Old Nov 12, 2009, 01:38 PM
draftman1 is offline
Find More Posts by draftman1
draftman1's Avatar
central CA
Joined Aug 2002
my wings do awesome outside loops. I dont do them much in combat but I know that I can. just find a good plane you are comfortable with. and learn it really well. you will do good if you can do that
draftman1 is offline Find More Posts by draftman1
Old Nov 12, 2009, 02:01 PM
sgilkey is offline
Find More Posts by sgilkey
Shelby Township, MI
Joined Feb 2002
holes
I would strongly suggest you avoid putting wing dowels thru holes in the AL rails. The edge of the holes in the AL will cut thru any rod in very short order, under the influence of engine vibration. A fellow club member built a Battle Axe-type rail plane using an all-flying stab, and had the fiberglass pivot axle of the all-flying stab passing thru drilled holes in the rails. The f/g rod was cut CLEANLY in a matter of very few flights leading to total failure of the elevator system. The same bad result might occur with wing attachment dowels, though they will be kept from vibrating in the holes to a great extent by the force of the rubber bands. Plus they are larger in diameter (though if you use a shaft instead of a rod, that will be a marginal improvement.) Coupled with the tendency of the rails to bend at the holes, there may be better solutions.
sgilkey is offline Find More Posts by sgilkey
Old Nov 12, 2009, 05:08 PM
draftman1's Avatar
central CA
Joined Aug 2002
good thinking there scott. my boy has a homebrew axe and we put the dowels in the PVC box. or we used U shaped coat hanger wire with hooks on the ends for the rumber bands
Old Nov 12, 2009, 07:46 PM
PLMS is offline
Find More Posts by PLMS
Martin - AKA mr.sneezy
PLMS's Avatar
Joined May 2004
Originally Posted by sgilkey View Post
I would strongly suggest you avoid putting wing dowels thru holes in the AL rails. The edge of the holes in the AL will cut thru any rod in very short order, under the influence of engine vibration. Coupled with the tendency of the rails to bend at the holes, there may be better solutions.
Yep, agreed. We already removed the front dowel and integrated it into a new wing box design. I'll be flying that one tomorrow to test. The rear dowel I will test for a bit longer as it's not under so much stress (bending) in a crunch up.
The great thing about these type models is they are so easy to change...
PLMS is offline Find More Posts by PLMS
Old Nov 12, 2009, 07:49 PM
PLMS is offline
PLMS's Avatar
Joined May 2004
Steamers ?
Hey where's the best place to tie on the streamer ?
My first thought is to put a hole in the rudder just above the angle brackets and put a string through there...
Old Nov 12, 2009, 08:27 PM
gsjames is offline
Find More Posts by gsjames
Gary James
gsjames's Avatar
Weatherford, TX
Joined Feb 2006
Usually we just drill a large hole right through the angle brackets just aft of the aft-most screw.
gsjames is offline Find More Posts by gsjames
Old Nov 14, 2009, 09:33 AM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
The BattleAxe has the hole through the angle brackets. Works fine.
BTW, to dial in a combat plane, do so with and without the streamer. The Battle Axe seems to be able to handle less elevator with the streamer. IOW, if you set it up so full throw is almost tip stalling without the streamer, it will tip stall with the streamer and full elevator.
Pinecone is offline Find More Posts by Pinecone
Old Nov 14, 2009, 11:10 AM
Blue Note is online now
Find More Posts by Blue Note
Blue Note's Avatar
East Tennessee
Joined Nov 2007
You should also consider attaching a streamer ( or hopefully capturing one ) to the outer region of one tip to get a feel for how it will perform differently, especially through the turns and vertical maneuvers.
BNC
Blue Note is online now Find More Posts by Blue Note
Old Nov 15, 2009, 08:17 AM
Pinecone is offline
Will fly for food
Maryland
Joined Sep 2004
Yeah, I had mine capture a streamer and uncontrollably roll for a while.
Old Nov 15, 2009, 08:58 AM
gsjames is offline
Gary James
gsjames's Avatar
Weatherford, TX
Joined Feb 2006
On mine, I SIGNIFICANTLY increased the size of the vertical tail. I found that in the strong winds that we occasionally have here in Texas, that the standard tail was too small and the airplane oscillated in yaw. With the larger tail, it is much more stable.
Old Nov 15, 2009, 09:02 AM
gsjames is offline
Gary James
gsjames's Avatar
Weatherford, TX
Joined Feb 2006
It looks like this:
Old Nov 15, 2009, 09:05 AM
gsjames is offline
Gary James
gsjames's Avatar
Weatherford, TX
Joined Feb 2006
Oops, here it is with dimensions.
Old Nov 16, 2009, 09:27 AM
sgilkey is offline
Shelby Township, MI
Joined Feb 2002
fin
i agree, it's almost hard to have too big of a fin. too small and you will be fighting yaw when you get streamers on the wing.
Old Nov 16, 2009, 08:45 PM
PLMS is offline
PLMS's Avatar
Joined May 2004
We haven't flown any of the test planes with a streamer yet, the weather is too damn hot for any more than a quick outing (like 38-41C for two weeks straight).
How long and how wide are you competition streamers ?
We have 25mm (1") crepe paper type here, easy to get.
Also why is there a string leader on the streamer, and how long is that ?
Cheers,
Martin
Old Nov 16, 2009, 10:25 PM
Blue Note's Avatar
East Tennessee
Joined Nov 2007
Cheers,
Martin
We use 1" wide crepe paper streamers also. 30 feet long. As you said, cheap and pretty easy to find.
As far as the string goes...Do you really want someone aiming for the tail of your plane??? Typically at least 10 feet long thin cotton string to keep the target zone a little behind the plane and reduce the midair collisions, at least in theory. Cotton string will break more readily in a tangle, where something like nylon will cause much more damage to a plane that gets tangled up in it.
I also suggest taking a puller with you to the field when you fly so you can pull the hub off of the engine in case you get string wound up in it. It's a quick fix, but only if you have the tool with you. Don't ask me how I know.
BNC
Question can some one cut me out a Miss Hangar One hisky Foamies (Kits) 0 Oct 31, 2007 01:56 AM
Discussion Please help me find some Ultimate biplane plans roundthebend Fuel Plane Talk 0 Sep 17, 2007 02:01 PM
Question Can someone help me out with some headspeed calcs for Xero G Jam Rectified Electric Heli Talk 5 Apr 22, 2007 01:42 PM
Help me out - buy my car! Buzz_Man Life, The Universe, and Politics 1 Oct 24, 2001 07:32 PM
Trying out Motocalc, some questions... Looooeeee! Electric Plane Talk 2 Jun 12, 2001 02:10 PM
