Go Back   RC Groups > Boats > Scale Boats
Old Oct 03, 2009, 09:42 AM   #61
Cheif Bottlewasher
more coffee's Avatar
Little more progress ..made a motor mount out off some scrap aluminium left behind by the sparkies at work ..
Its the first time I fabbed a motor mount ..OHH and it had to be for twin screw..
  • Name: PA020329.JPG
  • Name: PA020328.JPG
more coffee is offline Find More Posts by more coffee   Reply With Quote
Old Oct 03, 2009, 01:05 PM   #62
Cheif Bottlewasher
Motor's and mount in place ..PL Premium was the glue, bonds wood ,metal ,foam ,finger's and eyelids
  • Name: PA030330.JPG
  • Name: PA030331.JPG
Old Oct 03, 2009, 01:37 PM   #63
Grumpa Tom
Kmot's Avatar
Looks like a powerful, beastly setup!
Kmot is offline Find More Posts by Kmot   Reply With Quote
Old Oct 03, 2009, 03:53 PM   #64
Cheif Bottlewasher
Thanks Kmot... I really hope so ..the motor's turn about 3600-5000rpm ..they have gob's of torque
I'll see how she handles the 3 blade prop's ..if all is well I'll switch out for the same style only 4 blade , maybe 5 blade ..
Churn and burn
Old Oct 03, 2009, 06:00 PM   #65
Cheif Bottlewasher
Here's some shots of the greaser I use to lube my tube's ..I got it from a Stihl chainsaw dealer years ago to lubricate the hammer's in my impact gun ..
I fill it with white grease for the boats ..easily shoots grease in the tube with little pressure ..Its just a little pusher pumper
  • Name: PA030332.JPG
  • Name: PA030333.JPG
Old Oct 03, 2009, 07:02 PM   #66
Cheif Bottlewasher
Well everything being equal ..the salvaged motor isnt doing its thing ..after 5 minutes of operation ..it gets warmer than the new one..and is noticeably slower than the new one i had installed ...
Need to find some overtime ..some where ..
Old Oct 05, 2009, 06:01 PM   #67
Cheif Bottlewasher
A little more progress.. the lower superstructure .. untill my leds show up I cant put the roof on ..
The build here differ's from the plan ..the 1/8 ply supplied was lame and when wetted to bend the veneer began to lift and the grain raised everywhere ..So i swapped it out with 1/16 Midwest ply ..really made a difference in bending around the front of the structure. I used the 1/8 ply to bolster the aft bulkhead ....approx 2 inches ..thats all ..
the wheel house, mast ,funnel are next again pending the leds.
  • Name: PA040334.jpg
  • Name: PA040335.jpg
  • Name: PA040336.jpg
Description: here ..in the rear of the structure ..the last bit behind the rearmost bulkhead is where i added the extra 1/8 ply ..just to give it width and strenght here ..in the rear of the structure ..the last bit behind the rearmost bulkhead is where i added the extra 1/8 ply ..just to give it width and strenght 79.7 KB · Views: 45
  • Name: PA050337.jpg
Description: There's gotta be room for one more clamp There's gotta be room for one more clamp 87.5 KB · Views: 48
Old Oct 11, 2009, 09:14 PM   #68
Cheif Bottlewasher
No spectacular progress but some ..
  • Name: PA110338.jpg
  • Name: PA110339.jpg
Old Oct 11, 2009, 09:52 PM   #69
Grumpa Tom
Kmot's Avatar
Slow and sure will get the job done!
Old Oct 12, 2009, 10:53 AM   #70
Cheif Bottlewasher
Thanks Kmot..
The water intake for the fire monitor is fabbed ..as per Umi's suggestion.The screen is stainless ..from an aerator out of a facet ..$3 at Crappy Tire for the whole assembly ..It should be noted that Stainless steel cannot be soldered .but one can sink it in a pool of molten solder ...it was all i could find..
I used two grommets ..the idea is i will obtain two beads of epoxy to seal the joint ..i do plan to use an extra piece of ply-wood to add some strength against the hull ..
I also lightly tapped the inside collar ( short one) to bring it out-off-round ...this allows the two pieces to be pressed tightly and need not be clamped ..just a little interference fit .. I have an extra piece of tube same I'D' as the sleeve to push it down
Anybody remember the thread where the builder made his own ladder's ?..think it was a Model Slippway's kit and it was a tug ...really like to see that again ..
  • Name: PA110341.JPG
  • Name: PA110342.JPG
Old Oct 12, 2009, 12:32 PM   #71
Grumpa Tom
Kmot's Avatar
That's a lot of work and bother just for a water intake isn't it?? Or is it supposed to be a scale looking and working thing?
Heck, it if were me I would just have used any old water cooling style pickup. And if worried about detritus in the incoming water I would simply install an inline filter in the silicone tubing.
http://www.greathobbies.com/producti...od_id=DTXC2551
Old Oct 12, 2009, 02:59 PM   #72
Cheif Bottlewasher
Hi Tom .. yes and no on the bother ..I do want it to look right or at least semi- to what it should look like ....I have a windshield washer pump to make for a working monitor
A few years ago i sacked the hobby store they had K&S Engineering bags (4 of them ) on the shelf, loaded with end cuts and shapes .... each bag was 8 bones ..so for 32 bones i got about 5 pound of brass and aluminium stuff.. i have a ton of loose stuff floating around..
To tell you the truth Tom for what it is i had figured on using just a regular fuel filter from Wall-mart ..or pillaging the one from my lawn mower..It about as big around as a quater ..maybe a tad bigger ..
http://www.northerntool.com/webapp/w...1574_200271574
Everything said and done it took less than 10 minutes to whip one together ..
If I hadnt asked permission and wasnt so picky years ago ..I would be spinning these out on a lathe ...
Old Oct 12, 2009, 03:09 PM   #73
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
But it looks coool!
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki   Reply With Quote
Old Oct 12, 2009, 03:11 PM   #74
5 copies for my mother...
patmat2350's Avatar
I thought about doing one "right", haven't gotten around to it yet!
Real water pick-ups are "sea chests"... basically a boxed in space over a hole in the hull, and the hole is covered with a grating (imagine a storm sewer grating; keeps the tuna out).
Here's one:
http://www.teara.govt.nz/en/marine-i...2/1?setlang=mi
patmat2350 is offline Find More Posts by patmat2350   Reply With Quote
Old Oct 12, 2009, 04:26 PM   #75
Cheif Bottlewasher
Sea chest ...yes ..thats the term i was grappling with ...
And your right not really a authentic representation on my part ..but in my defense, I havent been able to find shots of Shelly in dry dock ....
Next time though ..
Discussion 36" dumas shelly foss motor question? cain8885 Scale Boats 5 Nov 23, 2008 05:44 PM
Build Log 36" Shelly Foss build more coffee Scale Boats 17 Nov 18, 2008 12:14 AM
Sold Dumas Shelly Foss 36" Kit sleepwalker Boats (FS/W) 0 Jan 20, 2008 05:44 PM
Help! Shelly Foss 36" plans sleepwalker Scale Boats 0 Jan 01, 2008 02:32 PM
Discussion Shelly Foss 36" sleepwalker Scale Boats 3 Dec 18, 2007 09:21 PM
Bored? Want to fight?
Join the RCGroups clan!
