Old Mar 03, 2011, 11:38 AM
warhead_71 is offline
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
I'm just bumping this old thread due to the prevalence of "one sheet" airplanes. This plane was originally designed as a one-sheeter, for free-flight -- and it's perfectly suitable for electric power. Makes a great little seaplane too. Mine was way too floaty for outdoor flying here in the Windy City... but it would be excellent for indoor flight.
If I were going to build it again for outdoor flying, I'd go for at least a 40" wingspan (for visibility) and use KFM wings. I might use 1/2" pink foam for the fuselage hull just to make it more rugged for belly landing, and I'd build-in a stepped hull for water operation.
warhead_71 is offline Find More Posts by warhead_71
Old Mar 04, 2011, 01:17 AM
foamdave is offline
Find More Posts by foamdave
skumgummi dave
Gresham, OR.
Joined Mar 2004
I thought the Phlatboyz were gonna share plans for this plane. What happened?
Dave-
foamdave is offline Find More Posts by foamdave
Old Mar 04, 2011, 07:28 AM
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
I dunno - it's not on their website either.
Old Mar 05, 2011, 10:42 PM
theothers is offline
Find More Posts by theothers
theothers's Avatar
Joined Aug 2009
Hey guys. We apologize for not posting the plans for the Jeep-O-Plane yet. We worked on this project some time ago and to be honest, can't remember why it wasn't completed. We'll have to go back and see if we can put together the plans and get them posted.
theothers is offline Find More Posts by theothers
Old Mar 07, 2011, 04:46 AM
7up is offline
7up
Find More Posts by 7up
7up
,ɯǝ ʇoƃ ɐʎ ɟı ,ɯǝ ǝʞoɯs
7up's Avatar
USA, KY, West Liberty
Joined Jun 2001
Jeep-O-Plane
Hey guys, PDF plans for the Jeep-O-Plane should be posted latert oday. I just wanna cut one out and make sure everything fits together good. This one is for 1/4"- 6mm foam with tab-n-slot construction. WS on this one is 30" but I will post files without tab-n-slots so it can be easily resized.
-Buk
7up is offline Find More Posts by 7up
Old Mar 07, 2011, 06:13 AM
Kronikpilot is offline
Find More Posts by Kronikpilot
BOXFUSE KING!
Kronikpilot's Avatar
NO WIND CITY GUAM U.S.A
Joined Jan 2009
NICE! You know I want to build one.
ALBRT
Kronikpilot is offline Find More Posts by Kronikpilot
Old Mar 07, 2011, 12:57 PM
foamdave is offline
skumgummi dave
Gresham, OR.
Joined Mar 2004
Woo Hoo!
Way to go on the plans. Really looking forward to them.
Thanks, Dave-
Old Mar 07, 2011, 01:20 PM
larryross is offline
Find More Posts by larryross
Registered FFF Addict
larryross's Avatar
Grand Junction, Colorado
Joined Dec 2007
Great 7up... please make sure to post full page for those of who like to mess with the scale. Do the tabbed plans full page too... I can import them into a program and scale it and change the tabs as needed. Thanks for your hard work.
Regards
Larry
larryross is offline Find More Posts by larryross
Old Mar 08, 2011, 12:21 AM
7up is offline
7up
7up
7up's Avatar
Joined Jun 2001
[EDIT 03-11-2011]
Updated files with proper wing chord size.
I finally got some time to cut this out and slap one together. Not mybest build but I was really just checking the fit of things. I had a couple mistakes that I corrected on the plans so I think they should be good to go.
Construction is a no brainer. I attached the top to one of the fuse sides, working my way front to back. Then I glued on the other fuse side the same way. Then I glued on the bottom, working from the middle tab outwards, (it just happended that way?). Next I slid the Hstab and elevator in place. I still need to form my airfoil in my wings but that will have to wait...
It will help to roll or bend the top and bottom to form a slight arch before try to glue them to the fuse sides.
The foam that you remove from the largest fuse windows can be used as bulkheads/support in the cabin of the fuse. I put one up front where the window divider is and one just behind the large window.
I have no idea on CG yet, so exact servo placement is unknown (maybe tomorrow).
Oh yea, ailerons are optional.
Enjoy and I'll post more info when I get it flying.
Sketchup and cnc files available at www.phlatforum.com.
-Buk
Old Mar 08, 2011, 04:22 AM
BOXFUSE KING!
Joined Jan 2009
Thanks for the plans 7up. I will build one soon.
ALBRT
Old Mar 08, 2011, 04:46 AM
jclassic1 is offline
Find More Posts by jclassic1
jclassic1
New Houghton, Derbyshire, UK
Joined May 2006
What an attractively ugly little foamy.Just have to have a go at one of these.
It will be built for outdoor use only so will be a 6mm depron construction.
John
jclassic1 is offline Find More Posts by jclassic1
Old Mar 08, 2011, 08:07 PM
theothers's Avatar
Joined Aug 2009
Awesome 7up. Great job. Thank you so much for posting the plans for this great little plane.
Old Mar 09, 2011, 07:03 AM
BOXFUSE KING!
Joined Jan 2009
I printed the plans today, looks easy to build. I hope to see this bird in the air soon. I can't decide on the electros yet until it's built, and then I will go from there. Thanks for posting the plans again.
ALBRT
Old Mar 09, 2011, 08:02 AM
7up is offline
7up
7up
7up's Avatar
Joined Jun 2001
Yea, very simple to build. I haven't had time to finish mine though. It's all together except for securing the wings in place, then I can do some glide tests and figure the CG out.
-Buk
Old Mar 09, 2011, 09:16 AM
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
Finding CG was pretty easy. On mine, I just used 25% of the combined chord of both wings. So that's 25% from the LE of the upper wing to the TE of the lower wing... puts me right at the middle of the side-window.
I flew mine about a dozen times before I gave it away. A nice little floater but too small for outdoors and I think I'd prefer stiffer KFM2 wings.
Discussion In today’s paper: “UFOs baffle O.C. earthlings” This is the last thing we need! DWA Aerial Photography 76 Oct 19, 2007 05:21 PM
Discussion Not your grandfather's paper airplane (or RC paper plane) caseih Parkflyers 16 Jun 02, 2007 08:53 PM
Morrison's Paper Plane Pete P Free Flight 0 Aug 04, 2005 03:51 PM
Ray-O-Vac AA's & AAA's, Anyone using them for a while? Looooeeee! Power Systems 3 Sep 24, 2001 08:16 AM
drunken E-plane, what's wrong here? windsurfer Foamies (Kits) 7 May 11, 2001 06:55 PM
