Old Sep 08, 2009, 05:19 PM
wesley blue is offline
Find More Posts by wesley blue
wesley blue's Avatar
dothan,AL
Joined Jul 2009
NO!!! ahhhhh crash
well,i crashed my bran new ultimate .40 yesterday.my engine kept cuting off in mid air,i dont understand why though my engine was not over heating ,it had plenty of fuel,my glow plug was tight,and it was not flooding.does anyone no what else could make the engine just quit
wesley blue is offline Find More Posts by wesley blue
Old Sep 08, 2009, 05:26 PM
fhhuber506771 is offline
Find More Posts by fhhuber506771
Deletedfor proving Nauga wrong
Joined Mar 2005
Well.. it happens.
I crashed a .60 cc gasoline power plane Sunday
Not my first crash... not my last. (as much as I wish it would be the last...)
There are MANy causes for an engine to quit...
Idling too low too long.
mixture too rich or lean on the low end and rapidly advancing throttle.
Pinhole in the fuel line inside the fuel tank (that one will drive you insane if you don't know to look for it)
And many more...
fhhuber506771 is offline Find More Posts by fhhuber506771
Old Sep 08, 2009, 05:38 PM
lee292a is offline
Find More Posts by lee292a
Build, crash, repeat...
lee292a's Avatar
USA, VA, Cedar bluff
Joined Dec 2002
I had lots of problems with the engine dying on my Ultimate 40 also. I had a GMS .47 on it with the "tuned" muffler. It turned out that the muffler worked fine as long as the engine was wide open, but it was letting it lean out at midrange. I swapped the "tuned" muffler for one from a Thunder Tiger 46 and that took care of the problem. One thing I noticed about the Ultimate 40 was that the fuel tank was a little lower in relation to the carb than in most of the models I've flown. The low fuel tank could be starving the engine for fuel. Did you bench test the engine, and did it run OK then?
lee292a is offline Find More Posts by lee292a
Old Sep 08, 2009, 05:44 PM
Joined Mar 2005
The tiniest bit of dirt in the needle valve will kill an engine... I highly recommend a fuel filter betweent and and engine.
Old Sep 08, 2009, 05:58 PM
XJet is offline
Find More Posts by XJet
The reviewer
XJet's Avatar
Tokoroa
Joined Mar 2004
The symptoms you describe are typical of a GMS47 that has an obstruction in the carby.
It ran fine at full throttle because of the extra muffler pressure and fitting a TT46 muffler helped too because they provide more backpressure which creates more fuel-pressure.
The cure isn't to change mufflers (because those GMS tuned mufflers are *great*), it's to fix your carby.
XJet is offline Find More Posts by XJet
Old Sep 08, 2009, 08:36 PM
skippyspad is offline
Find More Posts by skippyspad
Sudden Crosswind on Final
skippyspad's Avatar
Loveland, CO
Joined Jun 2008
Just a friendly piece of advice. Once you notice a problem, fix it before you fly again. Once airborne, the problem most likely won't fix itself. Now you have to try to land with the problem. I watched a fairly new guy fire up his trainer and noticed the elevator servo had a small shutter to it with no input to it. It seemed to go away after a few minutes. He was airborne for about 5 min when the plane shot straight up, stalled and gravity took over. We brought the pieces back and found the elevator servo locked full up. The servo had failed. Had he checked it before he took off, he probably would still be flying it.
Deadstick practice is helpful though.
IMHO
skippyspad is offline Find More Posts by skippyspad
Old Sep 08, 2009, 09:12 PM
dothan,AL
Joined Jul 2009
i dont have a GWS .47 THOUGH i have a thunder tiger .46 on it,it worked fine on my somethin extra. u no,my engine did sound a little to lean yesterday.luckily i can still fix my ultimate .40 so i should have her flying by this weekend,if im still having problems with her i will check in with yal again. see ya thanks 4 the help so far . wes
Old Sep 10, 2009, 03:21 PM
lee292a is offline
lee292a's Avatar
Joined Dec 2002
Originally Posted by skippyspad
J
IMHO
Been there, done that! Coaxing a draggy bipe back to the runway dead stick is definitely a high pucker factor activity! Had lots of practice on that Ultimate before it went to the Great Hangar in the Sky! Interestingly enough, it didn't die from a dead stick. Lost orientation, got into a death spiral and before I could correct, CRUNCH!
