Go Back   RC Groups > Aircraft - Electric - General > Batteries and Chargers
View Poll Results: People who ask us should be told...
"Yes, it's a good idea." 141 50.18%
"No, it's a bad idea." 140 49.82%
Voters: 281. You may not vote on this poll
Old Sep 08, 2009, 08:16 PM   #1
Pompano Hill Flyers
Miami Mike's Avatar
Should we advise people to use Lithium-Polymer batteries in their transmitters?
When people ask us if they should use LiPo cells in their radios, should we tell them "yes" or "no"? Is it a good idea or a bad idea?
Miami Mike is offline Find More Posts by Miami Mike   Reply With Quote
Old Sep 08, 2009, 10:31 PM   #2
I always recommend that people check with, and follow their manufacturer's recommendations. Who are we to go against a manufacturer's recommendations? I certainly wouldn't want to be held accountable for giving bad advice and a TX is critical piece of equipment.
Maybe I'm being over cautious, but I'd rather err on the side of caution.
Lastly, I don't see what all the rage is either. Buy an extra pack for your TX or get a better charger and charge at the field. I have multiple TX batteries and swap one out at the field when necessary.
PeteB is offline Find More Posts by PeteB   Reply With Quote
Old Sep 08, 2009, 11:25 PM   #3
GPT
GPT's Avatar
I went to 3 cell lipo in my JR2610 2 years ago no problems.
GPT is offline Find More Posts by GPT   Reply With Quote
Old Sep 08, 2009, 11:58 PM   #4
characters welcome
Mark Wood's Avatar
My
Lipo in a tx - an answer looking for a question.
Use whatever makes you feel like you know what you're doing.
mw
Mark Wood is offline Find More Posts by Mark Wood   Reply With Quote
Old Sep 09, 2009, 12:20 AM   #5
vhoward1122's Avatar
My answer would depend on if I had any experience with the model of radio the person is asking about. Neither one of the poll questions is absolutely correct. It might just be a bad idea depending on the maximum voltage a radio can handle.
vhoward1122 is offline Find More Posts by vhoward1122   Reply With Quote
Old Sep 09, 2009, 01:22 AM   #6
"Hobby Apparatus" Flyer
Mikey C.'s Avatar
Honestly, what's the point? When the energy density of NiCad/NiMhs is nowadays above 2600mAh per AA cell, why bother? Heck, even my old, rusty Hitec Lazer 4 Tx can last 2-3 hours on its stock (800mAh I think) NiMh battery on a full charge. Besides the "because I can" excuse, what's the advantage? Seems to me, the risks far outweigh the benefits, especially when taking newbies into account.
That said, this is all well and good until Tx manufacturers start designing and producing LiPo or Lion powered Tx's. When they become as trouble-free as cellphones, then there won't be much discussion in this regard I think. But until then, why "fix" what ain't broke?
There's my two cents.
Mikey C. is offline Find More Posts by Mikey C.   Reply With Quote
Old Sep 09, 2009, 01:23 AM   #7
Deletedfor proving Nauga wrong
there's 2 more choices needed...
C) Depends on the radio
D) No point using LiPo, just use Eneloops or other low self-discharge NiMh.
Its not bright to stick LiPo in a JR X9303 or a Spektrum DX7. The LiPo can damage the radio and void your warrantee. (not to mention potentially causing the loss of control of a model in flight)
Some Futaba radios are specificly rated for 3S LiPo...
with the 2 choices provided in the poll... I was forced to vote no. But its dependant on the radio as to if its OK to use them... and the relatively recent development of low self discharge NiMh gives a better option for many radios.
fhhuber506771 is offline Find More Posts by fhhuber506771   Reply With Quote
Old Sep 09, 2009, 04:56 AM   #8
Frequent Flyer
whitecrest's Avatar
I'd vote for the high-capacity Nimh. They will significantly increase transmitting time and can be charged with the Nicad charger. I think a lipo is overkill in this application.
whitecrest is offline Find More Posts by whitecrest   Reply With Quote
Old Sep 09, 2009, 06:05 AM   #9
I didn't see your answer choice in the poll?
HobbyCNC is offline Find More Posts by HobbyCNC   Reply With Quote
Old Sep 09, 2009, 06:31 AM   #10
Southern Pride
everydayflyer's Avatar
Use Sanyo Eneloops, Ray O Vac hybrids or other high quality LSD Ni Mh .
Charles
everydayflyer is offline Find More Posts by everydayflyer   Reply With Quote
Old Sep 09, 2009, 07:03 AM   #11
A man with too many helicopter
The problem is that you should charge LiPo batteries in a fire proof container. You have to remove the battery for every charge or make a fireproof compartment in your transmitter.
My Futaba transmitters with NiCad or NiMh have almost 3 hours of on time so I don’t see why you need more. For those long weekends away from home I fly several transmitters so it’s not a problem to charge one while I am flying other.
LiPo – it’s just not worth the risk.
RC Man is offline Find More Posts by RC Man   Reply With Quote
Old Sep 09, 2009, 07:04 AM   #12
That’s definitely the best solution.
Old Sep 09, 2009, 08:05 AM   #13
jrb
Member
jrb's Avatar
Neither -- always YMMV; and, only if you're careful/capable!
I do w/diode in JR 9303 (72 & w/2.4 Spek Module); my freind in 2.4 JR 9303 w/o diode -- both of us since early this spring.
jrb is offline Find More Posts by jrb   Reply With Quote
Old Sep 09, 2009, 08:24 AM   #14
Challenger 413's Avatar
I voted yes. If you are careful with lipos, why would you be careless when used with a Tx?
Challenger413
Challenger 413 is offline Find More Posts by Challenger 413   Reply With Quote
Old Sep 09, 2009, 08:55 AM   #15
characters welcome
Mark Wood's Avatar
Because happens. Why complicate matters when simple solutions exist? (Eneloop, Ray-o-Vac, etc.)
mw
Where are we with Lithium Polymer cells? Eddie P Batteries and Chargers 1 Oct 19, 2002 11:22 AM
Voltage of Lithium Polymer Cells/packs? stuka Electric Plane Talk 3 Sep 29, 2002 07:43 PM
Voltage of Lithium Polymer Cells/packs? stuka Batteries and Chargers 3 Sep 29, 2002 12:05 PM
Lithium Polymer Batteries in Foamies RD Blakeslee Foamies (Kits) 5 Sep 05, 2002 09:36 PM
Lithium Polymer Cells now available dhurd Indoor and Micro Models 8 Jun 25, 2002 03:53 PM
Congratulations SimpleM!
