Old Dec 14, 2009, 03:58 PM
Lonelasso is offline
Find More Posts by Lonelasso
Lonelasso's Avatar
United States, TX, Austin
Joined Dec 2006
Where are y'all placing the pack (4s-3300-4000) with the GR60 ?
THX !
Lonelasso is offline Find More Posts by Lonelasso
Old Dec 14, 2009, 04:00 PM
blucor basher is offline
Find More Posts by blucor basher
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
United States, TX, Tyler
Joined Jun 2003
Dennis - Use a throttle-rudder mix instead of adding washers to the motors, IMO, easier to tune and just as effective.
blucor basher is offline Find More Posts by blucor basher
Old Dec 14, 2009, 04:06 PM
Knotnuts is offline
Find More Posts by Knotnuts
Knotnuts's Avatar
Joined May 2008
This is one great airframe, ain't it!!
Knotnuts is offline Find More Posts by Knotnuts
Old Dec 14, 2009, 04:18 PM
Dennis C is offline
Find More Posts by Dennis C
Dennis C's Avatar
Grass Valley California
Joined Jun 2004
Ben
Thanks, I have a 13% throttle rudder mix in, I just thought that with a little more right thrust I would not need quite as much mix. I do not have the mix on a curve and it seems to need it a litte earlier at the half throttle hover position.
Ps Steve say's thanks for the replacement canopy,, great 3DHS customer service
Dennis
Dennis C is offline Find More Posts by Dennis C
Old Dec 14, 2009, 06:00 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Hi Guys....
Since I am going to use my sons decals until I can get another set, I have a question for those that have used them.
Did you use a soap/water mix and then squeegee the water out, or just apply them dry with another person helping or what???
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Dec 14, 2009, 06:06 PM
Hypersprint is offline
Find More Posts by Hypersprint
Lets Make a Deal
Hypersprint's Avatar
Parrish, FL
Joined Apr 2008
Originally Posted by Draknkep View Post
Hi Guys....
SteveT
Here is a link to ADC Decal Installation
Rob
Hypersprint is offline Find More Posts by Hypersprint
Old Dec 14, 2009, 06:12 PM
SteveT.'s Avatar
San Jose, CA
While I appreciate that link, I am asking about the decals that come with the kit, not ADC vinyl ones...
SteveT
Old Dec 14, 2009, 06:18 PM
ambientech is online now
Find More Posts by ambientech
ambientech's Avatar
Central Texas
Joined Jun 2008
The normal 3dhs decals I just peel and stick. I have in the past used the soap water mix on this type of decal and it works great. I do not know if it is recommended to do this though.
ambientech is online now Find More Posts by ambientech
3D-Dabbler is offline
Find More Posts by 3D-Dabbler
Just "hanging" Around
3D-Dabbler's Avatar
Richmond, VA
Joined Oct 2009
I just slapped them on there. I applied them pretty close to the ADC instructions linked above except that I didn't clean the surface before hand and I didn't use tape to align them. I didn't need a 2nd person.
They seem to stick just fine and don't have any wrinkles.
-Mike
3D-Dabbler is offline Find More Posts by 3D-Dabbler
Old Dec 14, 2009, 06:21 PM
SteveT.'s Avatar
San Jose, CA
Hi Guys...
Thanks for your responses...
SteveT
Old Dec 14, 2009, 06:55 PM
Fliprob17 is offline
Find More Posts by Fliprob17
ADC Vinyl
Fliprob17's Avatar
SoCal-Rancho Santa Marg.
Joined Mar 2007
make sure your hands are clean, oil/dirt free, those clear decals suck up all the oil from your fingers if it's on there and you will see it once they are installed.
make sure the plane is clean, Windex and a paper towel are fine, then just blow off the paper towel lint.
cut, peel, stick - I have always preferred the dry method, seems to last longer and the decals don't play slip and slide while you are trying to position them. The big wing decals require an additional pair of hands to keep them from rolling up and getting ruined by sticking to themselves. If you don;t have a helper, then the wet method might make sense here.
Fliprob17 is offline Find More Posts by Fliprob17
Old Dec 14, 2009, 07:46 PM
TexasFlyer is offline
Find More Posts by TexasFlyer
TexasFlyer's Avatar
Houston, TX
Joined Sep 2005
Draknkep: I used the wet (Windex) method for the main wings and I'm really glad I did. Those are really big and I found them difficult to place exactly where I wanted them.
Dennis: I, too, needed a lot of throttle to rudder mixing. I started with a washer and switched to TX mixing as Ben suggested. While not perfectly linear (as you mentioned), it's easy enough to adjust with my thumbs. Before the mixing, though, it was making a number of manuevers more difficult than they needed to be.
All: It always takes me a while to get comfortable with a new plane but I'm really loving the 330SC now! The rolling harriers are REALLY nice & predictable and I'm starting to bring it lower and lower. High Alpha KE is very easy and consistent with the SFGs, though as Dennis mentioned a little R --> E mixing helped make it perfect. This plane also waterfalls and elevators better than any other plane. And it blenders/flat spins better than any other than my QQ 69" Yak which is perfectly flat. The plane really does instill confidence like none other! I just hope it doesn't instill OVER-confidence
Alan
TexasFlyer is offline Find More Posts by TexasFlyer
Old Dec 14, 2009, 09:30 PM
Stagger_Wing is offline
Find More Posts by Stagger_Wing
For the Birds
Stagger_Wing's Avatar
California
Joined Jul 2004
I received the Scorpion 4020-10 and installed it today. It works better with the ICE than the Reaper however it is still not perfect. There is some weirdness near full throttle. I will test fly it as soon as it stops raining and report back. Settings are V2.16, 8khz, timing 0,
Stagger_Wing is offline Find More Posts by Stagger_Wing
Old Dec 14, 2009, 09:44 PM
Lonelasso's Avatar
Joined Dec 2006
Which pack ? I'm using the 4020-10 w/15x8 APC on 2x4S-2350s (parallel). 75A/1060W SS 100A ESC
Old Dec 14, 2009, 10:00 PM
cayars is offline
Find More Posts by cayars
cayars's Avatar
Bridgeton, NJ
Joined Mar 2009
Originally Posted by Dennis C View Post
Ben
Dennis
FWIW (for what it's worth) I'll do the throttle/rudder mix out at the field. Then when I'm back at home and have time to adjust things "properly" I'll add a washer or two to shim the motor so I won't need the mix.
At the field, if you need it, you need it, so add it but when you have time to adjust the airframe and parts accordingly so it fly's "neatrral" so be it.
Carlo
cayars is offline Find More Posts by cayars
New Product 3D Hobby Shop 47" Edge 540 #BUILD VIDEOS ADDED# ipsmotors 3D Flying 3960 Nov 23, 2013 07:39 PM
Video 3D Hobby Shop 57" Sukhoi sukhoi26mx Electric Plane Talk 7 Sep 17, 2008 08:33 AM
Sold NIB 3D Hobby Shop SHP Extra 300 *Blue* Version 2 thomer Aircraft - Electric - Airplanes (FS/W) 7 May 04, 2008 01:31 PM
Build Log 3D Hobby Shop 55" Katana LIVE Build Log Jeremy Sebens 3D Flying 54 Oct 12, 2007 03:39 PM
