Old Sep 10, 2009, 01:09 AM
Miraj is offline
Find More Posts by Miraj
Are you serious?
Miraj's Avatar
Brisbane
Joined Jun 2005
1/3 scale retract doors hinge
Working on a 1/3rd scale ash-26 and was interested in info/pictures on how the best way to hinge the retract doors?
Thanks in advance
Steve
Miraj is offline Find More Posts by Miraj
Old Sep 10, 2009, 03:54 AM
Steve.650 is offline
Find More Posts by Steve.650
3Ding at a field near you!!
Cranny, Vic. Aust
Joined Mar 2008
Hi Steve, Is that one of John Copelands models? Ive got ans ASW 27 he built from ann S2G kit. Its quarter scale though, but if it helps tomorrow I will take a pic or 2 of his instalation and post em for you
Cheers (another) Steve
Steve.650 is offline Find More Posts by Steve.650
Old Sep 10, 2009, 04:29 PM
Miraj is offline
Are you serious?
Miraj's Avatar
Brisbane
Joined Jun 2005
Steve
Yes, it is, had sitting around unbuilt for about 2 years. I thought it time to get it flying. John sent me a cd with images on it and they show a hinge system using brass and steel rod, but i saw on rcg sometime ago some guys using tube rubber.
So not sure which way to go?
Steve
Old Sep 10, 2009, 05:30 PM
s2000 is online now
Find More Posts by s2000
so. cal.
Joined Jan 2006
Pretty sure there is an explanation on the SoaringISSA website in the tech tips area about how to hinge gear doors.
s2000 is online now Find More Posts by s2000
Old Sep 10, 2009, 05:51 PM
henrykk is offline
Find More Posts by henrykk
henrykk's Avatar
Australia, VIC, Surrey Hills
Joined Jun 2006
Hi Steve,
there is a pretty tough way of doing it that I used on both my third DG303:
http://www.silentflight.net/index.ph...=114&Itemid=40
Also my cirrus (see image)
the idea came from Chris Williams who covers the technique well on the SSUK site (just ask him in the forum)
http://scalesoaring.co.uk
henrykk is offline Find More Posts by henrykk
Site Sponsor
Old Sep 10, 2009, 06:15 PM
balsabozo is offline
Find More Posts by balsabozo
Joined Apr 2006
any drawbacks to silicone hinges? i used this on my 6m schueler and either i was lucky or it is easy. since i dont care that much about inward travel, i used a thick layer. also, it retains the tendency to remain more closed than fully opened which is nice (so long as you cure it wiht doors closed).
here is link to inner tube method.
http://www.scalesoaring.co.uk/GLASS/.../Retracts.html
balsabozo is offline Find More Posts by balsabozo
Old Sep 11, 2009, 11:59 AM
SoarScale2 is offline
Find More Posts by SoarScale2
SoarScale
United States, WI, Wind Lake
Joined Nov 2004
The more friction forces you can eliminate from the doors, the better IMO. I suspect you've heard the odd tail of retracts jamming!!!!
If you have the ability to create an almost friction-free hinge, I'd certainly recommend it. The pictures below show a hinging system I used on my 10.3m Eta. It is a development of the pin and tube type shown in HenryKK's thread.
The small metal hinges are washers. A quarter of the washer is cut away leaving about a 3/4 washer. A hole for the pin is added to one end and the end is filed round. The arc of the washer is about half of the washer and the other 1/4 is bent at 90 degrees. The three bent ends are then captured by the pin and glued to each door. This is an inexpensive method of creating the "door hinge" type of hinge that is generally a two part hinge.
This was simple, worked well and was almost completely friction free. Rubber bands were used to create sufficient forces to close the doors.
Not all the steps are shown here since I didn't take any more photos but I think you get the "picture"!!
FWIW - Tony
SoarScale2 is offline Find More Posts by SoarScale2
Old Sep 11, 2009, 03:27 PM
yyz is offline
yyz
Find More Posts by yyz
yyz
yyz's Avatar
USA, CA, Paso Robles
Joined Dec 2004
Aramid
Has anyone gone to the trouble of making their gear doors out of aramid (eg, Kevlar) to toughen them up? Or is there not enough landing and take-off abuse to warrant the extra effort?