Old Sep 10, 2009, 11:06 PM
ryank is offline
Find More Posts by ryank
Joined Sep 2009
you know what.. when your running on the ground or fixed to a "bench" the engine runs a bit different than when its up in the air..
Ive found that on the ground its a bit better to have it running just a TINY bit richer than you think is optimum.. the reason I am presuming this is the case is because when its in the air and has air speed - there is more air running in to the mix than when the engine is being held on the ground..
The way I came up with this was while during straight and level flight the air generated by the prop was similar to while being held on the ground where the mixture was set up of course.. so when flying level everything was ok.. but then when i entered into a dive and airspeed increased the engine started to mutter a bit and die out. or just generally nto sound healthy.. this is how i came up with this theory.. so then i adjusted the mix to being a little bit richer while its on the gruond in my hands and this problem did no occur anymore..
Try this out and let me know what any of you thinks..
Ryan
ryank is offline Find More Posts by ryank
Old Sep 11, 2009, 02:28 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
My initial reaction if an engine keeps cutting after a few, or several, minutes flight is that it's too lean.
As ryank has suggested, I always tune slightly rich on the ground because it always seems to lean out in the air. The recommended test I always do before take off is to open the throttle to full, and then hold the model in a vertical nose-up position for several seconds. If it's too lean (i.e. just right for level flight) it will die after a couple of seconds. If it's slightly rich you might hear it speed up a little when you lift the nose, as it leans out to optimum richness, but it won't die on you.
If it runs okay nose-up, but still dies in the air, you need to look for something else, as has been suggested in other posts.
abenn is offline Find More Posts by abenn
Old Sep 11, 2009, 06:11 AM
Mode One is offline
Find More Posts by Mode One
Closed Account
Joined Dec 2006
I don't put a fuel filter in the feed line from the tank to the carb., as I want only clean fuel to get to the airplanes fuel system, so I filter in my filling line from my fuel supply to the tank. This way I'm not putting a possible fuel restriction in the feed line. Yes, having a filter in the feed line will stop garp from getting to the engine! However, everytime you fuel, you are blowing the garp in the filter back into your fuel tank and thereby building up the amount of garp in your tank and sooner or later the filter will certainly plug!
Better to filter before the fuel gets to the fuel system of your airplane.
Checking the high speed needle the way described above is the way I do it. If checking this way doesn't help a thorough check of everything in the fuel system is needed, down to possibly replacing all the fuel lines in the system.
Mode One is offline Find More Posts by Mode One
Old Sep 13, 2009, 07:14 PM
wkk427 is offline
Find More Posts by wkk427
Joined Nov 2008
engine quiting
make sure your vent line is at top of fuel tank and the bottem line has weight on it and it feeds the carb.i got mine backwards one time and it did this also i had one do this today and it was the weight on the end of the fuel line had came loose
wkk427 is offline Find More Posts by wkk427
Old Sep 14, 2009, 06:52 PM
dothan,AL
Joined Jul 2009
it turns out that the problem was the o-ring on the needle valve was eaten up and was leaking pressure which made the carb not get any fuel.thanks for the help guys.Wesley
Old Sep 15, 2009, 07:41 AM
Mulciber126 is offline
Find More Posts by Mulciber126
What goes up, will come down
Mulciber126's Avatar
ATL, GA
Joined Jul 2009
that wouldve drove me insance lol sounds like you started replacing everything and see what you got lol
Mulciber126 is offline Find More Posts by Mulciber126
Old Sep 15, 2009, 02:15 PM
Mode One is offline
Closed Account
Joined Dec 2006
There you go, a thorough inspection revealed the culpret, don't you feel good about determining your own problem, yourself?
Discussion Harbor Freight-No More Crash Warrantees! Ah Clem Parkflyers 3 May 23, 2006 09:34 AM
