Go Back   RC Groups > Boats > Scale Boats
Old Sep 18, 2009, 06:58 PM   #31
Cheif Bottlewasher
more coffee's Avatar
I did it cheaper than that ..
I was cool here last night ..and I decided to light up the wood stove ..theres a nook that the basement door is in and its a high spot in the basement ...nail in wall ,hung the girl up ..got the fire going ..turned up the stove fan .. left the through door open..after an hour it was 38C up there where the boat was .. ..left it there all night ..this morning was much better ..and this evening she's solid as a rock ..
So thanks toes and dnchvs for calming the nerves .... once shes cleaned up and primed ..running gear in its place ..I'm gonna resin the inside as well ..
more coffee is offline Find More Posts by more coffee   Reply With Quote
Old Sep 18, 2009, 08:36 PM   #32
King of The Moon
ozoneone's Avatar
Originally Posted by more coffee
OK ..tell me how its done !!!!!
well, i'm no expert. there's much better qualified out there on this forum. but my resin (from home depot) says 14 drops per oz. i used 7 fl oz. for my hull. 7 1" bristle brushes and 7 1 oz mixing cups. lay the cloth on dry, and work your way into corners and crevices. stop when the resin thickens and start a new batch. be sure where you stop the fg is flat against the wood. dries in about ten minutes. mix another batch and continue. when hull is covered, trim FG cloth and sand high spots and entire surface and then apply more resin until surface is uniform. try not to sand through the fg. if necessary, fill low spots with bondo and apply more resin. looks like you're well on your way. hopefully tomorrow will warm and dry so i may finish. good luck to both of us!
ozoneone is offline Find More Posts by ozoneone   Reply With Quote
Old Sep 18, 2009, 08:50 PM   #33
jjac's Avatar
It will be easier on you if you will put one coat of resin on the wood first and let it cure out. The first coat seals the wood. After it is cured apply another thin coat, then apply the cloth and a wet coat on top of the cloth. By applying the cloth on top of a wet coat you are less likely to get air bubbles. While its still wet use a fiberglass roller and roll over the surface to get all of the air bubbles out.
jjac is offline Find More Posts by jjac   Reply With Quote
Old Sep 18, 2009, 11:09 PM   #34
King of The Moon
ozoneone's Avatar
wow. sounds like a good plan, but a lot of work. i have a seguin by midwest tug i built more than ten years ago by my method and pretty perfect finish with no problems so far. but your method sure seems thorough. no air bubbles if you work in small increments, and good adhesion directly into the fibers of the wood. whatever works!
Old Sep 19, 2009, 09:52 AM   #35
Cheif Bottlewasher
Another question
What do you guy's/gals use for a bulkhead fitting to hook up a fire monitor?
I had thought about flaring a piece of brass tube ..but its so thin i wouldnt be able to thread it to get a tight fit against the hull..also it wouldnt have a barbed fitting on the end ..meaning the hose would be at risk of comming of ..
Thinking i should use a screen or filter ..probabley one of those cheapie inline fuel filters at Wall Mart..you know the clear canister type...
Old Sep 19, 2009, 10:06 AM   #36
jjac's Avatar
I agree, whatever works!!
Old Sep 19, 2009, 01:46 PM   #37
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
Another question
Solder a washer, or brass finish washer to the end of a brass tube, and
solder some mesh over the opening to screen the water.
Then solder another washer to a second tube that will telescope over the first. Once the first tube has been run through the hull and glued in place,
the second tube will slide over the first tube on the interior, and can be
epoxied, or fiberglassed into place.
  • Name: P1010104 copy.jpg
Description: A silver soldered brass tube and washer with a fine brass mesh soldered across the end A silver soldered brass tube and washer with a fine brass mesh soldered across the end 42.7 KB · Views: 60
  • Name: P1010106 copy.jpg
  • Name: P1010108 copy.jpg
Description: Ready for installation... Plywood backing plate for the interior. I often step the tubes down, so the intake is a larger tube, and provides a bit wider base of support than the actual plumbing. Ready for installation... Plywood backing plate for the interior. I often step the tubes down, so the intake is a larger tube, and provides a bit wider base of support than the actual plumbing. 37.3 KB · Views: 44
  • Name: P1010109 copy.jpg
Description: Exterior of the installation in a Tito Neri. Exterior of the installation in a Tito Neri. 25.1 KB · Views: 55
  • Name: P1010037 copy.jpg
Description: Interior of the Fireboat. This used a second brass washer soldered to a large diameter tube, and set over the  first, exterior half of the bulhead, soft soldered, then fiberglased in place. Interior of the Fireboat. This used a second brass washer soldered to a large diameter tube, and set over the first, exterior half of the bulhead, soft soldered, then fiberglased in place. 96.2 KB · Views: 74
  • Name: P7300030 copy.jpg
Description: Exterior of the Fireboat. One of three... Exterior of the Fireboat. One of three... 41.0 KB · Views: 50
  • Name: P1010091 copy.jpg
Description: Finish washer, and brass mesh silver soldered to brass tube. Finish washer, and brass mesh silver soldered to brass tube. 58.8 KB · Views: 58
  • Name: P1010092 copy.jpg
Description: Bulkhead mounted to the SDM tug... Bulkhead mounted to the SDM tug... 74.7 KB · Views: 43
  • Name: P1010095 copy.jpg
Description: Feed for the monitors comes up the vertical support to the deck, not the "actual" stand pipes. Feed for the monitors comes up the vertical support to the deck, not the "actual" stand pipes. 56.2 KB · Views: 52
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki   Reply With Quote
Old Sep 19, 2009, 05:51 PM   #38
Cheif Bottlewasher
Thank you for that tutorial Umi !! ..I know where to get the brass parts ..
