Go Back   RC Groups > Boats > Scale Boats
Old Sep 17, 2009, 11:29 AM   #16
Cheif Bottlewasher
more coffee's Avatar
Originally Posted by ozoneone
that's exactly what i am doing on my Lord Nelson Tug! just glassed it monday, now i need a few more coats poly resin. i don't much like glassing so i'm happy it's done. raining since though and no poly indoors!
OK ..tell me how its done !!!!!
more coffee is offline Find More Posts by more coffee   Reply With Quote
Old Sep 17, 2009, 01:46 PM   #17
Cheif Bottlewasher
Ohhhh Bouy !!!!
some quick reading ..and some note's ..I glassed the old girl ..
It got real sticky ..i ended up using my hands ( with rubber glove's) to move the Resin around ..and Kmot was right in one of his post..a healthy ..not so much generous helping of resin keeps everything from moving ..
Now only to hope it set's up ..
  • Name: P9170301.JPG
  • Name: P9170302.JPG
Old Sep 17, 2009, 02:39 PM   #18
r/c ships and workboats
If you get the chance trim the excess off just as the stuff is setting to the cosistancy of butter with a sharp tool. Makes clean up of the hull easier.
keith S is offline Find More Posts by keith S   Reply With Quote
Old Sep 17, 2009, 02:47 PM   #19
Cheif Bottlewasher
LOL
Just did ...thanks for the heads up !!!!
Old Sep 17, 2009, 03:07 PM   #20
Grumpa Tom
Kmot's Avatar
Yeah, I try to trim it when it is slightly rubbery.
Kmot is offline Find More Posts by Kmot   Reply With Quote
Old Sep 17, 2009, 04:31 PM   #21
Cheif Bottlewasher
Another Abomination???
How long should it take for this stuff to setup ?
Old Sep 17, 2009, 04:41 PM   #22
about an hour...but it can vary temp how much hardner used and how much you thin it
your build looks good...makes me want to glass my foss hull
did the cloth need a lot of releif cuts to lay down?
dnchvs is offline Find More Posts by dnchvs   Reply With Quote
Old Sep 17, 2009, 04:54 PM   #23
Cheif Bottlewasher
3 drops hardner / 1 ounce of resin . didnt go for the acetone
relief cuts...No not really ..
I laid it on dry, cut a slot for the keel ,took a triangular piece out for the bow ,and slit the stern in the middle..
after i wetted the hull .. i laid on the cloth..and carried on ..kept a razor knife handy to adjust the cuts ...and finaly the whole keel was cut fore to aft when everything was wet and tacky because it bowed up over the keel
Old Sep 17, 2009, 05:14 PM   #24
USA'd ex Brit
toesup's Avatar
Oh dear...
That might take a while in those temperatures..
I've been using 6 drops / oz... and I'm in California..
toesup is offline Find More Posts by toesup   Reply With Quote
Old Sep 17, 2009, 05:18 PM   #25
Cheif Bottlewasher
I would put it on top of the furnace ...but that would leave me and Shelly to end up sleeping in the shed ..
But it well set up ? ....Right?
A gental flash of the heat gun to move things along ??
Old Sep 17, 2009, 05:38 PM   #26
USA'd ex Brit
toesup's Avatar
Eventually... yes..
I wouldn't go anywhere near it with something that is a source of ignition, not with resin fumes..
Old Sep 17, 2009, 05:49 PM   #27
Cheif Bottlewasher
OK ...Thanks toes ..
I'll have to find a heat source ..the barbque is totally out of the question ...
Thats all I'd need ..to be in the neighbours yard with a door box wrapped around my neck ..
Old Sep 17, 2009, 06:28 PM   #28
i'v also been doing about 6 drops of resin a few weeks abo in about 85-90 degrees
and it set up in about 1 hour
put the hull in the sun to dry it may take a while
i'v also noticed the thicker the resin the quicker it cures...i belive you get more heat build up?
Old Sep 17, 2009, 09:17 PM   #29
Boats on the brain!!
green-boat's Avatar
Put the boat in a cardboard box, poke a hole in it and push a hair dryer into the box. Turn the hair dryer on a low setting and let bake for several hours.
green-boat is offline Find More Posts by green-boat   Reply With Quote
Old Sep 17, 2009, 09:22 PM   #30
good tip phil
Discussion 36" dumas shelly foss motor question? cain8885 Scale Boats 5 Nov 23, 2008 05:44 PM
Build Log 36" Shelly Foss build more coffee Scale Boats 17 Nov 18, 2008 12:14 AM
Sold Dumas Shelly Foss 36" Kit sleepwalker Boats (FS/W) 0 Jan 20, 2008 05:44 PM
Help! Shelly Foss 36" plans sleepwalker Scale Boats 0 Jan 01, 2008 02:32 PM
Discussion Shelly Foss 36" sleepwalker Scale Boats 3 Dec 18, 2007 09:21 PM
Bored? Want to fight?
Join the RCGroups clan!
