Old Apr 17, 2003, 06:15 PM
mefly2 is offline
Find More Posts by mefly2
mefly2's Avatar
New York Mills, MN
Joined Jan 2002
Anyone know offhand where the CG should be on a GWS J-3 Stick?
I'm setting up my old J-3 Stick for an evening flight, but I can't remember where the CG should be...and who knows where the instructions are... . Haven't flown it for nearly a year!
If I remember correctly, 50-55mm, or is that the TM...geez, it's been awhile... !
Appreciate any quick help, thanks.
mefly2 is offline Find More Posts by mefly2
Old Apr 17, 2003, 07:12 PM
William A is offline
Find More Posts by William A
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
Maybe....
http://www.gws.com.tw/english/service/book/bookmenu.htm
William A is offline Find More Posts by William A
Old Apr 17, 2003, 08:32 PM
mefly2 is offline
mefly2's Avatar
New York Mills, MN
Joined Jan 2002
Thanks Will....
I finally remembered that I had marked the fuse where the front wing mount should be...puts the CG right in the ballpark.
...(~ahem~)...managed to put it into the barn roof twice in two flights, I guess 2 for 2 isn't bad (windier than I thought)
Discussion New F-16 build-This should be on H-J's F-16 Thread electriceye Pusher Prop Jet Models 2 Aug 28, 2006 02:45 PM
Where should the true CG be on the GWS BN2 Islander?? mrebman GWS (Grand Wing Servo) 5 Nov 07, 2005 08:40 PM
Where exactly should the CG be on the GWS A10? mrebman Parkflyers 7 May 25, 2003 03:01 PM
What prop should be on this ZAGI? snowman610620 Foamies (Kits) 1 Feb 22, 2002 06:42 PM
What type of oil should I use on GWS IPS gearbox and motor? The Other Dave Parkflyers 5 Jan 28, 2002 12:47 AM