The screen looks alot like the stuff used in Diesel fuel pre-filter's/water separators ..I'll go with that ..there's a shop next door to work I can get them out of the dumpster
What did you use to secure the hose to the brass tube?
In the mean time Ive sanded the high spots of the hull ..now I'm doing my impression of "Cake Boss" and iced the whole thing with a skim coat of bondo..(wait till you see my choclate filling ---EP2 GLI ) .. I'll sand it with 150grit ..a little spot putty .primer and i can move into the engine room and start fitting her out ..
Old Sep 19, 2009, 08:29 PM   #39
Sea Dragon-Lover
To secure the hose to the bulkhead, I solder a brass collar over the
top of the intake tube. The hose has to be forced over it and then
down onto the smaller tube proper... Then I wrap it with a zip tie.
Old Sep 20, 2009, 08:04 PM   #40
Cheif Bottlewasher
A little more progress...
And hit the hardware store for a few bits to build a bulkhead inlet for the monitor as Umi suggested..
  • Name: P9200303.jpg
  • Name: P9200308.jpg
  • Name: P9200304.jpg
  • Name: P9200309.jpg
  • Name: P9200305.jpg
  • Name: P9200310.jpg
  • Name: P9200307.jpg
  • Name: P9200311.jpg
Old Sep 20, 2009, 09:41 PM   #41
Hey coffee, that hull is lookin great.
catfishchaser is offline Find More Posts by catfishchaser   Reply With Quote
Old Sep 21, 2009, 05:29 PM   #42
Cheif Bottlewasher
Thanks catfish ....power tools make a huge difference...As it stands there it needs some spot putty , a finer sanding ..another shot of primer and the base coat
What bug's me now though is where to get satin finish oxide red paint not primer..and exterior at that ..ever use actual hull paint ?
More to figure out ..
Also I think its X-nay on the gear box and motor....
I noticed a motor on one of the fan's in the tractor ..rather big ,,swings a 6 inch fan , its not a blender motor it may spin 4000/4500rpm,and dosent pop a 5 amp fuse even after all day on bust.. the whole fan is 20$ at the shop ..I may go with a pair of those direct ..versus the Dumas gear...
My props are 2 1/2 inch ..should be OK ..I think or it may be a Viking funeral for Shelly
Old Sep 21, 2009, 10:01 PM   #43
i got 3 inch props for mone
but i haven't finished the hull yet it's ready for glass
the dumas gears are soooo loud
dennischaves is offline Find More Posts by dennischaves   Reply With Quote
Old Sep 22, 2009, 05:45 PM   #44
Cheif Bottlewasher
This is the general propulsion arrangement
Dumas 2 1/2 in prop ,shaft, and stuffing box..
Dumas dog bone connector
the motor came out of a fan ..
12V ,2 in dia, 2 3/4 long ..12 poles, 1/4 shaft
Think it will swing the props with some to spare... ya tink's
  • Name: P9220312.jpg
  • Name: P9220313.jpg
  • Name: P9220314.jpg
  • Name: P9220315.jpg
  • Name: P9220317.jpg
Old Sep 22, 2009, 07:02 PM   #45
Grumpa Tom
Kmot's Avatar
That motor looks pretty stout to me!
Do you have an ammeter?
Kmot is offline Find More Posts by Kmot   Reply With Quote
Discussion 36" dumas shelly foss motor question? cain8885 Scale Boats 5 Nov 23, 2008 05:44 PM
Build Log 36" Shelly Foss build more coffee Scale Boats 17 Nov 18, 2008 12:14 AM
Sold Dumas Shelly Foss 36" Kit sleepwalker Boats (FS/W) 0 Jan 20, 2008 05:44 PM
Help! Shelly Foss 36" plans sleepwalker Scale Boats 0 Jan 01, 2008 02:32 PM
Discussion Shelly Foss 36" sleepwalker Scale Boats 3 Dec 18, 2007 09:21 PM
Bored? Want to fight?
Join the RCGroups clan!
