Old Sep 15, 2001, 04:47 PM
bjsiegel@texas.net is offline
Find More Posts by bjsiegel@texas.net
EFlight=Fun,Big-T=BIG FUN
San Antonio, TX, USA
Joined Jan 2001
Need RS380PH number for MotoCalc & Thrust computation
Could someone send me or tell me were to get the MotoCalc numbers for a RS380PH?
Need Constant, Current, Resistance and Weight.
MotoCalc has RS380SH but it bears little resemblance to my actual numbers (A,V,W,RPM).
How do you compute thrust from pitch & rpm?
I am running salvaged SoarStar gear (RS380PH, 1,85:1GB, 8x4 on 8x600AE) on a scrap built that is close enought to done to let me get a good guess at AUW. Trying out battery/prop combos to see what appears to work best.
During static tests I got
At 30 Seconds:
9.9A, 8.0V, 80W, 7950RPM - computed static speed = 30mph
At 2 minutes (350maH used)
9.0A, 7.3V, 67W, 7350RPM - computed static speed 27.8mph
Thank you,
Bernard
bjsiegel@texas.net is offline Find More Posts by bjsiegel@texas.net
Old Sep 17, 2001, 10:48 AM
BobK is offline
Find More Posts by BobK
Rhode Island
Joined Oct 2000
Unfortunately the designation RS380PH only tells part of the story. A complete designation would be something like RS-380PH-4075. The last four digits indicate the size of the wire and the number of turns; ie, 75 turns of .40mm wire (I have no idea if that's an actual 380 wind). The only difference between a 4.8V Speed 400, 6.0V and a 7.2V is the winding, in other words all three motors are RS-380PH's but the last four digits would be different for each motor.
The E-Zone FAQ describes how to measure all three motor constants, here: http://www.ezonemag.com/pages/efaq.htm#motor16
I believe the SoarStar motor is the same as a 6V Speed 400, with a flux ring. The flux ring will slightly reduce the Kv and Io but would have no effect on Rm.
Hope this is of some help.
BobK is offline Find More Posts by BobK
Question need a peak charger for low amp batteries Cliff Smith Batteries and Chargers 3 Sep 21, 2005 03:57 PM
Need motor info for motocalc MUDBOGGER2 Power Systems 0 Jan 13, 2005 03:03 PM
need part number for hornet II autorotation kit not sure if im right falcon41176 Micro Helis 3 Dec 21, 2004 12:18 AM
Actro 32 series - need motor constants for motocalc. rcjetpilot Power Systems 2 Nov 20, 2004 11:42 AM
Motocalc & Thrust jbird Power Systems 9 Nov 05, 2003 09:41 AM
