Old Sep 11, 2009, 01:57 PM
smau1 is offline
Find More Posts by smau1
Joined Sep 2001
Question
Where to buy low discharge (1 to 2C; but cheap) Lithium (or NiHM, NiCd) batteries
Hi,
I am looking for many low discharge (at most 1 to 2C rated) Lithium rechargeable batteries (either pack or cell) to make a battery pack for an electric lawnmower (24V at least 20Ah, but only 30A rate). I remember that some online hobby store used to sell them cheap. Does anyone know where I can buy any of those?
Please let me know where I can find surplus NiHM or NiCd cells for this purpose as well.
Thanks.
smau1 is offline Find More Posts by smau1
Old Sep 11, 2009, 02:03 PM
KC is offline
KC
Find More Posts by KC
KC
Registered Loiterer.
KC's Avatar
United States, FL, Orlando
Joined Sep 2006
12 NiMh for $0.99 on ebay. 30 min left on the sale. Better hurry.
http://cgi.ebay.com/12-AAA-1000mAH-1...d=p3286.c0.m14
KC
KC is offline Find More Posts by KC
Old Sep 11, 2009, 02:45 PM
aa78 is offline
Find More Posts by aa78
Fast and low...
aa78's Avatar
Joined Apr 2009
http:///www.hobbyking.com
Go for the lowest discharge rate which suits your purpose.
aa78 is offline Find More Posts by aa78
Old Sep 11, 2009, 03:15 PM
smau1 is offline
Joined Sep 2001
I was hoping to find some cells rated for only 1 to 2C that are even cheaper than the ones at hobbyking. I am assuming that the cost of making a 2C cell and a 20C cell are very different; but that could be wrong.
Old Sep 11, 2009, 03:55 PM
aa78 is offline
Fast and low...
aa78's Avatar
Joined Apr 2009
The lowest is 15C at hobbyking. Have a look at their Tx/Rx lipo packs which are even lower C rated.
Old Sep 11, 2009, 04:52 PM
supergps is offline
Find More Posts by supergps
Joined Aug 2009
following link is cheapest NiMH (sans the shipping) I've ever seen
http://www.hobbycity.com/hobbycity/s...idproduct=9907
to get 20Ah 24V (around 27.8 to 20V), you'd need 180 of these (20S9P) which will cost around $143 + shipping (6.3 Kg).
Following is the cheapest LiPo I've seen
http://www.hobbycity.com/hobbycity/s..._20C_Lipo_Pack
To get 20Ah 24V (25.2 - 19.8V) you'd need 1S4P of these. that should cost around $240 + shipping (3.6 Kg).
there is just one more option I can see:
http://www.hobbycity.com/hobbycity/s...idProduct=8930
this is cheaper in bulk buy, and gives 36 pieces.
connect 3S2200mAh in 2S9P you'd need 18 of these packs, so you can make a spare one too. Voltage same as 5Ah LiPo above.
$540 + shipping(8.5 Kg)
There may be other alternatives.
If I were you, I'd try to fing some Lead Acids, a trolley and some heavy gauge cables. I think they'd be cheaper (but much heavier) than all the above. Consult your car spares shops.
Either which way, you'd also need to charge those and thats going to take time. Plan about that too.
BTW, I am NOT linked with HK in any way. just giving out what I know.
supergps is offline Find More Posts by supergps
Old Sep 11, 2009, 06:11 PM
write2dgray is offline
Find More Posts by write2dgray
write2dgray's Avatar
United States, NJ, Princeton
Joined Dec 2006
I'd look at A123 or larger LiFe cells. Check all-battery.com, they have cheap/low c rated stuff like that.
- David
write2dgray is offline Find More Posts by write2dgray
Site Sponsor
Old Sep 11, 2009, 06:47 PM
rpage53 is offline
Find More Posts by rpage53
Boffin
rpage53's Avatar
Victoria, BC, Canada
Joined Apr 2001
Hi,
Thanks.
I think you'll find that if you want cheap, you need to go back to the original lead acid batteries. You can get 2 17Ah 12V for around $100. I looked around for NiMH bargains last year for my lawnmower and couldn't get close to the price of Pb. If you were considering 4000 mAh sub-C, you need a 20S5P pack or 100 cells in total. You could get by with 16S.
Rick.
rpage53 is offline Find More Posts by rpage53
Old Sep 11, 2009, 08:37 PM
smau1 is offline
Joined Sep 2001
Rick---Sealed lead acid (SLA) is the cheapest for this application, but I am not happy with its performance. It died after one season. This is also what many other owners' experiences (even when some were using deep cycle), based on my online search. SLA is also a harder to maintain due to its weight and size (harder to move it to the basement during winter, etc).
