Go Back   RC Groups > Boats > Scale Boats
Old Sep 12, 2009, 04:45 PM   #1
Cheif Bottlewasher
more coffee's Avatar
36" Shelly Foss build..revisited
after the initial wreck that was the first Shelly Foss.. i ventured in neck deep to another.
Learning from the multitude of mistakes i make in the last build..I laid off the beer ..put down the coffee for a moment and got a little dirty ..I pretty much have conquered the hull..
A carpenter I am not ..thats for sure but intent on seeing this through.. I am.
Pic's soon
more coffee is offline Find More Posts by more coffee   Reply With Quote
Old Sep 12, 2009, 04:57 PM   #2
Bravo Coffee...looking foward to the build!
catfishchaser is offline Find More Posts by catfishchaser   Reply With Quote
Old Sep 12, 2009, 05:56 PM   #3
Cheif Bottlewasher
The first is how she looks right now ..
the others are what she's supposed to look like when she's done ...
We'll see ..b its not cold enough to light the woodstove... yet ..
Think a 550 should be swinging a 2 1/2 " prop direct ?
  • Name: P9120295.jpg
  • Name: DSC_0223_edited-1.jpg
  • Name: ShelleyFossPhoto.jpg
  • Name: shelly_foss_2.jpg
  • Name: 2723459275_f1960113c9_b.jpg
  • Name: 2732006611_bc1569376e_b.jpg
  • Name: 2732821724_8c9ef04bcb_b.jpg
Old Sep 12, 2009, 06:15 PM   #4
MORE COFFEE- I thought I would pass on a bit of info as to a 550 size motor and the size propeller it can swing direct drive. First the “550” is the size of the case of the motor, it says nothing about the torque, RPM’s, voltage, or current the motor will consume under load.
To say flatly that a “550” motor can swing a 2 1/2” dia propeller can get you in a world of trouble if the motor is a high RPM motor with no torque. That is a recipe for burnt up speed controls, wires, and or motor. It is best to get the specs of the motor before trying to go direct drive to the prop. A lot of 550 and 600 size motors will run at 12 to 14,000 rpm on twelve volts and will be running a prop of 1 1/2” diameter at speed.
If it were me, and knowing that you are going to put the motors in a tug, I would go for the motor reduction gear box route for extreme torque and low amp draw.
frankg is offline Find More Posts by frankg   Reply With Quote
Old Sep 12, 2009, 06:23 PM   #5
Cheif Bottlewasher
Gear reduction .... OK ... 3:1 ..the motors are high speed ..
Thanks ..
Old Sep 16, 2009, 10:59 AM   #6
Cheif Bottlewasher
Yeee Haaa !!!
Think i have the hull ..some sanding ..a little putty ....OK ..lots of sanding and lots of putty..power tool's ahoy
Have to finally get the cradle built..
then onto the fiber glass ..nearest i can get is the polyester automotive type resin ..It will set up fast ..can i use acetone to thin it, slow the harding time still get reasonable strenght ..also ..what glass? the stuff at the Hardware store seem's rather heavy .. General purpose they call it ..and then there's the stuff that looks like a wool mat .."chop" it think they refer to it as ..
  • Name: P9120296.jpg
  • Name: P9150297.jpg
Old Sep 16, 2009, 11:34 AM   #7
Cheif Bottlewasher
Fittings..
Here's a few fitting I've amassed over the past year or more .. the liffe raft is as big as a door ..in pictures I've found the raft on the actual Shelly ..also appears as big as the doors hopfully
They do look a lot better than the Dumas supplied jobbies ..and the scale fits..
Marker LED's and stuff should be comming soon ..as long as i can find the brass to make the mast out off to act as a ground..it will make stringing the lights easier i think ..
  • Name: P9150298.JPG
  • Name: P9150300.JPG
  • Name: P9150299.JPG
Old Sep 16, 2009, 12:38 PM   #8
King of The Moon
ozoneone's Avatar
where did you get the tires?
ozoneone is offline Find More Posts by ozoneone   Reply With Quote
Old Sep 16, 2009, 02:50 PM   #9
Cheif Bottlewasher
Evil-Bay
But ..now Im seeing that the seller is no longer a registered user..
they came from the UK ...so hopfully that helps ..
Old Sep 16, 2009, 03:36 PM   #10
King of The Moon
ozoneone's Avatar
thank you, more coffee. i just found some here:
http://www.harbormodels.com/site08/tires.html
i'll have to try them.
Old Sep 16, 2009, 03:41 PM   #11
Cheif Bottlewasher
I initially liked those ..but after some searching its when I found the one's i have ..should have bought more ..
it was the information cast into the tyre that got me ,,you know ,the size information and all..
Now if only i could find a few Goodyear's to put on the stern
Old Sep 17, 2009, 09:20 AM   #12
Right on! Been wondering when you we're going to let us have a look. You'd better get the fiberglass done before winter sets in. Seems it's coming quick here.
I'm still sitting on the fence. Hoping the Invader get released again.
lashlander is offline Find More Posts by lashlander   Reply With Quote
Old Sep 17, 2009, 09:25 AM   #13
King of The Moon
ozoneone's Avatar
that's exactly what i am doing on my Lord Nelson Tug! just glassed it monday, now i need a few more coats poly resin. i don't much like glassing so i'm happy it's done. raining since though and no poly indoors!
Old Sep 17, 2009, 11:17 AM   #14
Cheif Bottlewasher
Yeah winter reared its head here last night ..2 C and a half inch of frost..tree's are coloring up in a hurry..
Invader ..yup now theres a boat ...from what Ive seen Lash there's no reason you couldnt scratch the ol'girl out using a set of plans ..
Old Sep 17, 2009, 11:27 AM   #15
Cheif Bottlewasher
In light of the glass ..I picked up resin ,hardner ,fabric , acetone, and a few brushes...
Now what???
For my thicknes im guessing 2 drops of hardner for every ounce of resin.. its about 10C outside right now..
I can thin it with a little acetone from what i gathered ...how much is what i dont know...
Should i apply the resin to the hull first then apply the fabric ..follow up with another coat of resin ..and as many coats as is needed..
Should i thin the initial coat of resin..
I havent done this before so if i could get a 1/2 hr working time with this it would be most helpfull.. last time i dabbled in this it hardened up in less than 5 minutes.. and off course ..once i put the hardner in the urge to go pee kicked in and well crossed legged and sweating i really had to move fast .. wont happen this time ..
Discussion 36" dumas shelly foss motor question? cain8885 Scale Boats 5 Nov 23, 2008 05:44 PM
Build Log 36" Shelly Foss build more coffee Scale Boats 17 Nov 18, 2008 12:14 AM
Sold Dumas Shelly Foss 36" Kit sleepwalker Boats (FS/W) 0 Jan 20, 2008 05:44 PM
Help! Shelly Foss 36" plans sleepwalker Scale Boats 0 Jan 01, 2008 02:32 PM
Discussion Shelly Foss 36" sleepwalker Scale Boats 3 Dec 18, 2007 09:21 PM
Bored? Want to fight?
Join the RCGroups clan!
