Old Sep 09, 2009, 06:05 PM
Frenchy520 is offline
Find More Posts by Frenchy520
Joined Jun 2007
Futaba 9ch 2.4 conversion
Hello
Has anyone tried converting an older Futaba 9ch PCM/PPM 1024A (FP-T9VAP) to 2.4mhz using modules from suppliers such as Assan/Corona? I have one that has not seen a lot of use and would like to update it if possible. Thanks in advance for your help.
Frenchy
Frenchy520 is offline Find More Posts by Frenchy520
Old Sep 09, 2009, 07:05 PM
DannyZRC is offline
Find More Posts by DannyZRC
USA, CA, Merced
Joined Dec 2007
is the radio in question a module based radio?
if so, and the form factor of the module is identical to the more current radios (9C etc), then I would imagine the futaba module for corona/assan would be a drop-in for your 9V.
just be sure to set the modulation for PPM.
DannyZRC is offline Find More Posts by DannyZRC
Old Sep 09, 2009, 08:44 PM
Joined Jun 2007
Hi Danny
Yes the tx has a removable module in the back of it that looks to be about the same dimensions as newer radios. I had asked Assan the same question and their reply was they thought that it might work but could not verify this as the transmitter is no longer supported by Futaba and not available for them to test. I was just hoping that someone might have tried it and succeeded. I may go ahead and order the Corona system and try it. Thanks for the response.
Frenchy
Discussion Futaba 6EX 2.4 vs DX7 stevo1957 Radios 20 Jul 12, 2009 02:00 PM
For Sale <<<<Futaba 9cap 2.4 Spektrum conversion TX>>>> Aero12 Aircraft - General - Radio Equipment (FS/W) 0 Jun 02, 2009 06:33 AM
Article Futaba 3VCS 2.4 GHz Surface Radio System Review Part I: Walkabout Michael Heer Car Talk 12 Jun 30, 2008 11:58 AM
Sold For Sale: XPS Futaba 9C 2.4 GHz conversion kit smsgill Aircraft - General - Radio Equipment (FS/W) 5 Oct 04, 2007 08:55 PM