Also, has anyone done an internal cg tow hook (attached to the landing gear structure in front of the wheel, etc) ?
MD
yyz is offline Find More Posts by yyz
Old Sep 17, 2009, 10:23 AM
Harm is offline
Find More Posts by Harm
Holland
Joined Jan 2004
I never toughen up the gear doors. When something has to give I rather have the gear doors take the abuse and maybe crack then something else in the construction.
What I do is make a mold of the fuselage outside over the gear door area before I cut the doors out. This way I can make a new door panel later when the need arises. First scratch the gear doors outline on the fuselage, then make the mould (the scratched outline you will find back in the mould for easy reference) and finally cut the doors free.
Harm is offline Find More Posts by Harm
Old Sep 17, 2009, 11:40 AM
SteveR is online now
Find More Posts by SteveR
New York
Joined Feb 2002
Tony, how do you go about cutting the doors out of the fuse bottom?
TIA,
Steve
SteveR is online now Find More Posts by SteveR
Old Sep 17, 2009, 11:57 AM
Seadog is online now
Find More Posts by Seadog
Seadog's Avatar
Canada, BC, Bowen Island
Joined Jan 2004
Cutting Gear Doors
Steve,
See this recent thread where I asked the same question....it turned out to be very easy to cut out the doors with a razor saw. I just scribed a line where I wanted to cut so that the saw would track until it actually started its own groove.
http://www.rcgroups.com/forums/showthread.php?t=1103007
Dave Smith
Seadog is online now Find More Posts by Seadog
Old Sep 17, 2009, 12:00 PM
bhchan is offline
Find More Posts by bhchan
Electric Airplane Junkie
bhchan's Avatar
United States, CA, San Mateo
Joined Jun 2000
Steve,
I use the Dremel Multi-Max. It is easy to use to cut hole in the fiberglass fuse. It cuts about a 1/32" wide gap.
The cutter that came with the kit is meant for wood and soft stuffs. For thin fiberglass, it can cut through with no problem. The negative part is it can't cut round corners.
MOst of the time, I score a thin line on the fuse to mark the door outline, then make a mold of the area. So if I ever loose a door, I have a mold of the area of the door to make a new door.
Brian
bhchan is offline Find More Posts by bhchan
Old Sep 17, 2009, 12:02 PM
chris williams is offline
Find More Posts by chris williams
chris williams's Avatar
Dorset, Southern England
Joined Dec 2006
Extremely tough gear doors can be made very easily from two laminations of 1/32" ply. Simply tape them to the fuselage to obtain the desired curve...
chris williams is offline Find More Posts by chris williams
Old Sep 17, 2009, 12:03 PM
yyz is offline
yyz
yyz
yyz's Avatar
Joined Dec 2004
Great technique. Thanks Harm.
Old Sep 17, 2009, 12:17 PM
SoarScale
Joined Nov 2004
Steve, I use nanobots. They wander around my workshop all the time and when I can find them, I give them a task to do. Cutting through a fiberglass fuse is an easy task for them because their hands and feet are constructed as multi-function devices - hair comb, de-licer, butt scratcher, nose hair curler and best of all - four little saws - two outside curved and two inside curved. I program them to follow a particular shape and in the case of the Eta, even the round end to the door. They are very good at it.
I use their front hands to do the major cutting and the back feet to scribe a starting line.
When I can't find them - which is quite often, I use a scribe and razor saw
New Brushless motor - 1/3 scale model? allan Electric Plane Talk 12 Jan 10, 2008 06:37 AM
1/3 scale SALTO agpilot24 Scale Sailplanes 3 Jun 16, 2003 05:01 PM
R/C Paraglider Huge 1/3 scale camera platform on EBAY countmonk Aircraft - Electric - Airplanes (FS/W) 0 Nov 11, 2002 06:29 PM
Yippee! R/C Paraglider Huge 1/3 Scale Camera Platform countmonk Aircraft - Electric - Helis (FS/W) 0 Nov 11, 2002 08:12 AM
ModelTech 1/3 Scale Cub mkirsch1 Sport Planes 2 Dec 16, 2001 04:24 PM
