Old Dec 07, 2009, 06:21 AM
Doc Austin is online now
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Originally Posted by lonelasso View Post
Shot this today...nuttin hair raising, still shaking 'er down
http://www.vimeo.com/8024192
Looks like you got everything sorted out pretty quickly, but anything Eddie flies is going to look good.
Doc Austin is online now Find More Posts by Doc Austin
Old Dec 07, 2009, 06:25 AM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Originally Posted by Dennis C View Post
To get the most effecient servo set up:
Set the end point adjustment in the transmitter to 140%
install the push rod to the contro horn on airplane (the extra 330 only has one hole)
Use the hole on the servo arm closest to the center that will give you the desired throw in high rate.
This will give you the best resolution and servo power
I'm going to save this and repost it when people want to know about set up. Very well written and easy to understand.
Old Dec 07, 2009, 07:54 AM
Lonelasso is offline
Find More Posts by Lonelasso
Lonelasso's Avatar
United States, TX, Austin
Joined Dec 2006
Think I'll try 16 x 8 APC Chris (Chribrian) started the flight and handed off to Eddie. Chris is rapidly evolving into a JEDI master
Lonelasso is offline Find More Posts by Lonelasso
Old Dec 07, 2009, 09:39 PM
heritageflyer is offline
Find More Posts by heritageflyer
Time to Fly AJ's Best!
heritageflyer's Avatar
Hills of Eastern Ohio
Joined Nov 2008
Looks like that Hybrid flys pretty nice!
heritageflyer is offline Find More Posts by heritageflyer
Old Dec 07, 2009, 11:46 PM
ipsmotors is offline
Find More Posts by ipsmotors
3DHS Junkie
United States, CA, Fullerton
Joined Nov 2007
As with the rest of the line up, the 57" SC is one tough airframe. How do I know?
Well, IPS jr got to experience his first "Bonedoc" on Sat.
He yells out "dad I have no control".
I run up, look for the plane & grab the Tx.
"Yup, you're right son, there's no control. Good thing you're in an inverted flat spin. We'll go get it when it hits."
About 15 seconds later it finally came down. Broke the prop, cracked the cowl & motor box. Canopy, rudder, fuse wings, etc are all good.
He had just done a KE spin before he lost control. We found the positive battery lead broken off @ the Deans.
ipsmotors is offline Find More Posts by ipsmotors
Old Dec 08, 2009, 12:29 AM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Well...if you're going to crash...that ain't bad!!
That is why I wish Deans plugs had solder cups on them instead of just tabs. (and yes, I know about the Atlanta Hobbies solder cups, but that's just one more solder connection)
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Dec 08, 2009, 07:52 AM
Hypersprint is offline
Find More Posts by Hypersprint
Lets Make a Deal
Hypersprint's Avatar
Parrish, FL
Joined Apr 2008
SteveT
What about the new XT60 Connectors from HC? They have solder cups
Hypersprint is offline Find More Posts by Hypersprint
Old Dec 08, 2009, 07:54 AM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
That is not too shabby!! just goes to show how tough the plane is!And how good your son is to be doing inverted flat spins so tight and flat that it comes down so gentle...Way to go ISP JR!!
Manta1 is offline Find More Posts by Manta1
Old Dec 08, 2009, 07:58 AM
Lonelasso's Avatar
Joined Dec 2006
+ 1 !! Kevin....maybe take a look at power poles Ask Capt Norway I've been using them for over 2 years now.
Old Dec 08, 2009, 09:26 AM
wedgewing is offline
Find More Posts by wedgewing
Ready, Post, Aim
wedgewing's Avatar
Cleveland, OH
Joined Nov 2007
those look cool
wedgewing is offline Find More Posts by wedgewing
Old Dec 08, 2009, 04:11 PM
ambientech is offline
Find More Posts by ambientech
ambientech's Avatar
Central Texas
Joined Jun 2008
Those look good but I am afraid as soon as I convert to them they will change to another type.
ambientech is offline Find More Posts by ambientech
Old Dec 08, 2009, 05:05 PM
3DHS Junkie
Joined Nov 2007
This was our 1st solder joint failure, not bad when looking at the number of packs & flights we have. I'll look at what's out there as we replace batteries.
Old Dec 08, 2009, 06:20 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Those actually do look good, but I between my son and I we have about 100 batteries that would have to be changed... I am also curious as to why Hobbycity says they will be using them on all their batteries up to 3000mAH, why not above that??? Will they not handle the amps above that??? Deans are good for (according to the person I spoke to at Deans) up to 100 amps.
SteveT
Old Dec 09, 2009, 10:52 AM
Scooter0509 is offline
Find More Posts by Scooter0509
Scooter0509's Avatar
Long Island, NY
Joined Mar 2006
Just to let you guys know I have a GR-60 Brand New never used for sale in the classifieds. I am selling because I decided to go for the 70" size plane so I have no need for it. Reasonable offers are welcome. Thanks
Scott
http://www.rcgroups.com/forums/showthread.php?t=1153926
Scooter0509 is offline Find More Posts by Scooter0509
Old Dec 09, 2009, 10:53 AM
BOBBY1017 is offline
Find More Posts by BOBBY1017
BOBBY1017's Avatar
Petaluma, Ca.
Joined Mar 2006
I had the same thing happen with my 55" shp, the pos lead came unsoldered from the deans, the solder melted. I'm not sure why. I was hovering about 40feet up Plane was trashed. After approx 500 flight's I wonder why it came loose?
BOBBY1017 is offline Find More Posts by BOBBY1017
New Product 3D Hobby Shop 47" Edge 540 #BUILD VIDEOS ADDED# ipsmotors 3D Flying 3960 Nov 23, 2013 07:39 PM
Video 3D Hobby Shop 57" Sukhoi sukhoi26mx Electric Plane Talk 7 Sep 17, 2008 08:33 AM
Sold NIB 3D Hobby Shop SHP Extra 300 *Blue* Version 2 thomer Aircraft - Electric - Airplanes (FS/W) 7 May 04, 2008 01:31 PM
Build Log 3D Hobby Shop 55" Katana LIVE Build Log Jeremy Sebens 3D Flying 54 Oct 12, 2007 03:39 PM
