptoms, as I haven't flown in more than a month, between a bad cold, and the weather...
Now I have to decide...finish my 70" Slick, or build my Red 47" Edge, or build up a new fuselage to replace the damaged one for my red 55" Yak..the wings are ready to go, just have to put the fuselage together.... decisions, decisions, decisions...
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Dec 17, 2009, 05:54 AM
starzen is offline
Find More Posts by starzen
starzen's Avatar
USA, FL, Stuart
Joined Jul 2009
what starts with 1Z, originates in TX and comes triple boxed ?
and because it will arrive in a few days it doesnt count as a christmas present
starzen is offline Find More Posts by starzen
Old Dec 17, 2009, 07:23 AM
BustedBlades is offline
Find More Posts by BustedBlades
Fear is the mind killer
BustedBlades's Avatar
United States, LA, Lafayette
Joined Dec 2008
can someone please explain what throttle-rudder mix is for and how you know if you need it?
Matt
BustedBlades is offline Find More Posts by BustedBlades
Old Dec 17, 2009, 07:48 AM
Lonelasso is offline
Find More Posts by Lonelasso
Lonelasso's Avatar
United States, TX, Austin
Joined Dec 2006
Matt
Adds additional (without adding a washer or 2) RIGHT thrust to help with hover
Lonelasso is offline Find More Posts by Lonelasso
Old Dec 17, 2009, 07:52 AM
Joined Dec 2008
so i assume it adds a little right?
How does the DX7 mix this? linearly? Step (25,50,75,100%)
Old Dec 17, 2009, 08:02 AM
Lonelasso's Avatar
Joined Dec 2006
Program mix....don't recall if 1-4, or any/all can be used. 1% steps
Old Dec 17, 2009, 08:11 AM
jadamian75 is offline
Find More Posts by jadamian75
jadamian75's Avatar
Fort Collins Colorado USA
Joined Oct 2007
See you there!
Joe
jadamian75 is offline Find More Posts by jadamian75
Old Dec 17, 2009, 08:48 AM
Doc Austin is offline
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Yes. Old school pilots are more comfortable making thrust adjustments than playing with mixes. It's simply a matter of having always done it a certain way and being too stubborn to accept the new ways. I'm getting better about it, but getting older just sinks you deeper into not wanting to change.
I could never figure out why why old people are so stubborn to acdept the new ways when those new ways make life easier, but getting older is bringing a new understanding.
Sometimes you can't get out of it like in the case of planes balooning on landing. You can take out some downthrust, but then it screws up the balancein hovering. It's much the less of two evils to add a low/throttle/down elevator mix because it only comes in at low throttle. This mix also makes the plane fall much more vertically on power offdownlines. Of course, we never did it that way when we were you studly turks, so it can't be any good. Right?
I can't believe I am saying this. It is hard to accept the world has changed so much I no longer recognize it. This stubborness has really held me back. I know for a fact that taking out the down thrust killed any chance I had of getting a good hover. As soon as I left the down thrust alone and used the low throttle/down elevator mix to stop balooning, my hover instantly got better. Set up is absolutely everything. You need a superb airfame, but a bad set up can still ruin it.
It's all down to a preferance. The thrust on these planes are usually dead one, but I am more comfortable doing less work with the rudder to keep the plane straight in harriers and such. Guys like Tyler just fly the plane and can put it where they want it without thinking. Old guys like me aren't as sharp on the rudder and need a plane that tracks perfectly and isn't affected by torque and P factor as much. I dial those things out with a little thrust.
Of course, this is probably wrong, but whatever works for you is right. Mostly I trim the plane to overcome my own weaknesses. Why not? Let the plane do the work instead of fighting it and hanging on the whole flight.
Doc Austin is offline Find More Posts by Doc Austin
Old Dec 17, 2009, 08:53 AM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
I believe on the DX7 there are several pre-mixes (six, I think) that you can set to do anything you like. The Futaba 7C has three, but it really needs more.
Old Dec 17, 2009, 08:59 AM
RC4x4 is offline
Find More Posts by RC4x4
Fly Low or you'll never know!
RC4x4's Avatar
Thornton, Colorado
Joined Jul 2002
Originally Posted by jadamian75 View Post
See you there!
Joe
What ever!
RC4x4 is offline Find More Posts by RC4x4
Old Dec 17, 2009, 09:24 AM
Joined Dec 2008
thx guys!
Old Dec 17, 2009, 09:29 AM
sun.flyer is offline
Find More Posts by sun.flyer
Test your skills....fly IMAC!!
sun.flyer's Avatar
Swanton, Ohio
Joined Feb 2005
Correct, the DX-7 only offers linear mixing (no curves until you get to 9303's).
Any of the open mixes will allow you to put in a throttle (master) and rudder (slave) mix. Start with a low percentage at first and adjust as needed. Beats taking the cowl offer everytime and adding spacers/washers/standoffs to adjust the thrust angle.
Tim
sun.flyer is offline Find More Posts by sun.flyer
Old Dec 17, 2009, 09:45 AM
Joined Dec 2008
thats why I gave up watching the news.
Old Dec 17, 2009, 10:30 AM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Uhhh, well the news just makes me angry.
New Product 3D Hobby Shop 47" Edge 540 #BUILD VIDEOS ADDED# ipsmotors 3D Flying 3960 Nov 23, 2013 07:39 PM
Video 3D Hobby Shop 57" Sukhoi sukhoi26mx Electric Plane Talk 7 Sep 17, 2008 08:33 AM
Sold NIB 3D Hobby Shop SHP Extra 300 *Blue* Version 2 thomer Aircraft - Electric - Airplanes (FS/W) 7 May 04, 2008 01:31 PM
Build Log 3D Hobby Shop 55" Katana LIVE Build Log Jeremy Sebens 3D Flying 54 Oct 12, 2007 03:39 PM
