Old Sep 15, 2001, 11:29 AM
KevinP is offline
Find More Posts by KevinP
Kirkland, WA USA
Joined Jul 2001
CA Glue bad? How to tell?
What happens when CA goes south?
I've got some Hobbytown foam-safe CA that seems to take forever to set when used to glue polystyrene foam. I've come back 10 minutes later to find it still liquid in some joints. Yet in others it seems to set in a minute or so.
What's going on? Is it old or just crappy CA?
Kevin
KevinP is offline Find More Posts by KevinP
Old Sep 15, 2001, 08:41 PM
Kevin Murray is offline
Find More Posts by Kevin Murray
Kevin Murray's Avatar
USA, NC, Greenville
Joined Dec 1999
I had a bottle of thin CA go bad. It got thicker, dried much slower (min. not seconds) and it just wasen't as strong.
Sounds like yours is bad. But then I have never used foam safe CA.
Kevin Murray is offline Find More Posts by Kevin Murray
Old Sep 15, 2001, 09:40 PM
DaveW is offline
Find More Posts by DaveW
Folsom,Ca,USA
Joined Apr 2001
I've had a similar experience. the foam safe stuff doesn't seem to work as well as the regular.
As Kevin said, if its thicker ( or discolored ), its over the hill. Toss it.
I suspect that a lot of the foam safe CA is older than the regular stuff because they don't sell that much of it compared to the regular.
But, if it did set in some places, the CA is probably ok, and just the looser fitting parts of the joint took longer to harden.
Dave
DaveW is offline Find More Posts by DaveW
Old Sep 15, 2001, 09:43 PM
ED B is offline
Find More Posts by ED B
Lambertville,nj, usa
Joined May 2000
The foam friendly CA tends to get a little wierd about how it sets. I think this is due to the need for moisture to be present to cause the glue to catalyse. Kevin M is right about the thickening issue. If the viscosity changes, dump it.
Ed
ED B is offline Find More Posts by ED B
How Do I avoid that white resedue that CA glue leaves? Eyefly The Builders Workshop 9 Jul 26, 2004 08:44 AM
How do I avoid that whire resedue that CA glue leaves? Eyefly Parkflyers 2 Jun 04, 2004 12:36 PM
How to tell a bad cell... Eury Batteries and Chargers 9 Sep 21, 2002 02:23 AM
Where and how is CA glue made? LJH Electric Plane Talk 13 Jan 24, 2002 08:24 AM
DXA going bad? how to tell???? harvey Parkflyers 8 Oct 27, 2001 10:48 AM
