This thread is privately moderated by patterkid, who may elect to delete unwanted replies.
Old Sep 10, 2009, 10:30 PM
patterkid is offline
Find More Posts by patterkid
Trader Rating: 21
TC, Michigan
Joined Jan 2009
Trader Rating: 21
For Sale
F/S: Scorpion HK 4025-1100 Needs work
Hey guys,
Well i have a scorpion HK (helicopter edition) 4025-1100 Motor for sale here. First off this is sold AS-IS. I will do my best to describe it and my pictures should help. There is a pinion stuck on the shaft and i decided to try to dremel it off. Well this thing wont dremel off very well and ive finally just had enough with it. To the best of my knowledge i would say it just needs a new shaft and bearings which cost
5.99 for bearings:
http://www.innov8tivedesigns.com/pr...products_id=362
and
8.99 for the Shaft:
http://www.innov8tivedesigns.com/pr...products_id=395
I just dont feel i have the skills to replace the shaft and bearings my self so i am selling the motor for someone else to do it. Keep in mind this is a used motor and has had about 20-30 flights on it. It has some cosmetic wear on it and im sure alittle internally as well hence it is sold as-is.
Best offer gets it. it is a 115$ Motor and only needs about 20$ In parts. so hoping for a decent amount but all offers accepted unless its like 20$ or something
Pics up SOON waiting for the batt to charge enough
-Justin
patterkid is offline Find More Posts by patterkid
Old Sep 10, 2009, 10:35 PM
Trader Rating: 21
TC, Michigan
Joined Jan 2009
Trader Rating: 21
Pics:
Old Sep 10, 2009, 11:00 PM
Trader Rating: 21
TC, Michigan
Joined Jan 2009
Trader Rating: 21
Sold pending funds for 45$
Old Sep 11, 2009, 07:43 AM
Joe 1320 is offline
Find More Posts by Joe 1320
Trader Rating: 179
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
Trader Rating: 179
A tool called a pinion puller is what you use to remove gears without going though what you just went though.
Joe 1320 is offline Find More Posts by Joe 1320
Old Sep 11, 2009, 09:31 AM
Cougar429 is offline
Find More Posts by Cougar429
Trader Rating: 125
Cougar429's Avatar
Canada, ON, Windsor
Joined Apr 2008
Trader Rating: 125
If the previous deal falls through I could use it.
Cougar429 is offline Find More Posts by Cougar429
Old Sep 11, 2009, 09:51 AM
birdie_in_texas is offline
Find More Posts by birdie_in_texas
Trader Rating: 114
Pro Bro #1008
birdie_in_texas's Avatar
USA, TX, Weatherford
Joined Sep 2003
Trader Rating: 114
If it is just loktite, then just hold a lighter to it and get it nice and hot and then use pliers..it will come right off..
birdie_in_texas is offline Find More Posts by birdie_in_texas
Old Sep 11, 2009, 10:03 AM
Trader Rating: 21
TC, Michigan
Joined Jan 2009
Trader Rating: 21
I tried and tried pinion pullers and other methods. Nothing would work its like it welded itself to the shaft. The shaft goes from 5mm to 8mm internally and it got jammed onto the part where it gradually gets larger.
Discussion Why is 55-10-32 a good match with Scorpion HK-4025-740 Halt Power Systems 4 Jun 03, 2009 05:49 PM
Sold Scorpion HK-4020-1100 never flown - price lowered metalhead1986 Aircraft - Electric - Power Systems (FS/W) 4 May 11, 2009 07:22 AM
Sold (BYE BYE R/C HELIS) Scorpion HK-4025-630 HighNear90 Aircraft - Electric - Power Systems (FS/W) 1 Feb 11, 2009 02:18 PM
Sold Scorpion HK 4025-890 jamesppp Aircraft - Electric - Power Systems (FS/W) 1 Nov 06, 2008 05:22 PM
F/S: 20amp zagi esc, needs repair... seanpr123 Aircraft - Electric - Airplanes (FS/W) 1 Sep 25, 2002 06:58 PM