The NiMH from HobbyKing found by supergps is approaching the price of SLA, but shipping is high, well, twice that of SLA due to the weight of SLA.
By the way, a good way to "normalize" the prices of batteries for comparison is to use their dollar per unit volt-amp-hr because price is roughly proportional to volt (get twice voltage by two packs in series) and charge capacity (get twice capacity by two packs in parallel) for a given product line (i.e., for a given brand, C-rating and product series). One execption is that it will be higher for the most popular configuration like 11.1 V 2.2 Ah LiPo. Note that VAh is Watt-hour (Wh), so this figure is really $/energy-storage, which should be a constant for a product line.
The NiHM from HobbyKing is priced at $0.29/Wh. A deep cycle lead acid at 12V 22Ah costs around $50 and is therefore priced at around $0.2/Wh. The HobbyKing 6S LiPo listed above is priced at $0.54/Wh. Brand name LiPo's are usually more than $1.3/Wh.
This exercise doesn't provide more information, but it does make comparison much easier. You can easily see the premium for higher rate if you compare the $/Wh between product lines of the same brand.
Thanks for all your advices.
Old Sep 11, 2009, 11:50 PM
fly_boy99 is offline
Find More Posts by fly_boy99
Flying motor mount master
fly_boy99's Avatar
San Jose, California, United States
Doesn't look like your price point will be met with Lipos especially if you want to buy a ton of 1 or 2C bats.
fly_boy99 is offline Find More Posts by fly_boy99
Old Sep 12, 2009, 02:17 AM
groundfx is offline
Find More Posts by groundfx
Delta, BC, Canada
Joined Oct 2003
Buy a plug in lawnmower and then you need NO battery. All the rechargeable mowers are just toys and environmental disasters that have been greenwashed.
Better yet, buy a good Honda gas mower if you really don't want a cord.
If you want to be green buy a used mower.
P.S. If you really do want a large format (20Ah 24V) Lipo, you should look at the e-Bike battery suppliers. E.g. http://www.pingbattery.com/servlet/StoreFront ... although because of safety, they all tend to be LiFePO4's now. They're pricey though and will make your rethink using an SLA.
groundfx is offline Find More Posts by groundfx
Old Sep 12, 2009, 06:45 AM
supergps is offline
Joined Aug 2009
Or maybe a 30A 24V power supply. That would last longer than any battery!!
Old Sep 12, 2009, 01:21 PM
smau1 is offline
Joined Sep 2001
groundfx---What safety concerns led large-format batteries to tend toward LiFeO4?
supergps---Yes, I am considering power supply as well.
I am also trying to get help from some friends working in the IT department. They probably have to-be-discarded laptop batteries and power supplies that I can take advantage of.
Old Sep 12, 2009, 03:12 PM
rpage53 is offline
Boffin
rpage53's Avatar
Joined Apr 2001
My first battery died within a year as well, mainly because the kids ran it down until it wouldn't move. I only use about half the charge before recharging now and my current Pb batteries haven't lost any capacity after 2 seasons. I rewired them so I can charge and test each 12v separately on occassion with a more capable charger.
I haven't had good success with cheap C and D NiMH. Most test out at less than half the rated capacity at anything more than a C discharge and they don't match very well for making packs.
My yard is too large and has too many trees and flower beds for a corded electric. The rechargeable is a good compromise but its heavier and more cumbersome than an equivalent gas mower. Still, its my small contribution to air quality.
Rick.
Old Sep 12, 2009, 04:54 PM
groundfx is offline
Delta, BC, Canada
Joined Oct 2003
groundfx---What safety concerns led large-format batteries to tend toward LiFePO4?
Venting with flames on a 2100mah 12V Lipo is one thing, venting with flames on a 20Ah 48V Lipo would be a completely different event.
LiFePO4 don't have this worse case problem... much better.
Cheap lithium batteries... sharkman Batteries and Chargers 1 Jul 05, 2005 05:00 PM
cheap Lithium Ion batteries? wallasan10 Batteries and Chargers 2 Dec 08, 2003 12:46 PM
Idea Low Voltage Cutoff for Lithium Batteries Dezynco Power Systems 10 Oct 21, 2003 10:44 AM
Cheap lithium batteries mrman Scratchbuilt Indoor and Micro Models 5 Jan 11, 2002 04:55 AM
